Question about Zebra Z6M Plus Thermal Label Printer
Error code v60.15.2z
See error code v60.15.2z. printer will not print labels.
When I go to print Avery labels 5160 i get the error code load ssf 024-0969. I can print all other documents
Hi, Brad;
the label with the adhesive on the back when it go through the heating unit it goint melt will coming off and stick on paper path it cause paper jam, sugest print label use inkjet printer.
Oct 31, 2013 | Dell 2155cn and 2155cdn Color Laser...
Error 616
The software is not corrupt. The 606 is basically telling you that one of the dots that heat up to make the image on your paper isn't able to heat up correctly. Since the printer can typically shift these dots over from one side to the other to help compensate for these dots going bad, it is also saying that it can't shift either.
You're seeing this issue on a barcode, and instead of a barcode you're getting a gray box. If you're unable to make changes in your code that is going to the printer, that tells it what to print and where, your best bet is to purchase a new printhead form Avery.
1-800-543-6650
Though the issue can be worked around, it is possible that now that you can print that barcodes you want, you may find that new ones won't be able to print because they're printing in that same space where the printer cannot shift dots to compensate for the bad one.
Jul 10, 2012 | Monarch 9855 Thermal Printer
We have an HP 2015n printer with an error code of 10.1000. Can you please tell me what this code means? Thanks
10.1000 Black e-label missing error Error message 10.1000 supply error alternates with Reinstall c00381084.jpg with a ? under the Black print cartridge gas gauge Description The black print cartridge or print cartridge e-label is missing. Action
  1. Install the black print cartridge.
NOTE: If this error occurs upon initial power-up on the printer, remove all cartridges to check for the orange packing tape. If present, remove it before reinstalling the toners.
Nov 10, 2010 | Computers & Internet
LP2844 printer stops after one page with out of paper error
Did you try to reload the labels. Pull the labels out and clean the paper path
May 07, 2010 | Zebra LP 2844 Thermal Printer
Printing error print system exception error
I had this problem with the LabelWriter 450 Turbo and it was a .Net Framework problem.
1. Uninstall the Dymo Label software
2. Click this link to download .Net Framework 4.0 http://www.microsoft.com/downloads/details.aspx?FamilyID=9cfb2d51-5ff4-4491-b0e5-b386f32c0992&displaylang=en
3. Reinstall latest version of your Dymo Label software (w/o printer connected to PC)
4. Reconnect label printer when prompted by installer
This should fix the problem
Dec 24, 2009 | Dymo LabelWriter Thermal Printer
Labelwriter 400 was working fine. Then put in a new roll and it stopped working. Every time i get a Print Error and it doesnt print at all. Unplugging the wires results in printing 1 label and spitting out...
Have you checked that the labels are suitable for this model. There is a code between each label that sets the printer up. If its sending the wrong code then the printing will be eratic or non existent
Aug 10, 2009 | Dymo LabelWriter 400 Thermal Printer
I work in a lab and we use a monarch paxar 9825 label printer and this morning it has an error code 400. What is this error code?
These types of errors are data errors. If you post your datastream, I may be able to tell you where the error is at.
Dec 11, 2008 | Paxar Monarch 9825 Thermal Label Printer
What does 10.0002 supply error mean?
10.0002 Magenta cartridge e-label error Error message 10.0002 supply error alternates with Reinstall c00381084.jpg with a ? under the Magenta print cartridge gas gauge Description E-label cannot be read or print cartridge is not properly installed. Action
  1. Open the front cover of printer and remove the toner cartridge exhibiting error.
  2. Inspect the print cartridge to ensure the e-label reader is attached to print cartridge and is not damaged.
  3. Inspect the inside of printer to verify the e-label does not have any product packing tape still attached.
  4. Inspect the e-label reader to ensure the gold contact points are not damaged or bent. Also inspect the black plastic on e-label reader to ensure it is not bent or broken.
  5. Reinstall the print cartridge.
  6. Power cycle the device.
  7. If reinstalling the print cartridge does not resolve the issue, replace the print cartridge.
  8. If the problem continues, contact HP Customer Support Center for technical assistance
Dec 03, 2008 | Office Equipment & Supplies
Printronix T5000r Label Syntax to print " character
It is a syntax error.
It should read:
D;POINT;075;095;12;6;"text"
You might be able to get away with this:
D;POINT;075;095;12;6;"test";"text"
quotes have to be in sets of two and elements have to be seperated by semicolons.
Jul 14, 2008 | Printronix T5000r Label Printer
Zebra Z6M Plus Thermal Label Printer Logo
114 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
