Proscan PLCD3271A-B I have local channel only with a RCA digitional antenna. I can only view one channel.
SOURCE: RCA HDTV, indoor antenna and Dish Receiver 311
I want to use two (2) 311 dish receivers with only 1 outside antenna.
Posted on Jan 24, 2009
  • 362 Answers
SOURCE: Basic broadcast channel plan vs. indoor digital antenna
Hi masaki h,
I am happy to help.
It is almost impossible to tell how well an antenna will work . It depends on atmospheric conditions, distance to the broadcast tower and a number of other factors.
The new flat antennas look nice and should work fine but your best course of action is to buy from a store with a liberal return policy. Places like Walmart will take the antenna back for any reason as long as you have an reciept.
Somtimes a cheap set of rabbit ears work as well as a expensive amplfied antenna.
I say give it a try and if not acceptable return it and try another one. I have provided a link to a site that will explain more about DTV and antennas. http://www.antennaweb.org/aw/welcome.aspx
Please rate this solution and please keep in mind that any rating except FixYa is a negative to my rank here
Thanks Lone99star
Posted on Jan 28, 2009
  • 90 Answers
SOURCE: Using an over the air antenna I get all channels but one.
I experience the same thing on a day to day basis. The key, is location of the antenna. Depending on where your antenna is located, determines if u can recieve local CBS analog v. digitial. I actually tried sticking aluminum foil to my old rabbit ear antenna legs. to my surprise, I even picked up digital channel I never knew existed. Besides, when the signal transmit in Digital, u are already prepared. Your local CBS afilliate station will be accesable on maybe 2 or 3 channels. example:
Channel 10 analog
Channel 10-1, 10-2, 10-3 digital HD will all broadcast the same programming.
hope this helps u out.
Posted on Jan 31, 2009
SOURCE: Local TV channels drop out after a few minutes
We're still hanging on by our toenails waiting for a helpful response from FixYa. We did contact Philips tech support and they basically said that we need a new TV...so they're sending one to replace this one, and we are sending back the "old" one (that we just bought in December '08).
Posted on Apr 10, 2009
  • 1779 Answers
SOURCE: Vizio VA26L - Tuner problem. After approx. 6
Take the set and reprogram it where one of the other sets are ok. Digital signal is not so forgiving as analog, also place one of the sets that is receiving that station in place of the not receiving one. It's possible that the signal level at the bad spot is on the border line and that model can't hold on to it. You may also check visio's web site for any software up grade to your model that you may have to down load.
Posted on Nov 27, 2009
I hooked up my new Proscan TV to the antenna but it can't find any channels
You need to check the connection is tight from the antenna and also on the back of the tv. You may need to try another coaxial cable. Is your antenna powered, meaning does it have a power plug that needs to be plugged in? Is your tv an old crt television? You may need a converter box to be able to view digital channels. A signal booster may help you get more channels.
Your tv or antenna may be defective. You could try your antenna on another tv. If your other tv gets a signal, your tv's tuner could be bad. If the other tv goes not get a signal either your antenna could be bad. I hope this helps narrow down your problem.
Oct 22, 2016 | Proscan Televison & Video
Step by Step instructions on How to run set up for my RCA flat panel antenna to pick up local tv channels
connect your antena first then go to setup on the tv and selct channel search it will scan and find all the channels that you can pick up with your antenna
Aug 25, 2014 | RCA Digital Flat Panel Antenna
Proscan tv problems
Yes. You should connect the TV with an external antenna, and should do an auto-scan, to search and store all the available channels. Refer its user manual for details.
Jan 28, 2014 | Televison & Video
I just purchased an indoor antenna for to view local stations. Can i use an indoor antenna for my olevia 232-t11 lcd-hdtv? If I can, what steps do I need to follow?
Yes you can use an indoor antenna. Just make sure it is an HD antenna to get the digital channels clearly. You will have to do a scan to pick up local channels. In the TV menu, it will ask you if you want to scan for "cable" channels or "antenna" channels. You want to choose antenna.
Feb 11, 2013 | Olevia LT42HVi 42 in. LCD Television
Have a 32 inch proscan flat screen but dont have a remote
These are setup codes for Proscan TV: 0031 0107 0015 0000 0162 0163
Nov 28, 2012 | Televison & Video
Hello, I am currently having a problem with my Audiosonic KM0767 Standard Definition Set Top Box. When we first bought it we wired up all the plugs and it worked great. We then moved onto Foxtel...
did you switch the TV's incoming signal to digital antenna? For the cable box it was probably set to cable antenna or analog inputs, not all TV's have automatic switching for antenna feeds. My Mitsubishi has 1 digital and 1 analog antenna input and the cable box will only work through the antenna input if it's the analog antenna input and it's tuned to channel 3 or 4, -(or through a seprate HDMI, PROSCAN, SVCR,or a yellow RCA plug input)- and when the analog antenna input is selected the TV will tune all analog cable channels that the cable service offers if a box is not used. likewise the TV will not tune any channels at all if it's set to digital antenna inputs. It will tune all local channels only when set to digital antenna inputs.
Dec 26, 2010 | Televison & Video
My proscan 32LB30QD won't power up. It worked
try this first:
Setup and Connection
The TV won't turn on Check your power cable connection.
• t can't view the Basic channels. Check the connection of the antenna cable
• t want to view cable channels. Register with your local cable company then connect their receiver to your TV.
• t want to view satellite channels. Setup your Satellite parabola antenna then connect your satellite receiver to the TV.
• Digital broadcasting is not functioning Check your antenna cable connection. Check if the digital channel selection is correctly
connected to your antenna cable.
Jun 15, 2010 | Proscan 32LB30QD 32 in. LCD TV
Digital programming for rca j26L637 I can only get the local channels in digital, how can I get the rest (ie cable channels)
I have a similar tv. Its specs. aren't clear about that point. It can get OTA digital via antenna, but my component connectors show no picture when hooked up. I guess if your cable co. sends digital signal it should work in the digital antenna input. Same one as for the OTA signals, and they claim no cable box is required.
I am awaiting any help and it may also apply to your situation.
Take care, breezelow
Jan 20, 2009 | RCA 27F650T 27" TV
Digital hook up
No, you will need an ATSC tuner box that will receive digital signals from the antenna and convert them to channel 3 or 4, and put the video and audio out on RCA plugs - yellow, red, and white.
tom
Apr 12, 2008 | Proscan PS27108 TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
