I recorded a video on my camera and when i played it you could barely hear it and I dont know how to turn up the volume...help!
SOURCE: Every time I try to play back a video, it goes super fast and I don't know how to slow it down!
Are you sure you have not recorded the video in time-lapse mode? Could be worth checking. Once in the Video setting, you can use the thumb ring to change video mode - one of these modes is normal and one is time lapse (there are five or six others).
SOURCE: Powershot SD1000 automatically shuts down in Camera mode
In any mode that the camera will stay on, press the "Menu" button and navigate to the RESET option and try to reset the camera. See if this will get the camera to function properly.
SOURCE: video records at high speed
You need to change your video settings. You have it set for time lapse. Turn your camera to the video mode on the top of the camera and then turn the dial on the back of the camera to the size of video you desire.
SOURCE: no sound
It sounds like you may be in "Fast Frame Rate" video mode. Turn on the camera to video mode, then press right/left to select normal 640 pixel video. (Depending on the camera model, you may or may not have to press "Func" or "Func Set" first).
SOURCE: Where is the Volume control
Press the "Menu" button, then scroll right to select the "Tools" tab, then scroll down and select "Volume" with the Func/Set button. Then scroll down to "Operation Volume" and adjust to maximum volume. Then press the "Menu" button to exit. Wasn't that easy and intuitive? (hehehe, software engineers, gotta love 'em) Don't expect much of an increase though, the SD780's speaker is very tiny.
