Question about Dishwashers
Ariston LSE 730T
My Aritston LSE 730T doesn't start the programs, it tries to push the water but can't do it, and doesn't show any code error in the display can you help me with this problem plz????
4 Suggested Answers
  • 641 Answers
SOURCE: error code AO1
Error message A01 means -Acqua stop operated due to a leak or overfill. Check if there is still water in the machine after it stop pumping. In case you still have water - your problem is with the pump or with a blockage drain line. If there is no water in the machin, it might be a water level sensor issue - stuck physically in the high level position or become defective. Try to reduced the water presure and leveled it up by the water entrance tap to the machine, it might solve your problem. Goog luck !!
Posted on Jun 27, 2006
Daniel S
  • 4323 Answers
SOURCE: hello, i have an Ariston LI
Hi
If the water inlet valve is fine and it fills with water then the issue seems to be with the float switch assembly that is bad and should be replaced. Float assembly is found inside the dishwasher's tub, on the bottom. The water that fills the dishwasher lifts the float, and when it reaches a certain level, it acts as a trigger for the float switch. The float triggers the float switch to shut off, thereby shutting off the flow of water into the dishwasher. A defective switch may interfere with dishwasher's filling and/or draining ability. Use voltmeter to test the switch. Set the device to the ohms setting x 1. Take each probe and touch them to one switch terminal each. This should produce a reading of either zero or infinity. Continue to touch the probes to the terminals, and press down on the switch's button. The reading should change to the opposite extreme. If the switch fails either of these tests, you should replace it. Hope this helps...please post back for further assistance.
Daniel
Posted on Aug 15, 2011
  • 867 Answers
SOURCE: Sanyo dishwasher doesn't fill. No error codes showing. (It thinks it is filling)
This is most likely either a broken solder joint in the control panel or a defective inlet solenoid.
Posted on Mar 12, 2012
Lcode 1 flashes and drain pump doesn't stop
The flash code means there is water in the base panel underneath appliance first check the support on your lower arm isn't loose then leave to dry out
Jan 01, 2013 | Hotpoint-Ariston LFT 321HX Dishwasher
My Hotpoint Aquarius WD420 does not wash properly. It doesn't seem to take in any hot water and the drum does not turn, it just sways from side to side and does not move on from wash to rinse and spin....
For those problems, you have multiple issues and need a service engineer. It may be just the hot water intake solenoid, but may also be a problem with the logic board or both.
Nov 13, 2017 | Hotpoint Ariston Aquarius WD420 Front Load...
Hello! We have Ariston AML 125. We've been using it for 5 years now and before we didn't have any problem. But just a couple of days, the drying program doesn't work properly. The washing...
Sorry but you have not mentioned whether you were able to check the function of the drain motor itself- it could be blocked/jammed which would account for the machine not stopping (still trying to drain but being unsuccessful). Soaked clothes take ages to dry in a dryer!
Following are my complete and hopefully 'coverall' pre-typed guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Aug 27, 2011 | Washing Machines
Hi,I got an Ariston Margherita 2000.It does work well,but the end of the cicle the water doesn`t dissapear from drum.I tried everything,but nothing happend. Many thanks. Zsolt
Hi Zsolt!
The problem can have more causes:
1. At the lower part of the machine is a kind of filter for the dirty water. It is possible it need to be cleaned, a lot of stuff can be stucked there. To get to the filter you have to remove the pannel from the front lower part.
2. The used water pump itself can be the problem, then it need to be replaced.
3. The command unit doesn't work properly so the pump for draining the used water does'n start.
It is quite simple to determine if this pump is starting or not, because it makes during running a tipical sound.
Hope it helped.
Regards,
Bogdan
Aug 21, 2011 | Ariston Technologies Washing Machines
Hi, I have an Ariston LL64 model dishwasher that doesn't complete a wash cycle. It gets so far and stops with the "crystal care" light flashing. Any ideas? thanks Barry
It is possible that the machine does not start off the cycle because there are errors or feedback from the inputs. For the program to start up the main program controller must initiate the INLET/PUMP MOTOR/DRAIN to work when it is commanded .If this does not happen then the voltage at these points must be checked or the fault relates to no voltage/drive from the controller. This means the controller is a suspect.
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor. The water pressure must be good and the spraying must be seen to be good. If not the pump must be checked for clogging.
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the drain valve/pump activated so as to drain off all the water.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
http://www.espares.co.uk/advice/dishwashers/a/3
Aug 03, 2011 | Ariston Technologies LL64WNA Built-in...
Fdd914 dishwasher error code A10 appears and its not in the booklet
Hi, the interpretation for error code A10 is: A10 = fill solenoid valve triac closed/open circuit - check valve/ operation - machine drains until level switch resets + 30"
Now, to try and solve the problem yourself: Turn off the water supply to the dishwasher & remove the hose, Run the machine for several minutes in a normal position. Turn the machine off, reconnect the fill hose, turn the water back on then turn the machine back on.
If this doesn't solve the problem, then you'll need to call a service person.
Jun 12, 2011 | Hotpoint-Ariston FDD914 24 in. Built-in...
Hotpoint wt740. When starting a wash cycle the machine tries to fill but shows the H20 code and the water goes straight out of the drain tube (it appears to have normal pressure and flow rate).
Indesit (Hotpoint, Ariston) Error code H20
(Quote)'If the machine is not in the demo mode and this error is displayed it means there is no water being supplied to the machine.
To cancel press and hold start/cancel then press again to cancel the drain and the machine should now be reset and display 'ON' as usual.'(unquote)
John C.
Jun 04, 2011 | Washing Machines
Ariston LSE 730 T dishwasher displays an erro ao1 watt is this?
A01 means The micro-switch in the base tray has been closed for 9 seconds to signal the alarm.
Water is leaking from components or hoses in the base of the machine.
Programme will abort and the drain pump will be energised.
Dec 21, 2009 | Ariston Technologies Washing Machines
Dishwashers Logo
Top Dishwashers Experts
