Computer booting problem
My computer won't work . It's an HP pavilion a1730n and loved it immensely for school work. Of there's a solution please help . I can't afford a new computer .
    Champion:
  • 237 Answers
On some of these, there is an internal circuit breaker on the power supply. You can try unplugging it, hold the power button down for about 30 seconds, then plugging it back in. That can alow the power supply to reset.
Posted on May 09, 2013
  • 42 Answers
Well, check out if you've properly working computer memory equipments, such as RAM and Hard disk drive. Also, keep your computer free from dust and clean if you found enough amount of dust laying around the CPU. This will make your CPU fan stopped working properly.
Apply these tactics and see if it helps you!!
Posted on Oct 16, 2014
  • 3 Answers
Well you're getting power from the power supply at least so here's one thing you might try. Unplug the computer, pull the coin cell battery out of it's holder on the motherboard, wait awhile and put the battery back in. Plug the computer back in, power up and see if you get a bios screen showing on your monitor. If you can get into the BIOS you can change the boot order to have the computer boot from the CDROM drive and from there you can use diagnostic discs to see what the problem might be. You didn't seem to have any beep codes but a good disc to check your memory is one called MemTest86 that is free to download from the internet if you have another usable computer to do that. You say the fan is running louder so could be a bearing going in the fan but that would not cause your problem. Also check that all connectors are seated properly and make sure the CPU heatsink is still seated properly on the CPU. Reconnect your monitor making sure all connections are good and monitor is turned on. There are Linux live CDs that allow you to boot using the CD to test drive linux to verify that the motherboard is functioning without actually installing linux on your computer and you can check if it's your operating system or hard disk causing problems. Another thought would be to get yourself a DC voltmeter and check the various voltages coming from the power supply to verify they are in spec.
PassMark MemTest86 Memory Diagnostic Tool
Posted on Apr 27, 2014
Hp pavilion 23" all-in-one PC
It would help us immensely if we knew what problem you were having. Simply saying you have a problem does not enable us to help you.
Apr 13, 2013 | HP Pavilion L2335 23" LCD Monitor
Describe your HP Pavilion dv9000z 17" Notebook Laptop PC PC Notebook Problem it won't boot up, it lights up but nothing else
Does it make a beeping sound when you turn it on? If it does try this:
Turn it off and take the battery out for about 2 minutes. Put the battery back in and press the power button to turn on. Immediately tap the F8 key on your keyboard. This will bring you to the advanced boot options. Choose last known good configuration.
If that doesn't work you may also try choosing system restore in the advanced boot options and follow the instructions. Note that a system restore brings the computer setting back to a previous restore point.
I hope this helps.
Cheers,
Sep 04, 2011 | HP Pavilion dv9000z Notebook
My hp pavilion a820n computer will turn on but won't start up
As the computer is starting up keep hitting F8 until you come to the boot options screen. Once in the boot options select "Last Known Good Configuration" and see if it will start. If it still will not start then try and see if the computer will boot in safe mode (Do the F8 thing again until you reach the boot options screen again and click on "Safe Mode").
If it will not load into safe mode then you may need a Windows O/S Reinstall.
Jul 12, 2011 | HP Computers & Internet
WON'T LET ME LOG ON WITH PASSWORD THAT USED TO WORK NOW IT WON;T LET ME LOG IN
You can remove or change the Windows User oradministrator's password. You need access to a computer with Internet access todownload the Hiren's Boot CD and burn it onto a CD. Then insert this CD into the laptop/computer and boot upthe laptop/computer with the Hiren's CD and follow the instructions. There are very useful utilities CD and it a Linux boot CDwhich contains quite a lot of Utility programs including a password removalprogram. Click on one of these links todownload HIREN'S BOOTCD :- http://www.hirensbootcd.net/ http://67.20.82.163/
Jun 24, 2011 | HP Pavilion dv6000z Notebook
My Hp Pavillion a1730n with Vista loaded take about 1/2 half to boot up. What can I do to solve this?
I would run a registry utility to remove the broken links and then run antivirus just in case.
Feb 16, 2011 | HP Pavilion a1730n (RK574AA) PC Desktop
Dvd drive not responding on my pavilion a1730n
Try to use DVD cleaner cd, if it doesnot work, this means the lens is bad, replace it.
Regards
Aug 02, 2009 | HP Pavilion a1730n (RK574AA) PC Desktop
Looking for a replacement power/boot up switch for a hp pavilion a1730n
They are just an intermittent contact switch. Finding the two wires to the motherboard and replacing it with a different intermittent switch from someplace like Radio Shack.
Jul 29, 2009 | HP Pavilion a1730n (RK574AA) PC Desktop
Computers & Internet Logo
4,175 people viewed this question
David Payne
David Payne
