Question about Hardware & Accessories
Ace water timer instructions - Hardware & Accessories
Do I place this at the faucet or after the pressure regulator on drip system?
Generally you put these timers at the hose bib (faucet). In my home, they'd be used for sprinklers or drip irrigation systems that have a limited controls on them. If I put them past the flow restrictor on the soaker hose, the unit would be on the ground and in the water.
I hope this helps.
May 10, 2014 | ACE Water Timer, Electronic - No. 7198476
Are there instructions on line on how to set the ACE 265 timer? If there are, please give me a link. Thank you.
Copy following link for instructions how to set analog timer:
http://waterheatertimer.org/How-to-set-timers.html
Also decide if you want to use timer or use built-in thermostat operation:
http://waterheatertimer.org/Water-heater-recirculation-system.html
Add a comment and describe timer in detail so correct identification can be made
Jul 13, 2013 | Taco 265-1 / 563-2 Combination Analog 24...
Ace digital timer & cord combo pack
Buy another outdoor dawn-dusk timer.
Timers can be damaged by simple power outage, when power resumes there is a surge.
Dec 20, 2011 | Ace Hardware Ace Digital Timer and Cord...
Need instructions on how to set light timer
http://www.amertac.com/content/products.nsf/Lighting%20Controls%20&%20Dimmers/Screw-In%20&%20Plug-In%20Controls/SLC6C/SLC6C%20inst.pdf
May 19, 2009 | Ace Hardware AMERICAN TACK 3236858...
Replacing float switch on water ace r3s pump
I have been in this business for a ong time 34 years by the time ou take the pump apart and find the right peices it would be cheaper to buy a new pump, suggest zoeller submersable pump,,
Mar 17, 2009 | Water ACE SUBMERSIBLE SUMP PUMP 1/3 HP
Hardware & Accessories Logo
75 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
