Question about Fellowes Saturn 2 125 Laminator - 5727701
Laminator won't feed through. Any reason why?
It's warmed up and the light has stopped blinking and is steady which means it's supposed to be ready to go.
My gbc creative laminator won't heat up
We have an Ulitma 65 and it won't heat up...Any suggestions on how to fix this? We are at a school and no $ to replace the whole unit. Thanks in advance.
Mar 29, 2013 | Office Equipment & Supplies
GBC Pinnacle 27 won't come on
each heat shoe has a small thermal fuse, if either fuse is blown, the laminator keypanel will not operate. 99% fix everytime, just follow the wires from each heat shoe (right side of laminator) cover off. Ohm each set of wires and look for an open circuit. replace fuse (TCO) and it will work everytime.
Feb 20, 2013 | Gbc ® Pinnacle 27 Two-Heat Roll Laminator,...
The green light on my prince lionheart warmer won't stop blinking
I realize the original question is 2 1/2 years old but for future answer searchers... the flashing light means your power cord is no longer working.
Jan 18, 2013 | Prince Lionheart Premium Wipe Warmer
My laminator won't stop heating
so what model are you having troubles with
Aug 30, 2012 | Gbc HeatSeal H425 Laminator
Blinking/flashing lights(orange & green) & won;t pring. Have rebooted computer and unpluged printer. still won't print.
that is because ur head of ur printing cartridge is damaged.
remove ur cartridges black as well as color
n install only black cartridge n check d blinking of lights on ur printer if it doesn't blinks it's mean ur black cartridge is OK but ur blinking of light on ur printer is same it's mean ur head of black cartridge is damaged
after this process remove the black one cartridge and install the color one cartridge n check d blinking of lights on ur printer if it doesn't blinks it's mean ur color cartridge is OK but ur blinking of light on ur printer is same it's mean ur head of color cartridge is damaged
now take a dry cotton cloth n gently clean ur cartridges head install both cartridges on ur printer n check ur blinking light on ur printer that will work only if u r too lucky other wise u have to purchase a one cartridge.
May 29, 2011 | HP DeskJet 5550 InkJet Printer
I just purchased my playstation 3. I can't get the Sony dualshock 3 to work. When I plug it in all the lights on the back are blinking but the controller won't to anything
after you plug in the controller, wait till the light under the 1 becomes steady and all other lights stop blinking. once that has happened your controller should be synced with your console. if this does not happen after waiting several minutes, then you have a faulty controller and i suggest to turn it back in. please rate my solution, good or bad.
May 21, 2011 | Sony Dual Shock 3 Controller for...
I have a Lamiart-3201 laminator and the rollers are not working - or i cannot feed my item through the laminator. Usually I just put it in and the laminator feeds it out the other end...
Make sure your laminator is heated up properly before feeding material through. Usually, for a low-end laminator, you will wait anywhere between 10 to 20 minutes before it is completely heated up, allowing you to use it. There should be a red button that will tell you it is NOT ready yet, and a green button will tell you it is.
Nov 16, 2010 | Office Equipment & Supplies
I have a D-Link DIR-615, and the laptop says the Signal is Excellent, but it won't connect and it says Limited or no connectivity. Is the wireless symbol supposed to be steady on the router or is it...
You have not configured the DHCP or manually allotted IP address to the system or possibly a wrong IP address. This is the reason for limited connectivity.
The light blinks when it scans for the wireless devices nearby and as well as for data transfer.
Oct 14, 2009 | D-Link DIR-615 Wireless Router
Paper feed problem, then error
SEPARATION ROLLER MAY NOT INGAGE CAUSING THE PAPER NOT TO FEED TO THE FEED ROLLERS THE PAPER DOES NT ADVANCETO THE REGISTION ROLLER THAT SET THE PAPER FO COPY CHECK TO SEE IF THEY ARE CLEAN OR WORN
Dec 07, 2007 | Konica Minolta magicolor 2400 Laser...
Fellowes Saturn 2 125 Laminator - 5727701 Logo
73 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Jim Keysor
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
