Question about Lexmark C544dn Laser Printer
Yellow toner on my papers - Lexmark C544dn Laser Printer
The printer is reading error 093-919 and not printing
It thinks the yellow toner is not installed correctly. Remove and check yellow toner or try a new one. If that fails inspect around the space where the yellow toner sits to see if there is a switch jammed.
May 08, 2014 | Dell 3115cn Color Laser Multifunction...
Tip
How To Remove 077-100 Error in Dell 3130cn Printer?
This is right that error 077-100 error is belong to Registration and or Exit sensor.
But if the yellow toner cartridge doesn't run so there will jamming the paper and the printer shows the error (077-100).
Actually i solve the issue after three days when i guessed and checked the yellow toner cartridge it was tighter than others.
So i replaced the yellow toner cartridge and solved the issue.
on Mar 29, 2016 | Dell 3130cn Color Laser Printer
Biz Hub C250 is dumping too much yellow toner, what are some possible reasons/solutions?
Bad cleaning blade in the drum (Image Unit). Because toner goes in the image in the front not the middle or rear.
Mar 08, 2014 | Konica Minolta bizhub C250 All-In-One...
I have yellow streaks running down the page at the side which look like they are toner or ink. How do I get rid of them?
its the color toner! and what is happending is the drum is dirty and what happends is the excess is getting on the fuser and passing it to paper. May i suggest what they call wet sheets? there not really wet but there like magnet sheets you load them like you do normal paper and it cleans the printers paper path.
http://www.buy.com/prod/advantus-pathkleen-laser-printer-cleaning-sheets-cleaning-sheet/q/loc/101/206474823.html
click the link above. this will clean the whole printer now if some reason that does not work out for you the printer will then need its drum replaced or serviced. thanks please do rate and leave feedback for your free answer today.
Apr 27, 2010 | HP Color LaserJet 2600n Printer
Yellow toner usage is high , ventilator at back panel is yellow. Cannot print pure red colors
I would guess the yellow toner cartridge is leaking. Clean out the printer, including the fan and air path to the back panel vent, and inspect the mechanics of the yellow cartridge section. If no abnormalities are seen there, try a different yellow cartridge. Stray or excess yellow toner might mess up all of your colors - do you see green blotches in blue areas?
If you had normal toner usage, I'd suspect a problem with the corona wire for yellow that lets the toner blow away from the paper instead of adhering. That would leave your reds with a magenta hue and paint the fan yellow.
You could even have both problems if toner powder has contaminated the high voltage contacts.
Dec 09, 2009 | Konica Minolta bizhub C351 All-In-One...
Canon Pixma 470/ cyan and yellow won't print
it may be many things, here some thing to try:
the ink or toner is contrammed with foreign liqued like oils, water, bad ink, bad toner cartridge,
oil, water, ink toner inside the ink itself
oil from a human skin my have came in contact with refill of ink or toner cartridge, cleaning solvent to clean the cartridge, needles for hte ink or toner cartridge, water in the ink or toner cartridge, steam or vapors of some kind, compress air can or air compressor will spread water solution, the freon is used in compressed air can thats way they get so cold when you spray the can.
paper may also be wet some how try new and different brand of paper.
rod the candymangandy
Feb 04, 2009 | Enlight Intel Xeon 470 WATT EN-470 MP...
Just a few days ago my printer will not print. It will come up with the message that says Open the printer cover and put Yellow Toner Cartridge. The yellow is in and it is not empty. I took the color out,...
Let it go through its checks. When you take the toner out, clean it, wipe off the chip (upper right) then snap it back in. It may stop with the yellow and it may continue through the other colors.
What I found, is that it is really the paper feed being out of sync. Keep with it, it will resolve itself.
Also, take out the drum and turn the paper feed forward till it clicks and realign your paper.
Dec 01, 2008 | Konica Minolta magicolor 2400 Laser...
Samsung CLP-510 Toner Bleed
The following can cause bands (vertical on a normal page)
Faulty Toner cartridge
Faulty Drum Unit
Faulty Transfer Belt
Contaminated Fuser
Damaged or dirty LSU glass
Jan 09, 2008 | Samsung CLP-510 Laser Printer
Dell 5100cn Laser Printer Problem
My Dell 1600n suddenly stopped printing. It keeps saying "No paper," and even though I've changed papers, fanned it, squared it, changed how much, how little.............it still says "no paper."
Dec 27, 2007 | Dell 5100cn Laser Printer
Lexmark C544dn Laser Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
