Question about Corby 4400 Mahogany Trouser Pants Press
How can I bypass a faulty spin dial timer on Corby Classice trouser press?
The product I have actually is a Corby Classic, which they no longer make. It has a spin dial to see how long I want it to run. The dial shuts off prematurely after only a couple minutes, no matter how long I set it for. Is there a way to wire it so that I bypass the timer, and it is constantly on once I plug it in? I plan to plug the device into an external timer switch to use it.
Heating pad is wrinkled so clothes come out wrinkled
I thought my old one was faulty so I bought a new one and still experience the same wrinkling problem!
Dec 22, 2013 | Corby Trouser Press 7700
I have a Corby 7700 pants press that does not press the pants
Here are the instructions for this product:
http://www.corbyofwindsor.com/store/uk/info/292/TrouserPressInstructions
Feb 14, 2013 | Corby Trouser Press 7700
Corby 7700 will not heat up enough to press pants
Here are the operating instructions for this product: http://www.corbyofwindsor.com/store/uk/info/292/TrouserPressInstructions#Operating_Instructions
My HB1116R TIMER STOPS RUNNING ON OFF WORKS FINE thank you in advance if i tap on housing i can hear timer starting for a few seconds
If the timer dial will not push the tripper past the on-off lever, or if dial is no longer rotating, or is rotating slow, then clock motor has gone bad.
There are no replacement clock modules for HB series timers.
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#PB
You can set timer to override and plug HB into another plug-in timer
Intermatic site no longer shows HB series outdoor timers except for HB8800.
http://www.intermatic.com/products/ec%204%20layer/plug%20in%20timers/plug%20in%20timers/plug%20in%20timers.aspx
Amazon still sells HB1116R
Jul 07, 2011 | RTO Intermatic HB1116R Power Stake With...
Timer making noise, but not moving
If timer motor is in operation but the dial not forwarding, yes the timer is faulty. plastic gears in the timer eventually ware..
Jun 09, 2010 | Amana LEA11 Dryer
Dryer spins, no heat, timer does not seem to function
Your timer mechanism is damaged. this will happen if the timer motor is faulty. it will not advance the cycle correctly. replace the timer/control asap. Please rate and have a great weekend:)
Jun 05, 2009 | Hotpoint Dryers
Corby 4400 Mahogany Trouser Pants Press Logo
218 people viewed this question
Top Corby Clothing Experts
treeeee
treeeee
shuyumeng
shuyumeng
Erin Wood
Erin Wood
Are you a Corby Clothing Expert? Answer questions, earn points and help others
