Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Mower want start and rear wheels locked - Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
  • Craftsman Master
  • 2,760 Answers
I don't know what your level of mech knowlwege is for this engine , but the rear won't move because the engine wont run, it's designed that way on purpose , you'll need to do some basic troubleshooting of engine to maybe get it going again , Does it turn over ? does it have spark at plug? is it getting fuel? answer these and you'll have a better understanding of whats not making it run and know where to go from there
Posted on Apr 04, 2014
How do I fix a rear wheel that's locking up on my Toro zero turn mower?
Replace axle or check to make sure everything is still good and greased
Jul 24, 2014 | Toro TimeCutter SS4260 - 22HP 42 Zero Turn...
Brought riding mower into the garage thru a side door,after that back wheels locked up would not start after that ?
try bringing it in the front door but I don't think that will fix the problem. if the wheels are locked up there is a safety switch that will not let it start if the trans is in gear
May 26, 2014 | Garden
Honda hrr2163tda rear drive problems
remove the rear whheels and check the drive lugs on the axles to see if broken or just rusted or stuck down
Feb 21, 2013 | Garden
Front wheels on manual mower lock when pushing for awhile.
1 Locate the height adjustment lever on the inside of the left rear wheel.
2 Kneel next to the mower and push the left height adjustment lever toward the center of the mower. This will unlock the lever from the locking pin on which the height is currently set.
Read more: How do I Adjust the Height on a Great States Reel Mower? ' eHow.com http://www.ehow.com/how_6834215_do-great-states-reel-mower_.html#ixzz21NOr1e8d
3Rotate the lever toward the front of the mower to lower the height of cut, or toward the rear of the mower to raise the height of cut.
4 Release the lever over the locking pin closest to the desired height of cut.
5 Repeat these steps with the adjustment lever on the right-side rear wheel. Be sure to set the right wheel lever to the same position as the left-side wheel's lever for an even cut.
Jul 22, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman mower #247.887760 rear drive. rear wheels lock-up when you try to pull mower backwards
The rear wheels are locked to the drive train. To pull or push the mower, you must pull out the release probably at the back of the mower, near the transmission.
Gary
Jul 10, 2011 | Craftsman Garden
Lawn mower will start, but won't move????
If you have had either of the rear wheels off, remove the cover from the center and observe the shaft with the engine running and transmission in gear. If the shaft is turning, you have lost the 1/4 inch key that locks the axle to the wheel to make it go
Sep 11, 2009 | Garden
I have an 80's model 10HP rear engine Snapper riding mower that acts as if the rear wheels are locked together. The mower runs fine but does not want to turn. When you turn the front weels to turn,the...
Sounds like you have problems inside your gear box, The easiest way to check this is to stand the mower up on it's backend and try to turn one wheel and hold the other. You should be able to do this if you get any bucking or the rear end locking up your problem is going to be in the gearbox. FYI make sure you lock your clutch pedal down so the drive disk does not contact the friction disc
Aug 10, 2009 | Garden
What is causing slipping of rear right wheel on
most likely the gears that are inside the wheel hubs.
Jul 09, 2009 | Garden
My riding mower is stuck in gear. I can shift
If the wheels aren't facing straight forward you may have broken an axle.
May 18, 2009 | Garden
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
89 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
