Question about HP Officejet 5610 All-In-One InkJet Printer
Printer paper loader troubleshooting
My printer which hasn't been used in several months, keeps teeling me that the paper tray is out of paper, even though I have just filled the in-tray..
    New Friend:
Try reinstalling your printer Once installed , you can keep up to date with the automatic updates of drivers
Posted on May 08, 2013
Inkworks
  • 87 Answers
SOURCE: Keep getting "out of paper" error message
Unfortunately this printer and alot of others like it have a very poor paper feed mechanism. I am finding that the (1) small pickup roller that is used in this and other machines like it is failing (not picking paper) prematurely or faster than i think it should (this is looking at page counts on some of these machines). We have been disassembling them and rubber restoring the pickup roller which fixes the paper jam/paper out errors.
Inkworks
Posted on May 21, 2008
Nikhil Gedam
  • 87 Answers
SOURCE: Printing problem with HP Laserjet P2015 printer
This can be an issue with one of the faulty sensor across the printer.
Please check if you are able to print from tray 1, e.g. a configuration page.
A config page can be printed by holding the Green Button and releasing it as soon as the Triangle light comes on. This would take approx 5 secs.
If the printer is able to print from tray 1, then it could be an issue with the tray 2 pickup sensor.
Check if the tray 2 pickup sensor ( a black plastic piece to the right of the tray 2 pickup roller) is moving freely (front and back), also check if tray 2 pickup roller is not able to rotate completely.
If the tray 2 sensor is not moving freely and of the pickup roller is rotating completely, then reseat the pickup roller.
Normal use with good media causes wear resulting in the need to periodically clean or replace the pickup roller. Additionally, the use of poor media might require more frequent replacement of the pickup roller. Replacing the pickup roller Complete the following to replace the pickup roller:
CAUTION: Failure to complete this procedure might damage the printer. Unplug the power cord from the printer, and allow the printer to cool.
Figure 1: Unplugging the power cord
mma01_13245_0
2. Open the print cartridge door, and remove the print cartridge.
Figure 2: Removing the print cartridge
mma01_13246_0
3. Remove the main input tray (Tray 2).
Figure 3: Removing the main input tray (tray 2)
mma01_13247_0
4. Open the front automatic two-sided path door (HP LaserJet 1320 series printer only).
Figure 4: Opening automatic two-sided path door
mma01_13248_0
5.Place the printer on the work surface with the front of the printer facing up.
Figure 5: Placement of printer
mma01_13249_0
6. Pull the white tabs outward, and rotate the tabs up.
Figure 6: White tabs
mma01_13250_0
7. Slide the right tab to the right, and leave the tab in this position throughout the procedure.
Figure 7: Right tab movement
mma01_13251_0
8. Slide the pickup roller assembly to the right, and remove the left end cap.
Figure 8: Pickup roller assembly movement
mma01_13252_0
9. Remove the pickup roller.
Figure 9: Pickup roller
mma01_13253_0
10. Insert the left side of the new pickup roller into the left slot (1), and insert the right side (with notches in the shaft) into the right slot (2).
mma01_13254_0
11. Rotate the shaft until the notches engage and the shaft clicks into place. 12.Place the end cap over the shaft on the left side, push the end cap to the right, and rotate the tab downward into position.
Figure 11: Pickup roller end cap
mma01_13255_0
13.Push the right tab to the left, and rotate the tab downward into position. 14.Place the printer on the work surface with the top of the printer facing up. 15.Close the front automatic two-sided path door.
Figure 12: Closed automatic two-sided path door
mma01_13256_0
16.Reinstall the print cartridge, and close the print cartridge door.
Figure 13: Print cartridge
mma01_13257_0
17.Plug the printer in to turn it back on.
Figure 14: Power cord in
mma01_13258_0
Cleaning the pickup roller
Perform the following to clean the pickup roller.
1.Remove the pickup roller as described in steps 1 through 9 of Replacing the pickup roller above.
2. Dab a lint-free cloth in water, and scrub the roller.
mma01_13259_0
Figure 15: Scrubbing the roller
3. Using a dry, lint-free cloth, wipe the pickup roller to remove loosened dirt. Figure 16: Wiping the pickup roller
mma01_13260_0
4. Allow the pickup roller to dry completely before you reinstall it in the printer (see steps 10 through 17 of Section with a task ).
mma01_13261_0
Figure 17: Reinstalling the pickup roller
Posted on Nov 03, 2008
getbharti
  • 33 Answers
SOURCE: Printing Photos on Photo Paper
Ensure u are placing the paper in the photo tray..
if u r printing from the memory card which is inserted in the printer..ensure that the PHOTO BUTTON on the printer is on..
You can also try to reset the printer by going to the SETTINGS/TOOLS menu (RENCH SYMBOL) and then look for the Factory Restore (Might be under "Preferences")
Posted on Nov 28, 2008
SOURCE: HP D7160 Photo Smart
error:0xc18a0205 d7160
Posted on Jan 26, 2009
SOURCE: HP Officejet 7410 AIO keeps saying out of paper when plenty of paper loaded
I have the same unit. There are many issues with it. First when you install the software you may need to add something to the registry.
HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Control\Print\Printers\HP Officejet 7400 series\PrinterDriverData and create Key HPDJEnableSecondTray as DWORD with Value of 1
Once you've done this here is the biggest issue and one I've found to fix this issue PERIOD.
You need to go to your Printer Driver then to Properties of it then Device Settings Tab - you will see Form to Tray Assignment in the list and like 5 options, you have to make all but the one you want to NOT AVAILABLE. Example mine is set to Upper than Lower (Letter) all the rest are set to NOT AVAILABLE. Problem solved.
Posted on Apr 15, 2009
Paper jam
Here is some tips to avoid paper jam..
  • If your printer has a paper tray do not fill the tray to capacity. If you're encountering frequent paper jams, reduce the amount of paper you place in the tray each time it is filled.
  • Make sure you or the tray feeding the paper into the printer is aligned properly and the slider used to hold the paper in place in the tray is snug with the paper. Many printers have sliders that allow different types and sizes of paper to be fed into the printer. If the slider is not properly positioned it can cause paper jams.
  • Use standard office paper; folded paper, paper with labels, and specialty paper such as hard bound paper can often cause paper jams. If you're uncertain with what paper you should use with your printer your printer documentation will list the paper compatible with your printer.
  • Do not mix the paper you're feeding into the printer at one time. If you need to change the paper or size of paper being used removed any other paper currently in the printer before inserting the new paper.
  • If your printer uses a slot or tray for the paper make sure to not push the paper too far into the slot or tray.
  • Examine the printer for any previous stuck paper in the printer. Previous paper jams, torn paper, printing labels or other foreign objects in the printer can cause reoccurring printer jams.
**If you need any kind of technical assistance you can contact support cell at here
Jan 24, 2013 | HP Deskjet 3050A J611G Inkjet Multifunct
How to fix this error in printer hp p2055dn ''manual feed press ok for available media into tray 1
Go to menu, in tray tray behaving tray1 select as unless paper load,in tray2 page size as any size.. while giving print command select printer properties, goto paper/quality select paper source automatic or tray2 & shoot print command & check...
# if you are not selected tray 1 as unless paper load, it will ask paper to load after command reached to it.
# if you are not selected tray2 as any paper size, defined paper size only it will allow to print..any paper size it will print with out questing you..
Aug 01, 2012 | HP LaserJet P2055d Printer
I'm getting an error code 60.02 on a HP 4014N printer. How do I troubleshoot the problem
An error has occurred while the product was attempting to lift the tray designated by XX. Pull out tray 2 and remove most of the paper. Push the tray into the printer and listen for the lift motor and watch the paper level tab in the front of the tray. If you don't hear the motor and the tab doesn't move, it's possible the printer has a bad lift motor. Remove all the tray 2 paper and look for any paper scraps in the tray. Reinsert the paper and listen for the motor and watch the tab. If it works, great, if not call a tech.
Aug 05, 2011 | Office Equipment & Supplies
Hp officejet 8500 premier printer has paper jam alarm,also I don't see paper being picked up from input tray at all
Hi........................
Please click here for solution :-
I hope this solution will helpful for you
Please don't forget to click on Four thumbs which are given below & then write testimonial for my appreciation if it is helpful
THANKS & Keep Using fixya
Jul 28, 2011 | HP 8500 Premier All-In-One InkJet Printer
My Dell 1110 laser jet printer begins to pick up a sheet of paper, but then stops just as the paper turns up with the roller. This will happen several times before the printer actually picks up the...
85% of paper jams are caused by worn rollers . The rubber treads in the rollers wears down, making them smooth, so they won't pick up the paper. Sometimes, they are aged, which also gives them a smoother rounded texture, causing jams. The quick fix is to liven up that roller with a mixture of alcohol and soap. Damp a rag with the solution and wipe the rollers clean with it. That's make them more pliable and the paper jams will cease. If you plan to keep your printer,
Replace the pick-up and feed rollers.
Metal Tab Separation- Pull out your paper tray and examine either end where the paper sits in. If any of the corners are held down by metal tabs, this is your paper feed system. Chances are, you only have one rubber roller or one set of rollers arranged along side of each other. Reach in where the tray goes and feel up. You should feel some rollers. They might be completely round, or they might be shaped like a half moon. Clean whichever part of them you can with the solution, and this should stop your paper jams. It might be necessary to turn them, but don't force them if they don't move freely.
Pickup Roller and Separation Pad-
If your printer uses this paper feed system, you should see a small piece of flat or slightly curved rubber or cork. It would be towards the end of the paper tray, or deep inside the paper loading cavity on top loaders. This 'separation pad' rubs against the paper feed roller, so if you find the pad, you've found the roller. Clean it and your jams should stop.
Three Roller Paper Separation System- Pull your paper tray out, and look for a roller on either end of it. If you find one, clean it. Then look inside the printer where that roller would rest with the paper tray inserted. You'll find another paper roller there. Clean this one also. Finally, look further back or closer to the front of your printer (depending on which way your paper feeds) to find another roller or set of rollers. Clean all of these, and your paper jams will go away.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Jun 20, 2011 | Dell 1110 Laser Printer
Paper keeps jamming. we get a partially printed page,then jams about 2/3 of the way and we have to pull it out.
You can avoid most paper jams by correctly loadingpaper and other media in the printer. Tips on how to help prevent paper jams · Do not loadwrinkled, creased, or damp paper. · Make sure thepaper is not buckled in the tray. · Never mixpaper/media types within a single tray. · Flex, fan, andstraighten paper before you load it. · Do not exceed themaximum stack height. · Push all papertrays firmly into the printer after loading them. · Make sure theguides in the trays are positioned snugly against the paper. · Do not remove anypaper trays while a job is printing. Wait for a Load Paper light sequencebefore you remove the tray. See the 'Load Media' section on page 61 of theUser's Guide for more information. · Use onlyrecommended paper. Consult the CardStock & Label Guide on the Lexmark web site for more information aboutwhich paper provides optimum results for your printing environment. For additional assistance, please contact LexmarkTechnical Support.
May 31, 2011 | Lexmark E232 Laser Printer
I wanted to print a form from the internet The printer said The rear loader is empty I only use front loader and it is full I did not ask it to change to rear loader I want to use the front tray as I...
It could be several issues - although commonly when a printer moves from it's default tray it's due to a paper size conflict. The form you are trying to print may be a legal size form (8.5x14) or a a non US standard such as A3. Regardless, if the size is different than what's loaded in your main paper tray it will move to the secondary tray or to the MPF (Manual Paper Feed) tray looking for the appropriate size.
If you don't have the appropriate paper, you should be able to enter your printer properties and adjust the settings to scale the document to fit to page.
May 02, 2011 | Canon PIXMA MP620 All-In-One InkJet...
ESP5200printer,new,paper jam message
Hi slicknick58,
Paper jam message occurs when there are stuck papers inside the printer. There are several ways on how to correct this problem, either you remove the visible stuck paper manually or replace the toner or ink cartridge. Below are the steps you'll want to follow when this problem still occurs.
1. Turn off the printer. Turn the printer off and on to see if it can automatically clear some or all of the jam.
2. Inspect the location or tray the printed paper ejects to. If the stuck paper is visible manually remove it. Remove any paper trays. Inspect them for wrinkled or damaged paper.
3. Open the printer door that allows you access to the printer ink cartridges or toner and look for any stuck paper. If the stuck paper is visible manually remove it.
4. If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
5. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
6. If the paper does tear, try rotating the roller gears manually to free the paper . Don't force anything.
7. Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
8. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path and try repeating the above steps again.
Hope it helps.
Thank you for using FixYa.
Apr 20, 2011 | Kodak ESP 5 Printer
It keeps saying that there is no paper in the machine--but there is paper there --it is only about 6 months old--it was working and then said there is no paper
Just saw one of these the other day. If you navigate the menu you will get to a place where you can adjust what tray the printer is trying to grab paper from. We could troubleshoot this easier: make sure you fill both the cartridge under the print output tray and the paper tray on the back of the printer.
Feb 28, 2011 | Canon MP560 All-In-One InkJet Printer
HP Officejet 5610 All-In-One InkJet Printer Logo
174 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
