Question about Troy Garden
Hp gas Hi, I have a Troy-Bilt, 21" push, walk behind mower mulcher. Model number is: 11A-436A711. It starts fine, but quits after just a few seconds. It has a new spark plug. I had seen some suggestions online that said to take the bowl of the carburetor off and then use a thin wire to make sure the small holes aren't clogged. My mower looks different than the examples online, and I don't know where to find it on mine, or if it's even the right fix for mine. Thanks.
    Master:
  • 969 Answers
Follow gas line from tank to carb. Observe bottom of carb. Remove screw holding carb bowl to carb. Clean bowl. Pinch off gas line with pliers. Ensure float falls down easily. Float up no fuel flow, float down fuel flow. Observe screw that hold carb bowl to carb, see if it has a whole thru it, clean with small wire, bread wrapper works good. Observe center fuel port, clean with wire. Remove pin that holds float and meter needle, clean port with wire. Reassemble. Ensure air filter is clean, oil is full, 30w oil, spark plug is clean and properly gapped. Replace air filter and spark plug once a year. Empty old oil out if any grey is observed in oil, this is moisture, can accumulate after winter storage. Clean out side of carb with carb cleaner to ensure choke can rotate freely. Always use Stabile in gas.
All newer mowers have a low oil shutoff.
Posted on May 24, 2014
4 Suggested Answers
honeymokey
  • 3113 Answers
SOURCE: Troy-Bilt TruCut 100 21: cut / 6.5 HP Briggs &
Remover carb. and clean it.
Posted on Jul 23, 2010
Knucklebstr
  • 222 Answers
SOURCE: I am replacing the spark
I'm guessing you have a standard Champion J19LM plug, which has a gap of .030. They come pre-gapped from the mfg. and usually no need to adjust them. Most of the plugs on these engines have a .030 gap. There are very few exceptions that use a .020 gap (such as the RC12YC). Anyway, here's a link to a chart I like to use for reference: (there's a drop down menu at the top to change engines, but the standard Briggs engine is the one here).
http://www.manddsmallengine.com/briggs/info/plug7.html
Hope this helps. James
Posted on Aug 12, 2011
  • 6468 Answers
SOURCE: troy bilt lawn mower were spark plugs go in striped and wont tighten
you can get a spark plug thread repair kit at a auto parts store
Posted on Aug 14, 2012
Troy Bilt 33" walk behind mower blades won't turn on.
Troy-Bilt Lawn Mower Blades Won't Engage - Model ...
www.repairclinic.com/...Mower/...-/Troy-Bilt-Lawn-mower-blades-won-t...
Most Frequent Causes for Lawn mower blades won't engage. See All Lawn Mower Parts for model 13AP60TP766. Cause 1 PTO Clutch. If the blades don't rotate the electric PTO clutch might not be engaging. ... Lawn mower wheels don't turn ...
Nov 08, 2015 | Troy Garden
Murray 21" 6.0 walk behind mower. Plate showing model number is missing and I need to find a manual, model comes with grass collection box and a mulcher. any ideas please?
hi go to google search and type in... pdf murray 21'' 6.0 mower manual ......it should take u to a page with all the info u need .cheers
Sep 16, 2015 | Garden
I have a troy bilt 21" push mower. Model no.11A-436M01198557. While changeing my pullcord the coil spring came out. How do I reset and put back in houseing
slip the spring through the rope hole attach it the rope pulley and wind it clockwise the spring will be pulled in make sure you set spring in its groove on the outside of cap the tighten it up by winding then let uncoil in cap
Jul 09, 2014 | Garden
How do you put a mulching blade on a troy bilt 21 inch walk behind lawn mower
remove the center bolt from under the machine put a block of wood against the blade to hold it from turning on you
Apr 13, 2012 | Garden
What kind of oil does my Troy-Bilt 12a-264u011 5.5 HP walk behind mower use?
You can check your manual but i would use SAE 30, if in doubt call your Troy Bilt dealer
Jul 02, 2011 | Troy Bilt 5.5hp Self Propelled Mower
How maintenance Troy bilt, 6.50 190cc 21" 2 in 1 push mulch mower with rear bag?
my troy-bilt 21" mulch mower 6.50hp/190cc won't start after it run for any amount time.
Sep 05, 2010 | Garden
Have Troy Bilt 47279. Need Vacuum Snout.
i NEED A REPLACEMENT VACUUM SNOUT FOR A 1990 TROY BILT CHIPPER-VAC. THERE IS NO MODEL NUMBER FOR THAT YEAR, ONLY DESIGNATED AS "MODEL 5 HP".
Nov 06, 2009 | Troy Bilt Walk Behind...
33 inch Troy-Bilt walk-behind clicks while trying to elect start
Check the voltage to the solenoid when the key is turned to start, it should be 8-12 volts. IF the voltage is low clean all electrical connections.
Jul 06, 2009 | Garden
Garden Logo
97 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
