Question about Sony DCR-HC27, DCR-HC27E, DCR-HC28, and DCR-HC28E Battery (Premium Japanese Cells, 1300mAh, 5-YR War...
Head cleaning I have problem, my hand cam says that "head dirty, clean head", what can i do while i have already tried to clean by using head cassette cleaner?
sreekidu
  • 60 Answers
SOURCE: Sound dropout
hi, the problem could be because of the problem with the pinch roller ,either it has some wear or the supporting spindle needle has some improper orientation. Is this with a specific tape or all tapes? if it is specific to a tape then it can be because you kept the recorded tape near magnet which causes this rythmic sound drop out. i guess the first one may be mostly happened. all the best sreejith
Posted on Aug 13, 2007
welcomejee
  • 10594 Answers
SOURCE: D8-->Hi8 switch.
Hello DutchyFL,
Sony recomends to use Video Head Cleaning Cassette in Playback mode. Video Head is still dirty in your camera thats why you can't see D8 picture.
Posted on May 27, 2008
pemring
  • 53 Answers
SOURCE: head cleaning
Error C31:42 it means FG fault during normal drum operations. Some it happen when ur head drum is Video head is dirty.Here if u try to cleaning tape it will not work. So u need to open the compartment clean manualey with the cleaning cloth which u have to buy from Sony
Posted on Jan 16, 2009
  • 497 Answers
SOURCE: I'm trying to clean the heads on my TRV 950, I
Follow these steps to resolve the issue:
Step 1: Remove the cassette and insert it again , then operate your Camcorder.
Step 2: Try using different cassette.
Step 3: Try resetting the Camcorder.
[Resetting the Camcorder will reset the settings of the Camcorder to the factory settings including date and time. It will not delete any data saved in the Camcorder.]
Please locate the RESET button behind the LCD screen of the Camcorder. Press the RESET button using a sharp-pointed object. The Camcorder should be switched ON when you reset the unit.
Step 4: Try to power reset the Camcorder and check if it helps to resolve the issue. Power Reset the Camcorder by removing the batteries from the Camcorder and inserting it after 1 minute.
Step 5: Service is required.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C79466
Posted on Aug 12, 2009
  • 29 Answers
SOURCE: sony vx2100...blue playback screen
in either case the head condition is bad.. pls inspect the tips on the head whether it is not damaged in the cleaning.inspect the drum hours also..
Posted on Jan 12, 2010
SEVERAL OF THE FUNCTIONS ON THE CONTROLLER DO NOT WORK. WHERE CAN I GET A NEW CONTROLLER AND HOW MUCH IS IT?
open the rem.controll and clean the keypads for dirty, corrosion, oxide, and bad contacts with c. cleaner and fix it.
2) clean the contacts batteries put new batteries alkalines from the same types.
3)retigh the springs with long pliers for better contacts, and clean it
Otherwise you must go to the repair shop TV for fix it.
God bless you
Sep 30, 2012 | Magnavox ZV427MG9 DVD Recorder VCR
Camcorder won't record or playback,has distortion and low volume.Is it just real dirty?
Try to find a video cam ,,head cleaner,,at elonric s store ,,find online,,,try cleaning the heads down in there with alcohol and a q tip,,,also,,good luck,,but thats what it is just dirty,,
Dec 23, 2011 | Quasar VM-L152 Camcorder
Video playback is only in B&W. Video "flickers" and varies in detail. Cleaned the heads and used a "head checker" to test for wear. Also, replaced 2 failing caps in power supply....
Hello
What is the model number of your device?. Without it how can I post a solution before you? Provide these by FixYa please.
May 21, 2011 | Televison & Video
I used a sony cam corder to record an event last night. The image is corrupted. there are solid grey bars running across the screen. Is there anything I can do about this?
Yes, its symptom of dirty/ clogged video heads in camcorder.
Put head cleaning tape in camcorder and clean video head as per instructions written on tape material.
Head cleaning tapes are available in radio Shake or any other store.
Thanks.
Dec 14, 2009 | Sony Video Cameras
No Picture, just sound. Would a head adjustment help? where is the head adjustment made?
NO!! Do not adjust any of the azimuth settings on the guide arms or control head this will only cause more problems. It sounds as if you just have dirty heads, either try a head cleaner tape, or better try to clean them by hand. Remove the cabinet cover & the head drum is the round silver drum sitting in the centre. Either use isopropal alcahol or something similar & very GENTLY use something non-fabric ( a piece of clean card will do) put a small amount of the fluid on the card & wipe the side of the drum, put very Light pressure on the drum you can damage the haeds if you are too rough, this should clean the heads.
Jul 06, 2009 | Panasonic Televison & Video
Black bands on picture
5 black bands means dirty heads. try a sony cleaning tape; if no good, time for hand cleaning.
Sep 19, 2008 | Sony DSR-30 Mini DV VCR
Sony handy cam CCD-TRV46E PAL
Please use Video Head Cleaning cassette to clean its video head. I'm sure, you get error sign of Dirty Video Head in view finder while recording.
Aug 09, 2008 | Video Cameras
Please help...Blue Screen of Death?
try a head cleaning tape. the blue screen is what is displayed when the heads are too dirty to read the information on the tape. if the head cleaning tape doesn't solve it, a hand cleaning should do the job.
Dec 05, 2007 | Panasonic AG-DVC30 Mini DV Digital...
I cant replay any vids.
video heads are dirty, try using cleaning cassette, if it won't help, replace the video head
Aug 20, 2007 | Canon MV600 Mini DV Digital Camcorder
Camcorder
if all the indicators i.e. battery condition, play mark, counter, etc are visible on the screen then it can be a simple problem of dirty video head. try using a head cleaning cassette or do the head cleaning manually, Open the cover by removing three screws on the right hand side next to the viewfinder. Slide it little towards front and pick it up. The video head will be visible.
Sep 15, 2006 | Sony Handycam CCD-TRV107E Camcorder
Sony DCR-HC27, DCR-HC27E, DCR-HC28, and DCR-HC28E Battery (Premium Japanese Cells, 1300mAh, 5-YR War... Logo
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
