Question about Refrigerators
Hotpoint fridge freezer ffa47x
Display flashing, c can not be used to control anything on temperature/time/date.
SOURCE: temperature adjustment
Answer the question is 1/2 or 4/5 colder?
Posted on Feb 04, 2007
SOURCE: Samsung twin cooling fridge/freezer model
My husband removed the covers inside the fridge which contain the lights and the cooling fan. The problem was the icing up of the cooling fan (which circulates the cold air) preventing it from rotating also the drain hole at the bottom of the fan was also iced up.
The fridge was switched off at the wall socket whilst working on it. After removing the panel containing the fan and unplugging the connection take the panel outside. A hair dryer was used to thaw out the ice. The drain hole was made slightly bigger to hopefully prevent this happening again.
When panel is screwed back in fridge make sure the black sealing tape is in position also take care not to damage cooling pipes which are attached to the evaporator unit. Defrosting a couple of times a year might prevent this happening again. It seems to be a design problem which im sure the makers will be aware of and modify future appliances. Q Will the makers repair this problem free of charge even if the warranty has expired !?
Posted on Aug 01, 2008
  • 139 Answers
SOURCE: my fridge freezer Hotpoint Mistral
E8- Evaporator thermistor short circuit
Well this is a sensor,, found in the freezer compartment of the f/f
what you have to do is reove the draws fro mthe freezer and you will c a panel which has 6 screws., remove the panel and and you will c a fan, toward the right of the fan you will c a yellow plug with a bit of wire on it,
This is what you have to replace
try connect distributions you can find them on the net if your in the uk that is
hope this helps
cheers
washdoctor
Posted on Aug 25, 2008
SOURCE: fridge tempertature
I have the same symptom too - freezer temperature flashes at -2. "Power Freezer" or setting it to any other temperature is not working either.
As a result, no ice being made. Please help!
Posted on Sep 01, 2008
SOURCE: Hotpoint Mistral Frost Free Fridge freezer - fridge not getting cold
We have just had to call out an engineer to get our 1 1/2 year old Hotpoint Graphite Frost Free Fridge Freezer repaired. The fridge had almost entitely stopped cooling even when on high. I was amazed at how easily the problem was sorted. The engineer removed all the basktes from the freezer to access the screws on the inside backpanel of the freezer. Once this panel was removed it was clear that the so called Frost Free doesn't really mean what it says. The ice need to be melted with a bit of simple care. It is obvious that with a bit of care it is easliy a diy job BUT PLEASE BE CAREFUL AND READ THE NEXT PART BEFORE YOU BEGIN TO REMOVE THE ICE> The ice forms around variouys pipes etc and he usecd a screwdriver to help release the ice quicker than waiting for it to defrost and he also used a simple hairdryer to help speed up the process. He had a ntowel and a basin to take care of the water. Next time I would have no problem doing this myself but I would need to leave it a little while to defrost and NOT USE A SCREWDRIVER as I am sure somehow I would puncture a pipe or the wall of the freezer itself and I am quite used to doing the odd bit of DIY. On a difficulkty scale of 1 to 10 with 10 being difficult I would rate the job as about a 3. Hope this helps anyone who reads this about £70.
Posted on Dec 27, 2008
I have a hotpoint FF72P fridge freezer. it comes down to temperature (-22/+4) without any problem, but after this the compressor won't cut in.
takes time for the temperature inside the fridge -freezer to normalize after doors are being left open
turning off a fridge freezer on and off wont help it
it takes time to for the thermostat to kick start the compressor
and more time to reach the freezing temp lost
if you are certain the thermostat is damaged
call in a service man
have the thermostat replaced and have them check
the gas in the system is running the correct pressure
Jul 31, 2016 | Hotpoint Refrigerators
Fridge freezer FFA47X DISPLAY OFF WONT TURN ON
I take it the fridge/freezer is working but no display. On the door that the display is not working take a look at the top hinge it will have a cover on it ( normally with a + screw in it ) take this cover off . you will see cables going into a plug and socket . Make sure this is nice and tight
Jan 23, 2015 | Refrigerators
Ffa47x fridge not cooling freezer overfreezing
there is a little air passage that allows the cold air form the freezer to cool the refrigerator is blocked or jammed closed check that first then you can get back to me
Dec 30, 2011 | Hotpoint Refrigerators
I can not find the freezer temperature control
this model refrig does not have a seperate freezer control. the only control will be the refrig control. thanks peyton
Feb 26, 2009 | Hotpoint Refrigerators
Red light on Hotpoint Iced Diamond freezer
got a hot point iced diamond fridge/freezer, just got back off hols and red light on, all food defrosted with water running out of bottom. whats wrong?
Aug 27, 2008 | Refrigerators
FFA45W
Hotpoint FFA47X fridge/freezer. I have had this fridge for 3 years now and has always on regular occasions decided to defrost when it feels like it and asks me to consume all the food immediately! I have wasted massive amounts of money on food and calls to hotpoint and have had a hotpoint engineer out to sort the problem about a year ago. It goes fine for a few months..then it defrosts all over again! Its just done it again, luckily I am not using the freezer anymore it only had some peas in there. Has anyone had this problem and solved it?? I would really like to use my freezer again but am loosing patience with hotpoint! I'd be very grateful for some advice.
May 11, 2008 | Hotpoint FFA60 Bottom Freezer Refrigerator
Food is defrosting in my hotpoint frost free fridge/freezer
Can you hear the compressor running? Is the fan inside the freezer running? It could be that a wire connection has come loose during the move. Was the fridge laid on it's side during the move? If so you probably have compressor oil restricting the refrigerant system. If compressor and fan are running you will probably need a qualified refrigeration tech to check it out.
Oct 03, 2007 | Hotpoint FFA60 Bottom Freezer Refrigerator
Hotpoint FFL49X Fridge compartment
GE Hotpoint has a history of bad fans and poor customer service. Unfortunate and a costly defect. Repair this yearly, forever or trash and buy new???
Aug 14, 2007 | Hotpoint FFA90 Bottom Freezer Refrigerator
Freezer not working
there is a defrost fault - quite common with these hotpoint. fault could lie with the module or stats associated with defrost or possibly the heater itself. most probable is the module but impossible to localize by remote control. water drains away thro a hole in the centre of the tray underneath the evaporator
Jun 21, 2007 | Hotpoint FFA60 Bottom Freezer Refrigerator
Refrigerators Logo
137 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
