Question about AOpen AX45-V (91.88I10.004) Motherboard
Motherboard problem hi I have a problem with a 810e mother board.there is no post beep or display only the cpu fan is moving.I found the cpu and ram are ok. I am asking your help. pradip
  • Anonymous Mar 26, 2008
    Help me please!!! my pc doesnt want to boot up to bios...but my CPU fan is running> my p4 motherboard doesnt have any jumpers>>> what can i do?
    thanks.
    Scott
    President:
  • 2,961 Answers
If you have tried resetting the bios by putting the jumper across pins 2-3, then back to pins 1-2 and it still wont boot into the bios and you know the memory is ok, then the bios chip on the motherboard is damaged and may not be easy to replace as the board is quite old.
Posted on Aug 11, 2007
  • andrew pester
    andrew pester Aug 11, 2007
    Sorry the pins to look for a 3 in a row with a jumper across two of them named JBAT 1
SOURCE:
My msi ms - 7352 ver :1.0 won't display but wen i plug the power cable on the power supply the cpu fan and power supply fan spin but wen i turn the pc on it doesn't display
Auto power on the mother board means there was not found RAM or VGA adapter. If you herd Beep tones
follow this link to identify the error
https://forum-en.msi.com/faq/article/bios-beep-codes
if not pls check the power supply 4pin connector correctly plugged .
Also need to check the cpu and post error codes by post diagnostic card to identify the eror.
Oct 24, 2013 | Computers & Internet
NO beep no display.
Hello try to renew the power supply, with one you know is working.
I think the power supply is not giving enough power, or have burned a power rail.
Here is the homepage:
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&keyword=d101ggc
But the mainboard could also be failing itself.
Look also here:
http://www.tomshardware.co.uk/forum/261145-13-perform-steps-posting-boot-video-problems
Good luck
Feb 23, 2013 | Computers & Internet
Hi I am working on a abit A 17 mother board it was taken apart by my nephew. I think I have every thing back togather, but when I turn it on it beeps and shows code 92,well I think thats what the l e d box...
Hi, you can download a manual here:
http://www.abit.com.tw/page/en/motherboard/motherboard_detail.php?pMODEL_NAME=AI7&fMTYPE=Socket 478&pPRODINFO=Manual
The fault could be the cpu, wrong type of ram, a faulty ram module
or a fault in the mainboard.
Check all the settings in the manual and the bios aswell.
Here is a list of beep codes:
Basic Beep Codes for ABIT AWARD BIOS Motherboards
  1. No beep at all - this means your motherboard is dead, either due to a defective or underpowered power supply, poorly seated CPU or RAM, or a dead-on-arrival board
  2. One beep - board is working fine
  3. One long beep then machine shuts down - faulty, improperly installed or missing CPU
  4. 1 short(Beep) System booting is normally
  5. 2 short(Beep) CMOS setting error
  6. 1 long - 1 short(Beep) DRAM ERROR
  7. 1 long - 2 short(Beep) Display card or monitor connected error
  8. 1 long - 3 short(Beep) Keyboard Error
  9. 1 long - 9 short(Beep) ROM Error
  10. Long(Beep) continuous DRAM isn't inserted correctly
  11. Short(Beep) continuous POWER supply has a problem
  12. A two-tone siren, generally caused by overheating or out of specification voltages
  13. Four beeps then machine shuts down. This is because this version of the BIOS will shut down your machine if no fan tachometer signal is detected on the fan header. Make sure you attach a fan to the FAN1 or FAN4 header or clear CMOS to reset to default (no checking).
Sep 07, 2011 | Abit AI7 Motherboard
Cpu fan running but the mother board does not respond
Remove/disconnect everything (Ram, Cables, Power Supply, Battery, Processor, Pci cards, Display cards if there's one, etc.) from the motherboard, and after while, reconnect/put them on the motherboard again. Make sure you correctly installed the Ram and it's working. Also don't forget to connect both the power supply cables (20 pins connector and 4 pins connector) to the board. Now reboot your system, can you hear anything (beeps)? If this doesn't help, your nearest culprit to the problem is Display card. Good luck
May 21, 2010 | MSI K8MM-V Motherboard
No ram beep is ok but there is no display
pls. replace with a new same rating RAM
Apr 06, 2010 | Intel Motherboard
Possible Bad CPU
RAM is more likely than the CPU. It could also possibly be a power supply. What are you getting as far as beeps during the POST?
Dec 19, 2009 | ASUS P5W DH Deluxe Digital Home Series -...
ASUS K8S-MX PC powers up but no display on monitor and no error codes. Hard drives spin and sounds as if it is in boot routine
OPEN UR CPU AND OUT UR RAM FROM MOTHERBOARD AND START UR PC WITHOUT RAM IS IT BEEP OR NOT IF IT BEEP THEN CLEAN UR RAM AND RE INSERT IN MOTHER BOARD AND THEN START UR PC IS IT OK
IF NOT THEN PICOUT BATERY CELL 2032 FROM MOTHER BOARD AND THEN START UR PC
IS IT BEEP WITHOUT RAM AND CELL IF YES THEN CLEAN UR RAM AND RE INSERT IN MOTHER BOARD AND THEN START UR PC
IF IT IS OK THEN CHANGE UR BATTERY WITH NEW ONE
IF UR PC BEEP WITHOUT RAM BUT NO DISPLAY WITH RAM THEN CHANGE UR RAM WITH NEW ONE.
Jul 01, 2009 | ASUS K8S-MX Motherboard
No beep,No Display on my monitor,only CPU heatsink fan is moving
have you thought about changing the battery on the motherboard, also checking that the fan on the cpu is seated properly with enough heatsink paste as both these issues will stop the pc from booting
Oct 29, 2008 | Asrock K7S41GX Motherboard
CPU OR Motherboard
its your motherboard problem if its have a warranty then send it to the asrock service centre if not then repair it
Sep 27, 2008 | Asrock 775VM800 Motherboard
try to clean your video card and ram using the eraser.
Mar 17, 2008 | ASUS P4VP-MX Motherboard
AOpen AX45-V (91.88I10.004) Motherboard Logo
102 people viewed this question
Top AOpen Computers & Internet Experts
Ekse
Gustavo Ortiz
Gustavo Ortiz
Alun Cox
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
