Question about Arctic Pro YPC-07C Faac7 Portable Air Conditioner
Need a new vent hose
After only a couple of years, the vent hose on this unit cracked and basically disentegrated. Can I get a replacement?
I have a unit with no exhauste hose conecter and no nozzel fitting covers or a window panel
Sadly this company seems to be out of business and parts unavailable. You can get vent hose at lowes. I attached the hose to a unit with a couple of small metal brackets, zip ties and vent tape. For the window part, I cut a piece of plywood, painted it white and cut a hole for the vent hose. Attached it with zip ties and silver vent tape.
May 24, 2012 | Windchaser PAC9 Air Conditioner
Could you tell me someone that sells a replacement vent hose for the Newair AC10000E portable air conditioner? Mine cracked last year. If I need to buy a whole new vent kit that would be acceptable.
If you cab salvage a few parts, you won;t have to purchase an entire new vent kit. You can find similar vent hose at any home center in the heating and cooling dept. Just take a piece of your old vent hose with you and match it up to one that same diameter. You can use your old termination and connect it to the new hose. You can do all of this fairly inexpensively.
Hope this helps and saves you a few $$ at the same time.
Apr 19, 2011 | NewAir Heating & Cooling
Fuel leaking at the fuel filter attached to fuel line outside of fuel tank . The little niple that the fuel line connects to, that has a filter at the end. This is on my model 345 HUSQVARNA chain saw....
The fuel tank vent is whats leaking.Some saws that have primer bulb set up were sent from factory with the primer return hose not being long enough so it will either come off or break at the tank vent/filter.I have seen some saws leak around the tank vent when temps are below 10 degrees F due to tank plastic distorting from the cold weather.
Feb 22, 2010 | Garden
Leaking out of the bottom, it seems to be coming out of light blue unit that has 2or more hoses coming out of it. was stored out side for a couple of years
This sounds like the water solenoid had remaining water in it and froze resulting in cracking the plastic. Water expands as it freezes and will crack the valve. Replace the valve units.
Jan 02, 2010 | Kenmore Refrigerators
Loud rumble sound, Vent hose vibration
That model of neptune dryer had a problem with the blower housings cracking. When the housing cracks, it binds forward into the blower wheel making a loud "rumble" noise and vibration. If you open the door and manually turn the drum and you hear a rubbing noise and feel alot of resistance, then you have a cracked blower housing and need to replace it. It is not an easy job to replace, so if your not familiar with dryers, you should have a technician replace it. Let me know if you have any further questions. shane
Oct 01, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Ice on the hose and not very cold
It does sound like it is losing charge. Unfortunately, most window units don't have charge ports. And the price you pay to have a guy put a port in and charge it would be more than the cost of a new unit
Jun 23, 2009 | Whirlwind FH-778 Air Conditioner
2004 explorer sunvisor support cracked...disentegrated!
car-part.com for used or tascafordparts.com for new at discount
Jun 10, 2009 | 2004 Ford Explorer
Need to replace gas line on Sears Craftsman 2 cycle blower
Hello pgtoepel:
The Following is a Basic Instruction File I made for Replacing the Fuel Lines and the Filter on Chain Saws and Trimmers. Any Input is Appreciated.
>>The Fuel Line is Pushed and Pulled (I Use Long Needle Nose Pliers) Through the Small Hole Until the Hose is Out the Fill Hole about a 1/2".
>>You can Also Use a Coat Hanger with a Small J at the End to Hook the Filter in the Tank and Pull the Filter and Hose (if Detached from the Carburetor) Out the Tank Fill Hole Enough to Replace the Filter.
>>Then Attach the Filter and Pull the Hose Back Until the Filter Lays at the Bottom of the Tank Just Below the Fill Hole (or so it is in the Bottom of the Tank and will Rest in the Fuel Mix when Turned at Common Angles the Unit May be Turned to During Operation.
>>**Hint: Use Plenty of Spray Lubrication at the Small Hole as you are Feeding in the Hose. It Slides Easier.**
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
May 14, 2009 | Craftsman 4 Cycle Blower/Vac
The regulatory is making a hissing sound from the vent hole; can I adjust it to stop the sound or does the unit need to be replaced. The unit is about 10 years old
The gas could be leaking from the threads or the hose. Get a spray bottle with soap solution (Windex will work too) , turn on the gas (outside only) and then spray the hose or fittings in the suspect areas. If bubbles appear in an area other than the threads, you will probably need to replace the hose.
The usual source of leaks is where the hose is cripmed onto the fittings with the threads. If the threads only are leaking, the fitting can usually be removed, treated with a pipe thread sealing compound (available at most hardware or home improvement stores) and then re-assembled.
Whichever method is used, check for leaks again after the repair is complete.
Be careful
Apr 18, 2009 | Thermos Stainless Steel Gas Grill
Arctic Pro YPC-07C Faac7 Portable Air Conditioner Logo
42 people viewed this question
Top Arctic Heating & Cooling Experts
Tom Chichester
Bill Boyd
Thomas Woodburn
Thomas Woodburn
Are you an Arctic Heating and Cooling Expert? Answer questions, earn points and help others
