Question about Garden
Toro LX425 Lawn Tractor highest setting to adjust deck height is too low. Cannot use any settings other than highest one or it will scalp the grass. How can I raise the deck so I can use all the settings?
5 Suggested Answers
  • 97 Answers
SOURCE: The highest deck setting cuts my grass down to one inch.
leveling bolts hang from each side deck by frame...tightened up and level...will give you some more room....be sure the blades are not bent.
Posted on Jun 14, 2009
mowerman1857
  • 389 Answers
SOURCE: How do you adjust the cutting deck?
Pete, go back to partstree and look at the diagram for lift arms. Item #27 is your lift cables. You will notice there are several little ferrules or balls on the cables, you unhook the cable and slide these up or down as needed to adjust your deck. If you need the deck higher, you would position more of the balls under the lift arm on each side. If you can't get the desired height then your cables are stretched and need to be replaced
Posted on Oct 10, 2009
  • 640 Answers
SOURCE: how do i adjust the
On the right side of your mower you should find a lever that allows you to adjust the cutting height of the deck up and down.
I hope this helps, if that is not sufficient just reply for some clarification and I will answer you question further.
Posted on Jul 15, 2011
SOURCE: 2010 Craftsman Lt 2000 deck height adjustment?
just bought a new craftsman riding mower. model lt1500. 17.5 hp with 42 inch deck. first time using I had the deck hight handle set on 6 the highest setting and still cuts grass to short, matter of fact it scalped the grass. anyway to set the deck higher. Its only 3 days old and still under warranty but the sears store is 20 miles away and I rented a trailer to go pick it up and hate to go rent another trailer to bring it back if its just a simple adjustment.
Posted on Jul 29, 2011
Mower deck adjustment
you may have bent brackets in the front. These are the pieces that straddle front and back of the front axle beam. This happens when you hit things sticking up or on the side with the deck.
You also could have bent deck link bars (where you make height adjustment on the front).
Aug 12, 2014 | Craftsman Garden
I have a riddeing lawn tractor and on its highest setting cuts grass too short how do i raise the deck to get a taller grass
if you look under lawn mower were the deck attachs you will see the adjustment rods unhook one at a time to adjust ether screw the rod in or out do this on a driveway so you can measure with the tape measure how for you or lifting deck and can match hight on both sides
May 14, 2014 | Yard Machines 13AC762F000 38-Inch 344cc...
I purchashed a used 26 54 husqvarna 2007 model rider and it will not cut low enough.My murray will scalp ground if i lower deck to ground.It looks like the blades are designed to be set higher off...
Low under the steering wheel there may be an adjusting knob. If it is there are you turn it, it should adjust the height of the deck. If you lower the deck and try to turn the knob it will be difficult to turn and you will know that is what it is for, the deck lower stop. Then pull up the deck and adjust a bit and lower the deck and see where it is, repeat until satisfied with the deck height when lowered.
Sep 20, 2011 | Husqvarna Lawn Tractor - 54in. Deck, 26...
How do i adjust the deck on my toro lx425 riding mower? it is cutting the grass too low.
Jul 15, 2011 | Garden
I want the length of my grass taller. How do I adjust the blade to achieve this? Or is it the wheels?
Hi, are you saying that you want it taller than the highest blade setting? Meaning the highest notch on the blade height setting lever?
May 06, 2011 | Yard Machines MTD Gold 20 HP Lawn Tractor...
Jul 31, 2010 | Craftsman 20 hp 42 in. Deck Yard Tractor
Mowing the lawn high and low
Mowing the lawn low and hi can only mean where are the adjusters or which is best.
The best height for grass is about 2 - inches for my nickle. There is no best - it is to your taste.
As for adjustments on your unit they are done with the handle that sets your deck height.
Let me know if after reading the instructions you still need help.
thanks
Gary @ Fix Ya
Jun 30, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Hower do you do the adjusting for height on the
The dial only sets the height or the total deck, it is more of a stop than an adjuster.
If it seems too low in the front, you can adjust it by tightening the nuts on the 2 bolts/pins that are attached to the deck and the frame.
First of all, though, check your tire pressures, 10 psi in the rear and 14 psi in the front. If front pressures are too low, this will make a huge difference in your cut. You want to adjust the bolts an equal amount to maintain your side to side level keeping in mind that it should have 1/4 to 1/2 " difference front to rear.
Make your adjustments on your driveway or garage floor so you have a flat level surface to go by.
If you make these adjustments and it still scalps, you will either have to set the deck to cut a bit higher or approach the high spots from a different angle or remember to lift the deck up a bit with the handle when you get to those areas
Hope this solves your problem
Nov 03, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Even on the highest setting, it still cuts too low. can i adjust it to cut higher?
When you put it in the highest setting can you see the deck actually moving in an upward direction? If not the linkage might be broken or damaged. When you raise the deck up or down with the lever it should move, a deck setting in the full up position is a pretty high setting you have to have some long grass to be cutting in the full up position and still think its to short. You might be able to reposition the deck, if when you look under the unit you see a bracket that controls the deck height setting that has a number of holes in it(maybe even 2 brackets), there should be a pin(s) in one of the holes this could be set in a low position and therefore you can change position to change height of deck.
Oct 15, 2009 | Craftsman 42 in. Precision Cut Plus 24hp...
Husqvarna YTH20K46
Is this the first time cutting grass with a lawn tractor?
How tall of grass?
Use the grass cutting heigth adjustments on the tractor to a higher setting when cutting tall grass. Cut again to a lower height setting on the second pass. Grass higher than your tractor is not good for your tractor. Follow the manual instructions for best results.
Jun 27, 2009 | Husqvarna 23 Hp 48" Deck Yard Tractor
Garden Logo
365 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
