Question about Sunbeam Pets - Others
Worn driver I have an old sunbeam clipper asc or acs??? The driver needs replacing. I,m told the clipper is too old to repair. How long ago did you stop making this clipper and what year did you stop making parts?
    Sergeant:
  • 266 Answers
Have you tried looking at ebay for another one?
Posted on Apr 27, 2014
I have a Sunbeam Breadmaker Model 5891 and I need a new bread pan; it's dented and the seal around the paddle is worn out. Where you one purchase them?
goto the amazon website the bread pan is there and also bread kneeder thats £6.05 EACH THE LAST TIME I LOOKED TWO WEEKS AGO
Jan 20, 2011 | Sunbeam 5891 Bread Maker
Greetings, I purchased a full size heated mattress pad with a single off-hi-lo-off control switch several decades ago and the fabric covering the heater elements has deteriorated thus exposing the...
I don;t think there is any repair that is possible and you will need to replace your mattress pad. I would recommend you contact sunbeam directly at sunbeam.com and see if this model has a lifetime guarentee.I tried but they wanted to know how old it was and other info that I could not provide.
If you have had this good of service from their product then I would let them know and maybe they will work with you.
I have had good results contacting companies and praising their products and it don't cost much to try. Thank you
Jan 16, 2011 | Sunbeam Heating & Cooling
Our Sunbeam Mixer (stand variety) is about 25+ years old and has many miles on it. . About a week ago, while mixing a light concoction it slowed down and then stopped. It started a couple days later...
You will need to search for a repair shop. There are replaceable parts in the speed control assembly that will cause your symptoms when they fail. The question is - can those replaceable parts still be obtained after 25+ years?
May 10, 2017 | Sunbeam 275 Watts 2369 MixMaster Series...
Oster Blade 918-306 Size Texturing Fits Oster Classic 76 Clipper, Power Pro, Power-teq And Star-te: Oster class 76 clippers....had them for a week and...
70ca16d.jpg Hope this helps, this is a tongue guide, you hopefully recognise it on your blade. If they are not paralell, then adjust them with pliers, both need to be perfectly vertical. When you put it on the clippers push the latch in as you close the hinge.
If it still wobbles then the next fe wthings need checking
1. The hinge screws on the clipper are tight, located either side of the hinge on the clipper.
2. The drive lever may be worn, thats the maroon peice of plastic sticking up at the top of the clippers, it moves from side to side when clippers are running.
3. If all seems fine up to now, your clipper should be fixed under warranty as it will involve changing parts covered by the warranty.
www.sheareaseltd.com
May 17, 2010 | Sunbeam Oster Blade 918-306 Size Texturing...
I want to use my set of ASC 295 with my (3-year old Intel) IMac. Do i need tot do something special to get this to work together. Thanks Chrisja
Hi therebud , there shouldnt be anything you need to do , besides making sure you have the audio drivers installed.:D
Jan 09, 2010 | Altec Lansing ACS 295 Computer Speakers
Run but will not cut
Are you sure you have Andis A5 or did you mean Oster A5 Clipper, if this clipper is A5 Clipper, You need to check the Lever for wear, The front of the Lever show wear on both side, Like white color and is not squad this Lever is worn. Need to replace. This Lever moves the blade side to side fully. if the Lever is worn the blade will not move fully side to side and the cutter blade the smaller blade will stay in the middle with hardly no travel to side to side and will not cut the hair even if you purchase new blades. Also I would like to mention if the Oster Locking Hinge is worn out and don't have the require tension to hold the blade in place the blade will not cut. How do you test the Oster Hinge on a Oster A5 Clipper,
(1) first close the hinge, in close potion with your finger nail try to open the Hinge, if the hinge slightly open or opens loose the Hinge is worn. if the Hinge is good it will not open or move and your nail may just brake your nail.
Many of my customers run into this type of problem, and the problem can be solve easily by checking these parts first.
One more item I would mention here if replace the A5 Hinge make sure you get the A5 Hinge not the Oster 76 Hinge they are driferrent, The A5 Hinge has on the back two wire's sticking out that fit on the Oster Latch for the A5 Hinge, the Oster 76 Hinge would not have these wire's on the back. I recommend replacing the Latch when you replace the Hinge. I hope this helps any body that have a A5 Oster clipper or A Oster 76 Clipper.
I have over 20 years in the repair business of Sharpening & Clipper repair. Mannys Sharpening 323 263-4697
b61c252.jpgOster Hinge
Jun 10, 2009 | Andis Outliner II Hair Trimmer
Blunt Clipper blade
www.sheareaseltd.com £5.90 incl VAT & Postage for sharpening.
Apr 04, 2009 | Sunbeam SBCL 802 Hair Trimmer
1690 trimmer
Please send your clipper to the Andis repair department at 1800 Renaissance Blvd Sturtevant, WI 53177. If this clipper is less than a year old repairs will be done at no charge with a copy of the receipt. If the clipper is more than a year old there is a $6.50 service fee and $5.00 shipping fee, there may or may not be a charge for parts depending on what actually needs to be replaced. If you would like to talk with a customer service rep please call 1-800-558-9441.
Thank you for purchasing Andis.
Dec 22, 2007 | Andis 01690 Hair Trimmer
Wahl clippers
Contact a scisor sharpener in your area. They usually do clipper blades as well ..
Oct 04, 2007 | Health & Beauty
How do I put it back together?
buy a new one, look at it, put yours back together and return the new one.
Jun 10, 2007 | Sunbeam SBCL 802 Hair Trimmer
Pets - Others Logo
56 people viewed this question
Top Sunbeam Pets - Others Experts
Ross Keen
Tom Chichester
Ruth summersides
Are you a Sunbeam Pets - Other Expert? Answer questions, earn points and help others
