Question about Light Outboard Motor Boat Bass Fishing Saltwater Base
1985 johnson not getting current from elec block to coil
  • 40 Answers
Not enough information , engine types, or model.
Posted on Nov 13, 2013
I need exact replacement ac air handler Weather King model RCBA4882GH21...4 ton 10 kw elec heat with the I need to replace my Weather King ac air handler unit...4 ton, W shape evap coil ,elec...
What's wrong with your current AHU? Any Ruud dealer can assist you. Most 4 ton units work with r-22 or 410a. As a side note, most parts in an air handler can be replaced unless the case is rusted thru.
Sep 24, 2013 | Rheem Air Handler 4 Ton With Rhplhm Series
1985 johnson 85 hp outboard bogs under load
CHECK IGNITION COIL OUT PUT AFTER THEY HEAT UP. A WIRE CONNECTION (INTERNAL) COULD BE SEPERATING, NOT MAKING CONTACT AFTER HEAT EXPANSION
Jul 23, 2013 | Boating
1985 VW Cabriolet. It turns over enthusiastically, but won't fire. I've traced current to distributor from coil, but no spark at the plugs. I've replaced the ICM card, given it a new...
So you have no spark from the coil or you have spark from the coil but not at the plugs. You said it turns over really fast? Have you checked the timing belt?
Jun 02, 2011 | 1985 Volkswagen Cabriolet
Engine won't start it won't even make a spark, we think it maybe the relays or a wire problem during the starting process... where are the relays located on 1985 Chevy Truck?
Hi and welcome to FixYa!
Before going to the relays please go for the coil pack. If the coil pack is faulty it tends not to give current to the plugs. Once replaced you'll be good.
Hope this helps and thank you for using Fixya! Have a good one!
Mar 03, 2011 | 1985 Chevrolet Chevy
Replaced both coils replaced cid module but motor still has a miss while idleing and when given gas to run backfires and misses terribly. it is a 1993 johnson 30 h.p. elec start. what am i possibly...
check the timming first. have you changed the plugs, i just buoght a new set and one plug died 13 mile off shore. goog thing i keep the old ones onboard.
check you plug wires too. the omc are put together style and sometimes will vibrate apart at the ends.
Oct 13, 2009 | Light Outboard Motor Boat Bass Fishing...
Does an 85 johnson outboard motor 15 hp have
Not ignition points as a set of breaker points as we know it.The timing is set from magnets set under the flywheel.Hope this helps
Sep 02, 2009 | Sport & Outdoor - Others
Light Outboard Motor Boat Bass Fishing Saltwater  Base Logo
42 people viewed this question
Top Light Boating Experts
ray gallant
fordexpert
Are you a Light Boating Expert? Answer questions, earn points and help others
