Question about Husqvarna Backpack Leaf Blower 350 Bt Yard Blower With Warranty Husky 350
My blower just stalled and will not run it is less than a year old and now the pull cord is very tight but it will turn and start but it will not run for mor than a few seconds
  • Husqvarna Master
  • 1,807 Answers
Have you changed the fuel.? If it had been stored for a long time with fuel in it then it could have gone stale and will need replacing. Also the 2 stroke oil can gum up carbs as the fuel left in it evaporates. Possibly clean carb, check fuel is getting into the cylinder.
Posted on May 09, 2013
2 Suggested Answers
  • 76 Answers
SOURCE: husqvarna 125B will start and run but once it heats up it stalls and will not start until it cools down
sounds like it's going lean lack of fuel check for cracked fuel lines,primer bulb or leaky carb to engine gasket
Posted on Aug 30, 2012
Snowblower won t start. pull cord too tight
How long has it setup? Could be varnished up, maybe broken ring, damaged needle bearings. Remove muffler an try to spray some cleaner or fuel in port to free it.
Mar 13, 2014 | Garden
Replace pull cord
Echo is one of the easiest pull cords to fix, remove the screws on the rewind and take off the motor and flip it over and pull old rope out and put new rope in wind the spring the correct way so when you pull rope it tightens spring so it will wind back up when let go, not winding too tight !
May 22, 2013 | Echo Pb - 413t Backpack Blower
Yardman blower jut quit running like it was out of gas, restarted then did the same thing, now its difficult to pull the cord to strt
I'll guess and say that the carb flooded the engine and you have hydro lock.Pull the sparkie and clear the extra fuel.
The carb is at fault,IMO.
if the needle get a little dirt in there it will hold the float open and flood the motor.
Dirt.
Nov 16, 2012 | Yard Man Mulchinator QuickShift BlowerVac...
Pull cord frozen
if it died while in use and you can't pull the starter cord the engine might have locked up was the oil/fuel mixed properly?remove the cover and see if the flywheel can turn
May 19, 2012 | Poulan Pro 25CC 2Cycle Gas Blower
The PB-250 will not start. It was purchased last year and used little. I have fresh gas and a new properly gaped OEM plug. I do have spark. The spark plug is wet with fuel. Can one flood the engine by...
It is very easy to flood this item mind you its easy to flood all petrol trimmers. If plug is wet simply turn the switch to off and pull cord at least 15 times you should get the engine to start coughing keep pull cord but do not turn the petrol on do not prime it either. It should catch. If it does not push the primer once and pull cord
May 31, 2017 | Echo Gas Blower 135 MPH390 CFM Blower...
Ryobi CS30 - Stalls out?
Dirt or varnish in fuel filter or carburator. Change filter if there is one.
Flush out the carb with a varnish remover.
Open high speed needle valve 1/8 turn farther, then turn in while running until it just smooths out.
Jun 07, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Cub cadet 18m, one year old won't start
try cleaning the air filter and make sure no grass is stuck under the guards (build up) do this while not running of course lol
Aug 21, 2009 | Garden
Craftsman blower stalls when choke is disengaged
You need to play with the timing adjustment, either on the spark plug, or the gap between the contact and the magneto.
That'll do it ;)
Don't forget to rate, thanks
Jul 31, 2009 | Craftsman 4 Cycle Blower/Vac
Hello, I have a Poulan Pro 25cc gas blower, 1 - 2 years old. Model #BVM200VS : Serial #07303N201072-1. I can get the engine started within 2 to 3 pulls, however, the engine will not idle - if I let go of...
Remove the spring loaded screw.Then clean the end of it.Replace it.Screw it in tight and then losen one and a half turns.hope that was helpfull.
Jul 31, 2009 | Garden
Husqvarna Backpack Leaf Blower 350 Bt Yard Blower With Warranty Husky 350 Logo
106 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
