Where can I get a replacement mainboard for the sony 52V 4100
The number is A-1547-088-ABU
Sony kdl-52v-5100 lcd TV picture is gone. Now has vertical lines that change slowly as TV warms up. Also Makes no noise. Any help would be appreciated greatly.
T'Con board fault. If you wish to get some details; visit this site . Pull up older posts. Surf the site with patience.
" Electro help " . Just Google for it.
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Apr 23, 2015 | Sony Televison & Video
I need the motherboard for Vaio e series vpceb46fg, any body have an idea what motherboard they use in Vaio e series vpceb46fg
Yes. they use the mainboard for a Sony VAIO VPCEB46FG. You find the mainboard for a laptop by the model number of the laptop.
Aug 16, 2013 | Computers & Internet
What is the Postal code for Abu Dhabi, United Arab Emirates?
There is no postal code for Abu Dhabi or any other City/Emirate in the United Arab Emirates. There is only Post office Box number.So if u need to write an address, it goes like
Mr. ABC
P.O Box.No. 12345,
Abu Dhabi, U.A.E
When completing on-line forms that require a zip or postal code for the UAE, simply type in 4 0's (0000), this is normally enough to be able to bypass this feature. Do not use 0000 on any written correspondence as it has no significance to the postal services at all.
May 23, 2011 | HP Computers & Internet
Sound turns off after tv is started sound only one
Hi my name is Roety,
I can help you with your issue ,
Without a model number, I do work on sony LCDs.
The audio is on the mainboard. You need the mainboard replaced.
Reboot every device by unplugging the AC power , if the sound still cuts off replace the mainboard
If I have helped you with your issue please click accept.
If you have more questions you can still respond
I will reply asap
Thanks
Eric
Oct 10, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
I have only power and ethernet lights on my 4100 B modem. Also, the ethernet light stays lit even when yellow cable is removed! Tech at ISP (AT&T) says the modem is defective. Shouldn't they replace it...
I had a similar problem with my speed stream wireless modem, Etisalat technician attended & replaced with a new modem. It looks to me the problem with Power supply as one of my friend replaced power supply for the modem and the problem resolved but my case, I had to change the modem itself.
Sajid-Abu Dhabi,U.A.E
Jun 03, 2009 | Siemens SpeedStream Modem (4100) (SS4100)
Samsung scx 4100
the motherboard in your machine has gone faulty. i have not found a repair other than replacing it which is not economical to do.
currently working on repairing the mainboards but no luck yet maybe someone else has a fix for this?
Jan 07, 2009 | Samsung SCX-4100 All-In-One Laser Printer
Z750i will send pictures locally (Abu Dhabi) but not the to the United Kingdom
hello,
U can't send msgs to ppl in U.S or U.k due to sum kinda msg restriction from our network to their network...I'm not exactly sure y.....
Feb 17, 2008 | Sony Ericsson K750i Cellular Phone
I need the parts no.
for what really if you are replacing the phone board just get a new k610i mainboard no part number needed.
Jan 13, 2008 | Sony Ericsson K610i Cellular Phone
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
Electro Med Services...
