Question about LG 32 32LK450 32 in. LCD TV
LCD set won't turn on but rde and blue light show
When I plug it in the red light is on and it turns blue when I touch the "on" button. No picture or sound. Can the screen be tested by hooking it up to something and is there a way to test the T-Con and Main boards. I suspect the startup board is ok since it lights up. (the lights) Thanks, Bob
SOURCE: LG RZ-23LZ40 no Picture
Thanks Jaime867
Best send repair manual.
I have pics to show / identify problem but I cannot attach to my reply. Parts defective are: 4532M x 2 (UC2 & 3), diode next to diode RC22 & cap C35 and IC6 (cannot see part number). Board number is YPNL-M007B r1.0, also recognized L.G. Phillips part number: LC230W01-A2
My hands are not as steady as years ago to do surface mount solerering but my wife can as she has done this before being electronic equipment assembler.
As stated before I need to find source of what I suspect is short that had blown these components.
I bet a replacement board is more expencive than a new LCD TV!, but I want to resolve this prob and maybe help others...LG too.
Thanks Heaps Jaime867!
Cugar63
Posted on May 25, 2008
  • 5 Answers
SOURCE: LG LCD 37'' standby problem
if you want i will buy the tv from you
Posted on Feb 23, 2009
pilot210
  • 39 Answers
SOURCE: No picture on startup and random remote cntrl functions stop working
Common problem on this set is the main board p/n AGF33761101. However, you might try a 'quick fix' mod on this set which involves locating and bypassing components.
I do think that the replacement board just have these 4 coils bypassed on them already, so you might be able to save some $$$ if you're electronics-savvy by removing and discarding coils l4010, l4011, l4012 and l4203... then jump the solder pads they were on with small bits of wire, making very sure not to short to ground. Good luck!
Posted on May 19, 2009
  • 187 Answers
SOURCE: Vizio P42hd approx. 1" red line on screen, picture shifted
You will need to replace the control board and your TV will be better that a new one.
Posted on May 27, 2009
  • 644 Answers
SOURCE: 47LC7DF, Green light comes on, blinks with remote
When you say that you have replaced the main board i assume you mean the power board? If the green light comes on and blinks when the remote is touched it was never a issue with the mainboard, if it was you wouldnt have any signs of power. In most lcd tvs you have the main board which is normally the power board, the signal board which recieves signal and hold settings of the tv which can be all in one, the other is the inverter board, which scrambles the signal to what you see on the screen, and next we have the back light which lights the screen so you can see the picture, sometimes in certain models as i have learned you can have power/inverter boards which means the inverter and power are all on the same board, in your case i pressume the inverter board is seperate board and probably the issue you need to address, you can buy these online probably the same place you got your new mainboard from. Hope this helps pls post bach what happens.
Posted on Feb 01, 2010
Red Light Won't Stay On
1. Remove batteries from remote to "zero" it, then reinsert batteries
2. Turn on TV (RCA?)
3. Press and hold CODE SEARCH button until indicator lights
4. Press and release TV button. Indicator will blink and remain on
5. Enter code from list in instructions
6. Point remote at TV and press on-off button. TV should turn off
7. Use remote to turn TV on again and press CH+. If TV responds you're all set; if not, repeat the process with the next code
Nov 19, 2012 | RCA CRK76TE1 UNIVERSAL REMOTE - With...
Tv won't turn on
Replace the power supply board the blinking power indicator is usually indicating the power supply needs replacement or repair. You can get the replacement power supply boards from www.tvcircuitboards.com
Oct 20, 2012 | Samsung LN-S3241D 32 in.LCD HDTV
Proscan 40LC45S screen flickers, red light flickers, won't turn on
check bad component parts at the power supply board as will as burnt parts.
Sep 07, 2012 | Proscan 40LC45S 40 in. LCD TV
My LG 42LV4400 has a red light in the bottom left corner but it will not turn on.
hello!
2 month and already quit? OK: first thing to do is to unplug TV off the power strip or wall outlet. Wait for a few minutes and plug the set back into the power source. Try to turn on the set manually, by touching sensors or buttons on control panel. some TVs have push buttons, some touch sensors. If your TV was set to "auto power on" mode, then don't touch anything after plugging set in. That's the only action you can do to "revive" the set. If you will be able to turn set on manually and "free standing" without any external connections, except power cord, check your remote control unit. 95% of consumers turn on their sets via "clickers". In case of complete failure, you might have month or 10 month left of factory warranty, depend on price you paid. Use it a.s.a.p! If needed. There is no magic button to heal broken circuitry.
Good luck,
Alex.
Feb 19, 2012 | LG 42LC2D 42 in. LCD HDTV
TV will not turn on? Blinking LED,won't turn on? Changing back and forth from Blue and Yellow; which is on and off from panel lights?
the red picture is because the optical block is bad now this part cost about $500 plus labor , when you took the lamp out you need to put the door back otherways the tv wont wort
Jan 27, 2012 | Toshiba 62MX195 62" HDTV
My ps3 won't show on tv but it show that it's playing
Are you saying that it has sound but no video?
Plug only the video plug (yellow) to the TV. Turn on the backswitch. When the red light in front is on, put your finger on the on/off button in front AND KEEP IT THERE. You will hear some beeps; don't worry about that. Keep your finger on the button until the front power light goes red again. This resets the PS3 video settings. Turn the PS3 on and the TV should pick up the signal.
Hope this helps. Keep us posted.
Jul 07, 2011 | Sony Playstation 3 (PS3) Console
When it is powered up nothing works, it won't eject, won't open up, blue light doesn't come on, "no signal" shows up on screen. This is on the Vizio Blu-Ray player. Wireless...
Hey, Firstly make sure all the plugs and cables have been plugged in (Securely) after this turn the power off by the mains then back on. If this does not sort out the problem take it back to the shop and ask the tech support for advise. :)
Jun 12, 2011 | Video Game Consoles & Games
LG 32 32LK450 32 in. LCD TV Logo
43 people viewed this question
Computer Repairing
Computer Repairing
