Question about Ovens
Model # w10117491a gas range
F2 come's up and can't use the oven. at one point i could pull the plug and wait ten minutes and plug back in. and it would work but now it stays f2 and beeps.
fridgetech
  • 473 Answers
SOURCE: F3 and F2 Error Codes
If hitting clear/cancel won't clear it try unplugging and then plug it back in. My guess is the oven control is bad. Here are the fault codes for this model.
Failure
Code
Condition Check/Repair F0 or F1 Failed transistor in control If code cannot be cancelled, replace the Electronic Range Control (ERC) or touch pad F2 Oven over temp - exceeded 590F with door in unlocked position or 990F with door locked If actual temp condition occurred, look for welded relay contacts or high resistance connection or any cause in the oven temperature sensor circuit F3 Open oven temperature sensor circuit Measure oven temperature sensor circuit at oven temperature sensor (should be approx 1100 ohms at room temp); check for cut or pinched wire or loss of contact F4 Shorted oven temperature sensor circuit Same as above; check for melted connector or both leads shorted to ground F8 Component failure within Electronic Range Control (ERC) effecting temp processing circuits Replace Electronic Range Control (ERC) F9 Problem with door lock circuit such as pinched wire between Electronic Range Control (ERC) and door lock switch Check wiring and test operation of switch
Posted on Jul 15, 2008
docjohn174
  • 943 Answers
SOURCE: gas oven temp problem
HI thanks for your question. there is a oven sensor , located in the oven, top left corner. replace this part. thanks the appliance doc. please rate my answer. thanks
Posted on Oct 11, 2008
aborcass
  • 2651 Answers
SOURCE: f7 error steady beeping
short inthe key pad, thinks a button is being preesed for an extended period of time youll need to replace the keypad/ electronic control
Posted on Nov 17, 2008
heatman101
  • 43501 Answers
SOURCE: Kenmore Gas Oven doesn't heat
Here is a tip that I wrote that will help you with that problem...
The ignitor for your burner has faied...
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
Posted on Apr 07, 2010
SOURCE: top oven bake igniter comes on, but gas does not.
If the bake ignitor comes on (starts glowing) - check the amperage on the bake ignitor wires when it's on. If the ignitor is a round style - amperage should be 2.5-3A, if the ignitor is rectangular - 3 - 3.6A. If less than 2.5A or 3A respectively - replace ignitor. If the ignitor does not come on - check the voltage on the ignitor, should be the line voltage 110-120v AC. Faulty gas valve is uncommon, but still a small possibility. Ignitor part numbers for round style ones: 4342528, WB2X9154, SGR403, 5304401265;
rectangular styles: 12400035, WB13K21, WB2X9998, SGR412, NR020, 5303935066, 814269, 9753108.
Ignitors of the same shape (i.e. rectangular) are interchangeable, if you can splice the wires.
Posted on Jul 15, 2010
Electrolux oven wont stop beeping
Hi Friend, I am happy to assist you!
I understand your Electrolux oven is continuously beeping. Without knowing your specific model number, let's try resetting your oven. This can be done by either unplugging it or flipping the household circuit breaker to the off position. It is best to wait roughly ten minutes and then turn on your oven. If resetting the power does not correct the issue, then your range could possibly be experiencing a communication problem with the EOC (electronic oven control) or a potential wiring failure. Hope this helps! - Z
Jul 13, 2014 | Electrolux Ovens
How do you unlock my frigdair oven door
Good Afternoon Anonymous, this is Z. I am happy to assist you!
I understand the oven door of your Frigidaire range is locked. May I please have your model number? The serial tag, which lists your model number, is typically located in the storage drawer, on the right side. With this information I can help you unlock the door.
In the meantime, try pressing the CLEAR/OFF or CANCEL button in for approximately three seconds if your range is a touchpad model.
If you have a knob type range control, I suggest starting a self-clean cycle. Then turn the stop time knob to the off position. If that does not work, then disconnect power to your range and reset it by either unplugging it or flipping the breaker off. I suggest waiting roughly ten minutes and then turn on your range.
Hope to hear from you soon and best of luck!
Apr 26, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
F1 code
Good Afternoon landstardad, thank you for allowing me to assist you!
Typically error code F1 indicates that a runaway temperature (overheating) issue has been detected. Let's try reprogramming your range by either unplugging it or flipping the household circuit breaker off. It is important to wait roughly ten minutes and then turn your range on. If the error code does not clear, at this point, I would suggest contacting a professional to proceed further. Most likely the RTD Probe (Resistance Temperature Detector) or the EOC (electronic oven control) will need replacing. Hope this helps!
Feb 01, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire stuck in DR mode
Good Morning ShawnR, thank you for your post!
An error code DR commonly refers to a door lock malfunction. I understand you have reprogrammed the range by unplugging it. It is important to wait approximately ten minutes and then turn your range back on. Typically, this will clear most false error codes. If the error code continues to display, your range could possibly have a faulty door latch, light switch or EOC (electronic oven control). I am fairly confident that an authorized service agent will be able to restore your appliance to its normal operating condition. You can often locate a qualified service technician on the manufacturer website.
Thanks for allowing me the opportunity to assist you!
Nov 26, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
Oven will not work
Good Afternoon Sandra, thank you for your inquiry!
Let's try reprogramming your range by either unplugging it or flipping the household circuit breaker off. Wait roughly ten minutes and then turn the unit back on. An experienced service technician may need to further evaluate this issue if it was not resolved with the power reset. Your appliance could possibly be experiencing a potential wiring failure, faulty EOC (electronic oven control), sensor probe and/or bake or broil element. I would strongly recommend consulting a professional to narrow down the precise issue before investing in parts that may or may not be the root cause.
Oct 31, 2013 | Frigidaire FGB24S5A Gas Single Oven
Displaylight not working
Hi Robert - Based on the symptoms you are describing it sounds like the range possibly has a communication error with the EOC (electronic oven control) or a potential wiring failure. How long did you leave the breaker off? It is important to wait roughly ten minutes and then turn the unit back on. If the issue persists, at this point I would suggest reaching out to an Authorized Service Technician that will be able to assist you in the diagnose of your appliance.
Jul 09, 2013 | Frigidaire FEB24S2AS Single Oven
When the pyrolytic function is switched on the oven starts the process then after about ten minutes the code f1 appears on the digital control panel and stops
Hello katefreeman1 - Typically error code F1 indicates that the range has detected an issue with the runaway temperature (overheating). A certified technician will need to check the RTD sensor probe and/or EOC and replace if necessary. Try reprogramming the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and restart range. Usually this will clear most false error codes. If it proves to be ineffective, contact a professional to move forward accurately.
Jan 22, 2013 | Electrolux EOC6690X Pyrolytic Electric...
Frigidaire oven door is still locked 7 hours after self-cleaning
Hello - Try resetting the unit by either unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and turn the range back on. This will clear most false error codes. If error code still displays on panel, I would suggest contacting a professional to move forward accurately. The unit could possibly have a faulty light switch, door latch or EOC.
Oct 21, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
Oven heats for 5 minutes then shuts off
The touchpad has a ribbon connector to the main control. Remove the control panel re-insert the touch pad ribbon into the main control tab. If it is not a bad connection the touchpad will have to be replaced.
Jul 07, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
The pilot light for the oven went out.
Relighting Your Furnace's Pilot Light
furnace1.jpg - Turn off the gas at the main valve at your utility box - Wait five to ten minutes for gas fumes to waft away - Get a long match—yes, a fireplace match, not a standard match - Set the gas valve on your furnace to "pilot" - Press the red button as you hold the match to the pilot valve - Keep pressing the red button for 30-60 seconds so the pilot can heat the thermocouple. Release the button and see if the pilot remains lit - If pilot goes out, wait five to ten minutes and repeat the process - Once the pilot stays lit, turn the main gas valve back on - If the pilot light continues to go out, call a technician, who may need to adjust or replace your thermocouple or adjust your pilot
Jul 28, 2008 | Tappan 30IN ELEC IGNa Oven
Ovens Logo
125 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
