Question about GE Refrigerators
Defrost not working
I recently replaced my defrost heaters because I was getting ice build up on the coils. One of the heaters was broken. when I replaced them, and try to cycle through the defrost cycle manually, they still never heat up. What else could be wrong?
  • GE Master
  • 4,654 Answers
It could be caused by a defective defrost thermostat or a bad connection in the wiring going to the defrost heater. What is your model number? Thanks Sea Breeze
Posted on May 10, 2013
Testimonial: "It is a GE TFX27PFSB WW. Is the termostat the little round part that has 2 wires that attach to the top of the top heater? The new heater assy came with a new thermostat, unless that isn't the thermostat. "
  • John Tripp
    John Tripp May 14, 2013
    I did not get word that you made a comment. Sorry. Yes that is the defrost thermostat. Have you changed the WR9X489 Defrost Control?http://www.repairclinic.com/PartDetail/D...
  • John Tripp
    The defrost control is location 257 in this photo here=> https://www.pcappliancerepair.com/model....
tborn6
  • 700 Answers
SOURCE: Evaporator coil frosted up on Samsung RS267LABP Refrig side
TAKE AND DISCONNECT THE POWER TO TH UNIT AND ON THE VERY BACK THERE IS A CONTROL BOARD THE IS UNDERNEITH A WHITE PLASTIC COVER THAT YOU WILL HAVE TO REMOVE THEN DISCONNECT AND RECONNECT THE WIRES TO THE CONTROL BOARD AND SEE IF THAT DOESTHE TRICK.
Posted on Mar 07, 2009
  • 64 Answers
SOURCE: Need photo of Defrost Switch or Sensor
Unit needs to be cold when you test. it closes at around 20 or 30 degrees F and opens around 55 deg F
Posted on Jul 02, 2009
aasc
  • 1606 Answers
SOURCE: I have a Hotpoint HSS25IFMD WW sise by side
A thermistor is a 2" torpedo looking piece with 2 wires attached to it . The defrost bimetal , a 1" round aluminum piece , snapped onto the coils , with 2 wires , should be replaced when replaceing the heater . This bimetal could be the problem . To test the defrost system , remove the main control board cover . The blue plug with 3 wires to it needs to be connected . Looking at the plug , the wireing will look like this : l l l . Lets call the terminals 1 2 3 . Useing a piece of insulated wire with both ends stripped , insert one end into terminal 2 and the other end into terminal 3 . The heater will come on if both the heater AND bimetal are good . If you put a new heater in and it wont come on , and you do this test , then the bimetal has to be bad . If your terminology is correct , you have 2 thermisters in the freezer . One on top of the coils ( evaporator sensor ) and one at the bottom by the drain pan ( freezer temp sensor ) . Wouldn't hurt to replace both if you replaced one .
Posted on Aug 08, 2009
woodchuck789
  • 4070 Answers
SOURCE: automatic defrost not working, but manual is?
Yes if the heater and defrost thermostat are good then the problem is the control board.
Posted on Sep 04, 2009
hvac1960
  • 2133 Answers
SOURCE: DEFROST CYCLE IN FREEZER NOT WORKING PROPERLY
1. Check defrost timer. 2. Check defrost thermostat. 3. Check defrost heater. One of this are more than one may be defective replace.
First, locate the defrost timer which may hiddenbehind corners of the fridge at the back bottom, in some models located in theceiling of the fresh food section or behind the cold control cover. Once youlocate the defrost timer, slowly turn the screw in the middle of the defrosttimer with straight screwdriver until the fridge shuts off. Now it's indefrost. If the defrost heater(s) starts, replace the defrost timer and defrostthermostat. If the heater(s) does not start, unplug wire cord to check ohm testfor continuity of heater. If continuity is there, plug cord wire which givespower 120volts (check specification) to heater. If heater no starts, bypassdefrost thermostat by join the 2 wires in the defrost thermostat. If the heaternow comes on, replace the defrost timer and defrost thermostat. If the heateritself is bad, replace it. Thanks and hope helpful
Posted on Jan 29, 2011
I have a problem with my s75438dt,the fridge as stopped working
If defrost heaters in freezer stop operating during defrost cycle, ice builds up around coils and blocks cool air from being blown to refrigerator side. If ice you need to defrost with heat and replace heaters. Remove rear freezer wall and look for solid ice covering coils. Also push freezer door switch closed while keeping door open and determine if fan is working.
Feb 06, 2016 | Refrigerators
I have a GE Profile refrigerator model #PFSSPKXBSS and the front control panel gets frozen. The only time I can change the settings is when the display panel goes haywire and starts changing all the...
solenoid for the ice dispenser flopper might get rusted, so the flop door would not close and freezer air would escape building up ice. need new solenoid assy for ice dispenser door and possible flopper.
Mar 27, 2015 | GE Refrigerators
I have a sub zero side by side. The refrig side is at 40 degrees but a 10 inch by 6 inch piece of ice keeps forming on the left size, back wall. What would be the likely cause of the ice build up??
Their are 2 possible things causing the ice build up
1) the condenser coils is very dusty and must be cleaned,to clean it remove the top grill and the smaller panel behind the grill,use a vacuum to clean all the dust from the coil
2) the evaperator coil in the refrig. behind the back wall has a small refregrant(freon) leak in it and the coil needs to be replaced
I hope thats its due to the upper coil needing to be vacuumed since its something you can do at no cost,but even if it doesnt fix the problem the coil needs to be cleaned to help both the freezer and fresh food section work more efficently
if after cleaning the upper (condenser) coil and turning off the fridge to melt is away ice build up from (evaperator)coil,if the ice ball reoccurs the repair could be as much a $1,000.00 to replace the coil and recharge the refrigerant
Jul 29, 2011 | Sub-Zero Refrigerators
Fan not working .water collecting in the fridge and build up of ice in both
The fan may have stopped working due to the build up of ice on the evaporator coil in the freezer. The most likely cause would either be a burnt out defrost heater or a bad defrost timer. Normally the defrost timer turns the heater on for about 30 minutes every 8 hours to melt the ice on the coil. If the timer fails it will either stay in cooling mode or defrost mode. The timer is usually located in the temperature control box in the refrigerator. It looks something like this:
slamfix_55.jpg On the side of the timer is a small cam that you can turn with a flat screwdriver. With the refrigerator plugged in, turn the cam until it clicks. When it clicks, it should be in defrost mode and the heater should start to get warm and melt the ice. You should be able to hear the ice crackling and hissing if the heater is working. If it does nothing then the problem is probally due to a burn out heater.
To get to the heater, you will need to remove the back panel from the freezer and the heater will be attached to the coil. You will need a hair dryer to melt the ice from the coil, to get to the heater. Parts can be found at your local appliance supply house or online at repairclinic.com. Hope this helps you.
Jun 30, 2011 | Frigidaire FRT21H8 Top Freezer...
1965 Frigidaire unit - heavy ice build up on coils
Sound like the defrost thermistat or heater is bad. Regardless if you have ice block on coils defrost thermistat must be replaced. Even if still good it gets damaged. Empty out fridge and let manually defrost for 24 to 48 hours. With doors open and unplugged. Test heater with a meter to see if its still good. Replace defrost thermistat and plug back in.
Jul 10, 2010 | Frigidaire Refrigerators
My refrigerator freezer is running but ice is building up and the refrigerator is warm. Please help
You have a defrost issue, you'll need replace a part.
This depends though, it could be a few things.
A. The defrost timer/board is dead - this does not tell the refrige to go into defrost mode, thus building up ice on the coil
B. The heater has died, thus when the defrost timer/board tells it to come on, it does not, thus causing ice build-up on the coil. The heater, you can OHM out, with a meter, if it has continuity to it, then its good.
To temporarily fix this, you'll need to remove the back panel of the freezer, turn off/unplug the unit, then get a hairdryer, and melt away the ice on the coil, be careful not to melt the plastic of the unit.
Hope this helps!
Mar 29, 2010 | Kenmore Refrigerators
Ice build-up in lower freezer. We replaces the
warm between doors is normal. if hot then clean coils and if coils clean make sure condenser fan motor working thats the fan in the back compartment, however if warm thats good. did the evaporator coil freeze from top to btm is that why u replaced heater. if it was then could be heater,if the coil is only getting frost on half the coil,you could have a sealed system problem. is the evaporator motor working in the frz side if not,then that could be the problem.if coil is froze up it needs to be defrosted. did you defrost coil when you replaced heater,if not try defrosting coils and then wait about 12 hrs and see how it does.
Sep 16, 2009 | Maytag MSD2756G Side by Side Refrigerator
Viking refrigerator with bottom freezer always running
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
Jul 05, 2009 | Viking VCBB363L Bottom Freezer...
Jul 02, 2009 | Viking Professional VCBB363SS Stainless...
My GE fridge is not defrosting the coils in the back. What's up?
if u have frost build up in the freezer it will affect the temperature
and it needs to defrost
problems could be
defrost timer.
thermostat.
terminator.
heater s.
unit problems (unlikely) if even frost coating.
Jun 16, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
52 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
