Question about Hayward H Series Pool & Spa Heater 400k Btu Propane Gas Milivolt Ignition H400p1
H400 manual h400ped2
Does a h400ped2 2005 is compatible with a salt system? is it in titanium?
I have a 2005 Hayward H400PED2, I want to know if it's a titanium exchanger beause I want to add a salt system?
Thanks
Posted on May 10, 2013
Hi I am trying to down load the manual but keep getting sent in circles where am I going wrong
http://pdf.crse.com/manuals/4533868111.pdf
right click mouse on this above link and select save target or save link .
if Sony Cyber-shot DSC-H400
this comes from the manufacturers support link on their web site
https://www.sony.co.uk/support/en/product/DSC-H400
Dec 07, 2015 | Sony Cyber-shot DSC-H400 Digital Camera
How can I get my Toshiba Sd H400 to find satellite signal?
You have to use some of the special connections on the back to connect the Satellite box. It will not work with those you are trying. See the manual below:
Toshiba SD H400 TU Installation Manual Using Your Sd h400 With Cable Or...
Oct 05, 2017 | Toshiba Sd-h400 Combination...
I have a waterco titanium pool heater water is pouring out of drain holes in the bottom of unit.I have to keep filling up the pool every other day.what do u think is causing the water to puor out like...
in which area do you live, as if the air temp is colder than the pool water it is evapoartion most likely, Test the water coming out of the heater against the water in the pool, if your pool is salt water and the water coming from the heater has no salt then your pool is not leaking, as the heat pump is like an air conditioner it will produce condensate Water from the air. in steamy weather there will be alot of water. David PoolWerx Brisbane
Mar 09, 2013 | Waterco Baker Hydro 80K Btu Titanium...
I do not have my user manual for my intex saltwater system, I bought it and used it last summer. I forget how to set my system and it is beeping like mad right now. I just want to run the filter system to...
Alright I imagine you have it hooked up already if its beeping at you. A couple of things to ensure first. One is a PCV pipe that has a electrical connection going to a T at the top. On that section of PVC pipe there should be an arrow. Ensure that arrow is pointing in the same direction as the stationary PVC pipe that contains the titanium plates. Now Ensure that you r filter pump is Supplying water to your salt water system. So it should be pool to filter pump to salt water system back into the pool. Now in order to program your salt water system you need to lift the screen protector. Press the left (down arrow) until you hear a short beep then press the right button (up arrow) until you hear another short beep. You just unlocked the keys, now you need to set the hours of operation by pressing the up arrow. For 2000gal pool you want to set for 2 hours if it is 68 to 97 degrees out. anything higher run it for 3 hours. For a 4000gal pool you want to run it for 5 hours if its 68-82 degrees. 6 hours from 84-97 degrees and 7 hours if its hotter than that. Once you have the hours set the machine will automatically start (ENSURE THEFILTER PUMP IS ON). You can relock the keypad by press and holding the down arrow button until it beeps then the up arrow button. A green chlorine light should light up within the next 5 minutes, which indicates the saltwater system started the chlorine production.
Jul 24, 2011 | Intex Automatic Salt Water System for ...
Intex salt water chlorinator 56602
First of all 91 is low salt content not too much
Are you checking your salt level with a test strip
You need to be at 3000ppm anything under 2800ppm can trigger an alarm and not produce enough chlorine.
Same thing if you are over 3600ppm
all manuals just give you an amount to start with but it is up to you to fine tune it
After adjustments you need to filter only for 24 hours before trying to generate chlorine
Jun 26, 2010 | Intex Automatic Salt Water System for ...
Low salt alarm on Intex system
so what does the test strip say. Should be as close to 3000ppm as possible anything close and under 2700ppm will trigger a low salt also you must run filter only for 24 hours to thouroughly mix the salt before trying to turn on the generator
Jun 14, 2010 | Intex Automatic Salt Water System for ...
Low salt
Same here, been getting the 91 code, 3 times in last 1 1/2 weeks. Added salt. Came on today, so I checked titanium plates and they were half clogged with white stuff. DO NOT ADD SALT just because 91 code is on, which I have done. . You need to check plates and clean if clogged, with hose and some pressure. I used a plastic wire tie to clean, do not use metal item to clean plates, you'll scratch the plates and ruin them. Mine was clogged on 2 plates full length.
Jul 18, 2009 | Intex Automatic Salt Water System for ...
Pool pump
You may have a hard water problem. Remove and inspect the unit containing the plates. You'll be able to see build-up. I was surprised to see how much it had coated the plates after only a month of use. Cap end and soak with vinegar. Re-install. Check regularly. Also, with the initial salt startup, a 16'x48" requires 120 pounds, the first time your low salt light comes on, the manual says to add 30 more lbs. That's a total of 150 lbs. Speed up the salt dissolving process, mix it up physically and aim the return down into the water, remove the skimmer if you have one so intake and circulation is maximized. Run for 24 hrs. Make sure you have a more than adequate pump with a clean filter. I replaced mine with a larger Intex pump.
Jun 14, 2009 | Intex Automatic Salt Water System for ...
TOSHIBA SD-h400 USER MANUAL
http://akamaipix.crutchfield.com/Manuals/052/052SDH400.PDF
Aug 03, 2008 | Toshiba SD-H400
Hayward H Series Pool & Spa Heater 400k Btu Propane Gas Milivolt Ignition H400p1 Logo
124 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
