Question about Electrical Supplies
Instructions for IQ group BQRFDCRXW pir alarm
I have lost my instructions for the IQ group 4323 15 type BQRFDCRXW pir alarm. I have changed the batteries in the chime sensor and it wont stop chiming and sending the signal to the light which then flashes. I can turn off the light but I need to know when someone is on my drive.
  • 3 Answers
SOURCE: Turn off hourly chime
switch to alarm mode and use "C" the select button to switch it off.
Posted on Jan 19, 2009
SOURCE: Seiko Westminster Chime Clock; Model No. QQF150G Caliber 12105
Does this help
http://www.theclockdepot.com/seiko_westminster_clock_instructions.html
Posted on Apr 22, 2009
SOURCE: I need instructions for Athletic Works AW60442W
hold bottom right button, press bottom left button. if all the days of the week are highlighted then your chime is on, if not your chime is off.
Posted on Aug 01, 2009
SOURCE: Coleman wristwatch - alarm and chime keep beeping
Hey, I had the same problem with my Coleman watch. It would alarm at midnight. I used the mode feature like the poster before me said. When I got to the alarm "screen" I used the button that backlights the watch's screen. The light came on and the alarm feature was removed. I hope this helps.
Posted on Jul 06, 2010
Hello I have my veritas security alarm ringing and it won't stop ringing after we put the reset code.something blew off while the electrician was fixing a fuse in the utility room
Looks like a blown fuse if you have pir detectors make sure that they are working, if not change the aux fuse in the control panel.(blown).Must be same type as original
Also check the power light on the main panel,or keypad.
Jan 02, 2018 | Cars & Trucks
Where can i get a instruction manual for the iQ sound iQ-4006?
I can only suggest that you contact supersonic
http://www.supersonicinc.com/Technical_Support
I can't find a manual for this exact model on-line
12.May.2014
May 12, 2014 | Supersonic IQ-4006-RED Sound MP3 Player
Reset instructions for PIR floodlight
There should be a screw adjustment under the PIR unit. Clockwise direction increases the amount of time it stays on and anticlockwise decreases the amount of time it stays on. It's usually a small hole which you can see a slot in which you turn with a screwdriver.
Nov 24, 2013 | Televison & Video
LINTECK LS400 WONT DISARM
You have most likely "bought a duffer" I have 30 years experience with alarms.
!. Remove the internal battery, power down the panel.
2. leave "dead" for 10 minutes.
3. reinstate the power, Mains first then refit battery (Make sure terminals are correct for each wire)
4. Retest.
If the above does not work give Lynteck a call on
  • 01282 717 490
  • email sales@lynteck.co.uk
Mar 05, 2017 | Home Security
Phantom bell rings on Siemens wirreless door bell chime jsjs-204, I do not have instructions
You may need to change the frequency of the chime. In this model, you need to remove the batteries from the receiver unit and wait for a while. Then replace the batteries. The doorbell unit should automatically set itself to a different frequency once you press the button, which will(hopefully) solve the problem.
It seems impossible to find the instruction manual for the doorbell. But see http://oddsnsods.net/blog/?p=68 who had a similar problem with a different Siemens model, which works on the same principles. (I can't seem to be able to remove the battery from the door bell unit on the jsjs204, but it reset itself after changing the batteries in the receiver).
Nov 01, 2011 | Desa International White Wireless Plug In...
Scurity penal temper
seems one of your tamper swicthes has been activated,you should be able to isolate which one is needing attention and mute the sounder too
It is common for the tampers to fail in very moist conditions ie outside siren boxs exposed to the elements or a rodent has chewed thru your wiring
i could be a simple as a spider sitting on the tyamper switch in side the box.
If your alarm is monitored then you will have to call an alarm company to fix this for you unless you have the right skills to trace isolate and repair this problem,
May 26, 2010 | GE Security GBC-PI-950-P5 Pir Camera...
Hi Liam here I just installed a networx nx4 and when powered up key pad has 1,2,3,4 flashing rapidly with service light on I was able to get rid of service light but zones still flashing And there is only...
This could be a supervision problem. If zone expanders, gsms, keypads, etc. are added to this alarm panel, you must enroll the device with the control panel. This is done by entering into programming mode ( * + 8 + {go code} ) and then simply exiting programming mode by hitting the exit button. The GE NetworX control panel and it's affiliated compatible devices will auto-enroll after about 15 seconds. The default 'go' code is 9713, but this is usually changed by the alarm company installer.
Apr 21, 2010 | General Electric GE NX-591E-GSM NetworX...
Electrical Supplies Logo
87 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
