Air conditioner Btu unit fan blade won't turn
    Problem Solver:
  • 8 Answers
A the fan motor is bad. Or b the capacitor is bad. Try spinning the fan motor with a stick or screwdriver.if it spins freely then it might be the capacitor. Take the side cover off and look for a silver round thing if the top is bubbled up or it has oil on it it's bad.But it's got to be one of those.
Posted on May 09, 2013
  • 3422 Answers
SOURCE: air conditioner window unit {Hampton Bay}
You can get the parts from the below sites:
www.searspartsdirect.com
www.partstore.com
If you need anymore help let me know.Please don't forget to rate or accept the previous premium solution.
Posted on Jun 22, 2008
SOURCE: Sunbeam floor air conditioner KY25/Y
Mine is cooling but I have a broken fan. If you're not going to use it sell it to me please. contact me at yenks@hotmail.com
Posted on May 24, 2009
  • 340 Answers
SOURCE: I have a Goodman air conditioner. My outside unit
If you are sure of the power then ya have a control problem thermostat set correctly? could be open low pressure switch I would call for service. Tom
Posted on Jul 03, 2009
hvac1960
  • 2133 Answers
SOURCE: I have a Haier 5,200 btu air conditioner that
E-1. Indoor room temp sensor defective. replace it.
Posted on Jan 04, 2011
  • 5105 Answers
SOURCE: What does the "dry mode" mean in a Hampton Bay air
The "dry mode" dehumidifies the air. This is useful when you do not need to cool the air but the relative humidity is higher than you want to have inside. You get the advantage of bringing in the fresh air without increasing the indoor humidity.
I hope this helps.
(this applies to all air conditioners with a dry mode)
Posted on Jun 19, 2011
AOU12RLS outside unit is knocking or ticking? Any idea what it might be? Nothing appears to be in fan after taking cover off to examine.
need to check and make sure the condensing fan ( outdoor unit fan) wires are not hitting the fan blade, it could also be that the fan blade needs to be balanced.
Oct 21, 2013 | Fujitsu "AOU12RLS 12,000 BTU Cool/16,000...
Danby DAC10011E 10000 BTU window air conditioner not draining water? does it have some sort of self evaporating technology? I can hear water inside when I turn it on and/or off, but none draining out the...
Hello, some window units do not use a drain tube instead they use the condenser fan blade to scoop the condensate from the bottum of the base pan and splash the condenser coil to keep the condenser cool and also evaporate the condensate. Most of the time you can hear a "swishing sound"
Jun 18, 2012 | Danby Dac10011e 10000 Btu Window Air...
In a 10x23 room with lots of widows how many BTU air conditioner do I need?
The dimensions you gave only equal 230 sq ft. It may seem larger, because it's long and narrow. Even with lots of windows*, you shouldn't need more than 15,000- Btu's to cool the area comfortably. *That's assuming you close the blinds, shades or curtains, while the room is in direct sunlight. Even with a higher Btu output, those "lots of windows" will always be an air conditioners worst enemy. So, in your case, more is not better. In fact, it's a waste of energy.
If you have a ceiling fan in that room, run it on the highest speed that comfortable to you, in a clockwise (looking up at the fan blades) direction. This will help move the cool air around and generate a wind chill. That will make it feel cooler than it really is. Plus, it takes the strain of the AC unit.
I hope this helps you and thanks for choosing FixYa.
Aug 26, 2011 | Heating & Cooling
My Lennox ac is making a very loud buzzing sound and the fan blades are not turning. We replaced the dual capacitor and that seemed to fix the problem for a couple of days, now it's doing the same...
Fan motor is probably bad, if it is under 5 years old the parts are under warranty. Do not run the unit for very long without the fan working as it can damage the compressor.
Aug 23, 2011 | Heating & Cooling
HI, My Kenmore Air Conditioner Model# 76129 - turns on, makes a sound like it is going to work but the fan does not move. Thanks
When a fan malfunctions, the problem is usually loose or dirty blades. If the fan won't operate or if it's noisy, cleaning and tightening will usually fix it. Here's how to repair a room air conditioner's fan:
What You'll Need
You'll want to have these tools on hand to repair a room air conditioner's fan:
  • Vacuum
  • Soft cloth
  • Screwdriver or Allen wrench
  • Long-blade screwdriver
  • Wrench 20-weight nondetergent motor oil
  • Volt-ohmmeter or multimeter
Step 1: Open cabinet and locate fan.
Step 2: Clean away any debris with vacuum and soft cloth.
Step 3: Check fan blade on motor shaft for looseness. Blade is fastened to shaft with setscrew at hub of blade.
Tighten setscrew with screwdriver or Allen wrench. If air conditioner has round vent fan, tighten fan on motor shaft by inserting long-blade screwdriver through port in fan.
Fan is installed in its h­ousing with bolts, and vibration can loosen these fasteners. Then tighten them with wrench.
Step 4: If fan has oil ports, apply several drops of 20-weight nondetergent motor oil (not all-purpose oil) to each port at beginning of cooling season.
Step 5: If you suspect fan motor is faulty, test it with VOM set to RX1 scale. Disconnect terminal wires from terminals, and clip probes of VOM to wires.
If meter reads between about 3 and 30 ohms, motor is functioning properly. If meter reads either zero or an extremely high number, replace motor.
To remove the fan motor, remove the fan, the power wires, and several mounting bolts. Install the new motor with the reverse procedure .bobicehouse_59.jpg
Aug 13, 2011 | Kenmore 76129 Air Conditioner
I have a 1400 btu portable air conditioner ( AMANA ) and the fan is broken, how to replace it.
Obviously, you will have to disassemble part of the cabinet to access the fan blade. Removig the blade should not be difficult. If it's the fan motor, than that may be a challenge. However, since you did not furnish the Model Number of your AC Unit, there's not much more I can tell you, other than where to find the part(s) you'll need. Try Factory Appliance Parts http://www.appliancefactoryparts.com/airconditioners/amana/amana-motors-and-blades.html You'll definitely need the correct Model Number of your unit, to search for the part(s) you'll need.
Hope this helped you.
Jun 27, 2011 | Amana Portable Air Conditioner
The fan wouldn't start for the condenser unless I turned the blades with a stick so I replaced the start capacitor and it still won't start without turning the blades with a stick. It runs fine but...
This problem could be caused by a bad motor run capacitor. Please see our If your motor capacitor is not the problem, then more than likely you need a new motor.
Jun 13, 2011 | Ruud UBHC Air Conditioner
I have an sumsung ac m#aw1403b 13,800 btu the lc indicator turn on but the air doesn't no fan or nothing but the lc shows speed,temp,funtions.etc but no air please can u help
it could be a fan motor or capacitor fault.Could be something jaming the fan blade.Does the compressor start? If you have nothing working then it is prob a problem with the control unit
May 02, 2009 | Samsung AW1403B Air Conditioner
Heating & Cooling Logo
61 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
