Question about Radio Communications
Quansheng TG-45AT My qhansheng TG-45AT suddenly went from being a VHF to a UHF2!!! How can I change it back? This is the second of these radios to do that to me. Can't keep buying them
Change frequency
Read the radio and write your desired frequency, must see you radio band. If it is VHF the put the VHF range frequency.
Jan 07, 2014 | Motorola RDU2080d Two Way Radio
My Solara Dsc radio, which has worked well for several years, suddenly began blowingthe 2 amp fuse on the red power line whenever the transmit button was pushed on the mic. Why?
No worries here.
According to Uniden, the 6 amp fast blow fuse is the correct one.
Not entirely sure why there'd be a 2 amp with your old radio, but I suspect the radio is good.
-Steve
Uniden VHF radio fuse Google Search
Dec 04, 2013 | Uniden Solara DSC VHF Marine Radio
Portable radios
the BF888 is NOT a vhf radio, it is a UHF radio so it will NOT program VHF frequencies
Oct 02, 2013 | Baofeng BF-888 S UHF 400-470 MHz Portable...
Radio is not working, screen went to a small print
Change the front pannel, if your RX/TX is working good.
Aug 12, 2013 | Icom Ic-f5061 Vhf Mobile Radio Ic5061
Can not program pmr
I\'ve just finished trying to solve, without much luck, another Chinese made radio problem.
Firstly, can you decipher Chinglish to English, if so your one step closer than me in fixing, stuffing the problem.
Secondly, do you have the user manual?
If not, try your best to get a copy, and have someone who can read and translate Chinese to English, so you can follow the steps required to program these nasty little buggers.
I hope this is of some use to you, Sorry if I make these radios sound bad, But nothing made in China has been a success with me including their cars which are available here in Oz.
Good luck and I hope you find someone to translate for you.
Cheers,
Peter
Jan 08, 2013 | Radio Communications
How can I make the 19DXIV VHF capable
There is no way to make that radio VHF capable, CB radio's operate in the AM band, and most, if not all VHF radio's operate in the FM band. CB radio's are not capable of VHF frequencies either, VHF is considered around 40MHz and above, CB radio's operate between 26.965 MHz and 27.405MHz that is considered 11 meter band HF. CB radio's are not broadbanded enough to cover anything that far away, expecially the newer radio's, as most of them are controlled via a microcontroller and PLL tuning circuit. the 19DXIV is a great little radio, but will never be able to operate in or even around VHF. sorry.
Oct 21, 2012 | Cobra 19DXIV 40 Channel Mobile Compact CB...
Radio turns on , channels change, but no sound or squelch..
It sounds like your vhf speaker has failed. I recommend taking your radio to a repair shop and replacing the speaker...this should solve your problem.
Jun 16, 2010 | Icom ICM422 FixedMount Marine VHF Radio...
IC-M302 VHF Marine Radio: need to have wiring schematic coming out the back ...
Blue: Speaker (+)
Gray: Speaker ( -)
Yellow: NMEA IN (+)
Green: NMEA IN (- )
May 17, 2010 | Icom IC-M302 VHF Marine Radio
IC A23 Portable VHF radio Locked
ic a 23 quero scannear como fazer /???
please scam mode /???
Mar 04, 2009 | ICOM Informatique IC-A23 VHF NAV/COM Air...
Icom vhf radio
i have the same unit. i get interferance from my depth finder wire touching the antena wire off the back of the radio. make sure that no wires are touching the antena wire.
Aug 12, 2007 | Icom M302 VHF Radio
Radio Communications Logo
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
