Question about Hitachi 60UX54B/55K 60" Rear Projection Television
Will not stay powered on
I have a Hatachi 60UX54B and if I leave it unplugged for a few minutes & then plug back in the set will power up for a few minutes then shut down and will not power up again. It seems that when the unit warms up the the power drop out. Thanks in advance, Mark
    President:
  • 3,130 Answers
Does the convergence look OK before it goes out/ Have you opened the set to see if there is any liquid or any staining on the printed circuit boards right under the picture tubes? This set is very common for the CRT coolant to drip out of the tubes and fall onto the printed circuit board. good Luck
Posted on Sep 05, 2007
    Sergeant:
    Champion:
  • 326 Answers
Hello, please check Q710 in high voltage circuit. If you need more info please advice. Arpi
Posted on Aug 12, 2007
  • Arpad Kothai
    Arpad Kothai Aug 12, 2007
    you can also check/replace integrated circuit IC401, capacitor C715, I601, IK04, IK05, D915.
    Change R074, R075 from 47K to 15K.
    Add a 100pf capacitor, one for SDA3 line other to SCL3 line.
    Check that C128 is a 22uf/16V.
    Best regards,
    Arpi
SOURCE:
Kenmore Upright Freezer Model #970180021 WB3285869Serial # I unplugged my freezer,plugged back said power interruption, I hit several buttons, Now flashing off, nothing else on panel lit up,thawing
try unplugging it and leaving it unplugged for a while. 15 minutes maybe? Leave door closed so it stays relatively cold. It should reset the unit.
Feb 01, 2018 | Kenmore Freezers
Will not power on..have to unplug wait till red power light goes off then plug back in ..then will power on fine
Power cycle your TV by unplugging it and leaving it for a few minutes. Plug it back in and turn it on. Restore settings back to factory defaults. If everything else fails, then I would recommend pursuing repairs.
Oct 18, 2013 | Dynex DX-LCD32-09 LCD TV
Television buttons unit do not work
Try power cycling the TV. To do so, unplug everything from the back of it, power off the TV and unplug it from the wall. Leave it unplugged for a few minutes, and then re-connect and plug the TV back into the wall. Turn it on and reset any system setting changes back to factory defaults. If the problem(s) still exist(s), then I would recommend scheduling repair service.
Oct 05, 2013 | Insignia IS-LCDTV32 32 in. Television
Where can i find a manual for a hatachi 60ux54b tv
you shouls be able to getboth the user manual and the service manual from www.tvrepairworld.com
Nov 04, 2012 | Hitachi Televison & Video
Dvdr philips 3305 blocked
Unplug your player from the power supply (do not just set it to standby). Leave the player for a few minutes. Plug your player back into the power supply and switch on the machine. This should unblock it.
Jul 02, 2008 | Philips Televison & Video
The tv turns on but no picture.
Mine did the same but no picture, just sound every few seconds for 1-2 seconds. I unplugged from the wall for 10 seconds and plugged back in, works fine now.
Jan 12, 2008 | Hitachi 60UX54B/55K 60" Rear Projection...
Hitachi 60" picture flashes on and off.
I've had the same issue although I don't unplug everything. I turn it off and then unplug it from the wall for 10 seconds then plug it back in. Seems ok after that. Has happened 4 or 5 times over the 10 years I've owned it.
Dec 20, 2007 | Hitachi 60UX54B/55K 60" Rear Projection...
Will not stay powered on.
Unplug the convergence yokes and see if set comes on DO NOT leave set on for longer than 2 minites with the plugs out presumming the set comes on, if it does replace 2 x STK 392-110 convergence ICs
Aug 03, 2007 | Toshiba 50A61 50" Rear Projection...
Screen goes blank after a few minutes
hi if your sure that all the power settings of the screen and the comp are fine then it points to 1 reason: the screen is heating up and the automatic circuit shuts it down... try locating it some cooler place or put a vent behind it... see if it does any help if soo set it in a cool place good luck
Mar 16, 2006 | ViewSonic VP191b 19" LCD Monitor
Televison & Video Logo
76 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
