Question about Thermos Nissan NCI1000 Coffee Maker
Where do I find a new screen for nissan french press thermos coffee maker?
Where can I buy a French Press online?
Amazon and EBay have a great selection of French Press's worth checking out -
http://www.amazon.com/Coffee-Presses-Makers-Tea-Espresso/b?ie=UTF8&node=289749
http://www.ebay.com/sch/i.html?_nkw=french+press
Otherwise, you could check out several other options yourself and compare prices. I would also recommend reading some reviews.
Feb 07, 2013 | Wine & Spirits
Why does the plug loosen and my coffee is cold after pouring???
The problem is the keep warm element. The reason, your pot perc's and it gets hot near the thermo, the thermo turns off the main element. The keep warm element is not on so after a small amount of time the water cools and the thermo turns the main element back on again, thus making the water hot. The K W element is supposed to be on all the time the pot is plugged in, it is instrumental in perking the first brew making it really hot, the thermo turns off the main element and the K W element keeps the water hot. The K M element is very a easy fix, it is the small looking white rope that runs around the bottom of the pot. You have 1-nut and 1- screw to remove. When removing the screw from the main element you must hold the (leg) that the K M element is screwed to so it does not bend and brake off. Take your time and be firm with the pressure you apply to the screw, while holding it with a pliers Good luck. bobbyone
Dec 13, 2009 | Faberware FCP240 Coffee Maker
Every French press i have bought works well the first couple of times then the screen on the press bends and creates air pocket which when pressing explodes coffee grinds and hot water everywhere!
The trick with any manual French Press coffee maker is to very slowly press the plunger down, after you've allowed the ground coffee to steep/brew for the time you prefer.
I've got an older French Press carafe and had my share of "bent" screens from being too quick when pressing. I finally learned that the slower I pressed the better the unit would survive and the better quality of coffee I'd get as a result.
French Press coffee is not a quick process, what with the boiling water and fresh ground coffee beans and the steeping/brewing dwell time needed to get the hot water infused with the coffee and the very slow pressing filtering process needed to extract the full flavor of the coffee from the ground coffee and water.
Take your time in pressing your coffee and enjoy the great, fresh taste from your efforts.
Hope you find this Very Helpful and best regards!
Nov 10, 2009 | Bodum 's BRAZIL french press coffee maker...
WEAK COFFEE & NOT HOT ENOUGH
Basing on personal experience (you can find more on Google probably), solutions are:
On percolated (filter) coffee machines:
Check water temp, if water temp is insufficient , most common is scale heating element , faulty element, faulty thermostat.
Check if water is dripping right at the center of the filter, if it is dripping on one side because the orifice is clogged, that can result in weak coffee.
Coffee blend not well distributed on filter basket.
On Espresso machines:
Check water temp, same as filter coffee machines (thermostat element, scale on heating chamber).
Ensure that coffee is filled correctly in the filter cup (fill at level), and well pressed.
Ensure that the coffee mixture that you are using is not too coarse, buy the apposite one for espresso.
Ensure that you are not leaving the machine brewing for a time that is too long, and Italian coffee cup is very small, approximately one regular shot.
On the hob moka pots (espresso, Moka and Bialetti type):
This are the trickiest ones, you need art and practice to get a good espresso with a Moka, but when you learn, the result is better than what you may get with an home electrical espresso maker.
The frame on the hob must be not too strong, and the mixture coarse but well pressed, with water at level tag, or you will get a weak coffee.
On Mokas a good strategy is keeping hob at minimum, and turning up the flame at top when coffee starts coming out.
French and turkish cafetieres:
Ensure that you put enough coffee, water hot enough, and that you left the infusion enough time to get a strong coffee.
Note: insufficient pressure and clogged lines on electric machines never give you a weak coffee, exactly the opposite.
Not pressed mixture always gives weak coffee, but too much pressed mixture may give you coffee with bad taste.
Dec 22, 2008 | Bunn NHB Coffee Maker
Replacement screen 4 your Nissan thermos
for your needs
Call Thermos Nissan direct at 1-800-831-9242
eric
Oct 10, 2008 | Coffee Makers & Espresso Machines
Assembly
turn the filter upside down (opposite the way it is now)
Should help
May 05, 2008 | Bodum 's BRAZIL french press coffee maker...
Replacement part for Thermos Nissan Coffee Maker
Call Thermos Nissan direct at 1-800-831-9242. Replacements were $3.75 each plus shipping at the time of this posting. Shipping is about a week.
Apr 23, 2008 | Coffee Makers & Espresso Machines
Thermos Nissan NCI1000 Coffee Maker Logo
51 people viewed this question
Top Thermos Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Thermos Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
