Question about Reflecta RPS 7200 Professional - Film/Slide Scanner
Cyberview x5 When prescanning, after scanning 3/4 of the frame the error-message "Open image file failed (Read)" (error # PF7250PRO3_LL) occurs and nothing happens. What should I do? Latest firmware and drive is installed already. Thanks in advance!
Smart Thru 4 Scanner - Application not error
well try a hp one my friend has one and it never fails to scan paper to a computer.
Dec 06, 2011 | Samsung CLX-3175FN Color Laser All-in-One...
I have installed HP PHoto and Imaging Softward for ScanJet 3570c 48 bit. Everytime I try to click on icons on the scanner, my computer shows an error message that there is a problem with connecting to the...
Does the same error occur if you launch a scan from the computer? What OS do you have? Vista only has a basic driver available and does not support the scanner buttons. (You can launch the scans from a number of options: third-party software, Windows Fax and Scan (new scan), Microsoft Paint (File > Import from Scanner or Camera > New Scan) and Windows Photo Gallery.)
If the error occurs when you launch the scan from the computer, try a new data cable and different USB ports. Try a direct USB connection if you use a hub. Then check your USB ports and the drivers for the USB. (For Windows, look in the Device Manager. Start > Control Panel > System > Device Manager (exact directions will depend on the OS).
The HP Photo and Imaging software requires you to set the default scan destinations in the software before you can use the buttons on the scanner (for those OS/driver versions that support the feature). Always open the software and scan from the computer to see what the defaults will be. Each version of HP's imaging software set up these buttons differently; the help option is useful. Try Scan > Scan settings to find where to set the color and black & white destinations.
I hope this helps. If you add a comment with your OS and whether the computer can launch a scan, I'll provide additional help if I can.
(who inherited a scanner when a USB hub failure aggravated the original user into buying a new scanner thinking it was a scanner problem.)
Aug 12, 2011 | HP ScanJet 3570C Flatbed Scanner
From the HP Solution Center the following error message appears about scanning: Parsing error in file C:\ProgramFiles\HP\Digital Imaging\bin\hpqscloc\1033.xml
1) Go to C:\program files\HP\digital imaging\bin\ and check how many folders are there for HPQSCLOC .If there are only one folder for HPQSCLOC in that case don't touch the folder.
2) Go to command prompt
TYPE THERE "CD..." AND HIT ENTER
KEEP TYPING "CD." AND HIT ENTER UNTIL WE SEE C:\
WHEN C:\ COMES
TYPE THERE- "regsvr32 /u hpqscloc.dll"
We may get an error in vista which says module failed to load
Follow Step 3
3) Open cmd prompt
Go to C:\
Type there
"regsvr32 hpqscloc.dll on"
4) Download and install
http://www.microsoft.com/downloads/details.aspx?FamilyID
=32BC1BEE-A3F9-4C13-9C99-220B62A191EE&displaylang=en
http://www.microsoft.com/downloads/details.aspx?familyid
=A5C84275-3B97-4AB7-A40D-3802B2AF5FC2&displaylang=en
Try to scan
Or else follow step 5
5) Uninstall the imaging device and the solution centre
6) Download msicuu2 from microsoft.com
http://www.filewatcher.com/m/msicuu2.exe.189920.0.0.html
Run the windows cleanup utility
Delete AIO Scan from it
7) GO TO CMD PROMT
Then type CD programfiles\hp\digital imaging\bin
8) Type regsvr32 /u hpqscloc.dll
try scanning and check if it works or not
if not follow another step
9) Tried to uninstall the software
10) then install the software back
It will scan fine
Mar 26, 2011 | HP Office Equipment & Supplies
Error code 2881
Found error in image file, Error Occurred, error 0901, 572, 2881
The camera says found error in image file, repair data now. When you press yes it says "Error occurred. Please replace disc." or use ac adapter/charger, turn off power. It won't let you go to Disc Navigation to finalize it. While recording video on DVD-R media the battery power may have failed and camera shut off. When turned on the message shown on the lcd is Found error in image file, Error Occurred, error 0901.
Regards.
Jan 12, 2011 | Hitachi DZ-MV580E DVD Camcorder
I have acrobat 5.0 and acrobat 7.0 on my computer. Most of the time they fail to read acrobat files with an error message ''An internal error has occurred'' appearing on screen. Any suggestions?
uninstall all your versions, run "ccleaner" and do the registry scan and fix all, do this 3 times to fix everything
restart the puter and install the latest version
Nov 13, 2009 | Adobe Acrobat 7.0 for PC
While trying to make a color copy, the copier slowly prescanned the image I wanted to copy and gave me the error message E-30 Placement error
I didn't want to wait. Instead I simply scanned toe document I wanted to copy, inserted it into a Word® file. Printing this file gave me the copy I wanted.
Oct 04, 2009 | Epson Stylus CX6000 All-In-One InkJet...
Can't scan documents
For the system to work completely; you need the print driver, scan driver and smarthru4.
Once you install the scan driver (available on Samsung website); the issue will go away.
Also, another trick; instead of using the smart thru - which is kind of awkward, download Picasa 3 and if you have installed the scan driver correctly, you can use Picasa to import the scans by controlling the printer. It also allws for some other tweaks that are not so easy to get to in Smart Thru.
In addition to Picasa you can use several other graphic applications to scan the image.
Good luck.
Jul 31, 2008 | Samsung SCX-4100 All-In-One Laser Printer
Unreconizable image
Try updating your scanner driver/software to isolate the problem. If same issue still occurring after uninstalling/reinstall, then source of the problem may be a CCD/lamp failure or some sort of dust, lint, on CCD causing calibration failure.
Sep 03, 2007 | Pacific Image PrimeFilm 1800u Film Scanner...
SCANNING PROBLEM
Maybe that JPG has very high quality, big size that Word cant handle it, it sometimes happens. Try to put it on some other text-editing software, I bet that WORD doesnt handle that big JPG. Happend for me also :) try to upload it to an image-hosting site, then just put the link in the DOC :)
Mar 13, 2007 | Brother MFC-3220C Plain Paper Inkjet Fax
Moving film by frame
try unistalling the prog and re install it windman
Sep 16, 2005 | ACI Pacific Image Prime Film PF3650 Pro...
Reflecta RPS 7200 Professional - Film/Slide Scanner Logo
143 people viewed this question
Top Reflecta Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Reflecta Office Equipment and Supply Expert? Answer questions, earn points and help others
