Question about Husqvarna Backpack Leaf Blower 350 Bt Yard Blower With Warranty Husky 350
Husqvarna Repair Manual
Does not want to run it will start but it is hard to pull the cord what do I need to do?
  • Husqvarna Master
  • 1,807 Answers
Have you used the correct fuel and oil mixture.?
If its new and still under warranty then take it back to your local dealer.
Here's the parts manual
Posted on May 09, 2013
Ignition timing set
The flywheels are keyed on the Husqvarna chainsaws, there is not way to change the timing. I would suspect you may have some carbon build up causing the hard start. Is the saw hard to pull over with plug removed?
May 04, 2014 | Husqvarna Garden
Saw starter pulling too hard to start.
Check piston rings. Sounds like you have a seized engine.
Feb 20, 2013 | Husqvarna Chain Saw Models 51, 55
Husqvarna hedge trimmer hard to pull cord
check the piston inside the cylinder for extreme wear. If it feels sticky and is hard to pull it sounds like a lack of oil in the cylinder and it has started to seize.
Jan 02, 2013 | Husqvarna 28cc Gas Line Trimmer
My husqvarna 288 wont start, has extreme high compresion and cant pull cord with the spark plug in it. easy to pull with spark plug removed
http://www.ebay.com/itm/HUSQVARNA-288-CARB-REBUILD-KIT-COMPLETE-TILLOTSON-NEW-/140290773535 Your carb.may need rebuilt,remove and inspect,did you leave gas in it while it was stored,if so then carb is suspect.About 80.00 for a shop to repair,14.00 for you to do it.
Oct 10, 2012 | Husqvarna Garden
Husqvarna 325L x-series pull cord repair.
From my experience, the trick is to pull the cord all the way out, then attach the pull assembly to the engine, and let the pull rope win back in place. hope that helps.
Aug 28, 2012 | Cars & Trucks
Pull cord pulls hard won't start
Remove the top engine flywheel & pull cord cover
Most likely dirty,as well as worn out. or the cord
is in the wrong place,you will see that,once apart
You can work on it some & down the road
get a new one if you have to
Jun 11, 2012 | Husqvarna 6021P 21-Inch 149cc Kohler XT-6...
How to start a Husqvarna 445?
Set choke to full on. To do this depress throttle all the way down and set choke lever to on. Pull starter rapidly until saw fires . Once it has fired set to start and pull starter cord until it starts. If it doesn't start in ten - twelve pulls,reset choke for two or three pulls,then switch back to start. Pull starter cord until it starts. When it starts it wii be at full R.P.Ms. Let run for twenty to thirty seconds. then move switch to run. Hope his helps, Thanks
Nov 18, 2010 | Husqvarna 16" Chainsaw Chain Saw Bar...
What are the steps to start my husqvarna 125b handheld gas blower
Put fresh gas/oil mix (if it is a 2 cycle) in the tank.
Put the choke on. Push the primer bulb 3-6 times. Pull the cord until the engine sputters. Put the chock to 1/2 way, pull cord again. Should start and run a bit with choke set there, then in about 10 seconds, put the choke completely off.
http://www.mylawnmowerforum.com/forum/
Aug 09, 2010 | Husqvarna Garden
Rope hard to pull, engine spins freely with plug removed
First off Husqvarna does not make Craftsman chainsaws. Chainsaws are very high compression usually 125 to 150 lbs. pulling the rope slowly will make it very hard to pull. Short fast pulls are best, this allow the flywheel to build momentum to get it past the compression portion of the piston trvavel.
Jan 15, 2010 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
Husqvarna 51 from 1991 too much resistance to starting attempts
It sounds like it's sorta gummed up from old gas residue. You could spray carb cleaner in the spark plug hole and into the carb while holding the throttle open and pull the cord several times and then follow that with penetrating oil to re-lubricate the engine. You're probably going to have problems with the carb also. I would have it rebuilt or, better yet, purchase a new one
Jul 01, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Husqvarna Backpack Leaf Blower 350 Bt Yard Blower With Warranty Husky 350 Logo
145 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
