Question about Polaris 380 In Ground Pool Cleaner
Polaris 360 leaks at swivels in the hose - Polaris 380 In Ground Pool Cleaner
    Top Expert:
  • Polaris Master
  • 6,514 Answers
Replace swivels
Posted on May 22, 2016
Polaris moves slow
see if good pressure from wall if ok check back up valve for leaks or swivels if ok take apart and check belts and hoses
Nov 10, 2013 | Polaris 380 In Ground Pool Cleaner
Polaris 3900 slow
Check your in-line filter screen for debris, and the wall fitting, the backup valve, and swivels for leaks. Otherwise you make have a blocked drive jet, or an internal hose came loose. A local pool store should have a pressure stick they'll lend you to verify proper psi at the end of the Polaris hose.
Mar 07, 2013 | Polaris 3900 Sport Automatic Pool Cleaner ...
My Polaris 3900 that I bought today is not moving fast enough. There is no blue restrictor cap in the wall.
Check your filter, pump, and debris baskets for excessive waste that could decrease the pool cleaners water flow. Check the hoses, hose connections, and swivels for leaks that could cause loss of water pressure. Check your wheel RPM. If it is below 30, you will need to incease the water pressure. If you have an adjustable return valve, make sure it is open all the way. Also, make sure that your pump is working properly.
May 28, 2011 | Polaris 3900 Sport Pool Cleaner ()
No My polaris hose keeps getting tangled up, how do I fix it.
Remeasure the pool cleaners hose to verify that it is adjusted to the proper length for the pool shape. With the Polaris operating, check that the swivels in the hose and the hose connections turn freely. Make sure feed hose is floating.With the Polaris turned off, spin each of the wheels. All wheels should turn together.
Nov 13, 2010 | Polaris 280 Black Max Pool Cleaner with...
My polaris only runs a short time and then just stops
With these pool cleaners, make sure that you check the filter screen in the filter and clean it if necessary. Clean the skimmer basket, pump basket, and pool filter. Check all of the hoses, connections, and swivels for leaks that could cause loss of water pressure. Make sure that your wheel RPM is correct.
Sep 12, 2010 | Polaris 280 In - Ground Pool Cleaner with...
The wheels are not moving when hooked up, When i move one manually they all move. i made sure the pool filter basket is clean and the water pressure going into polaris seems like it is strong.
Also check the skimmer basket and pump. Make sure they are functioning properly. Check all hoses, connections, and swivels for leaks that could be causing a lack of water pressure in these pool cleaners. Make sure that your wheel RPM is between 28 and 32. Increase the pressure to create more RPM.
Aug 29, 2010 | Polaris 380 In Ground Pool Cleaner
My no flow light is on and the polaris won't move
Check all of your hoses, connections, and swivels to make sure that you do not have a leak. Also, check for obstructions in all filter baskets, pumps, debris chambers to make sure that nothing is obstructing the flow. You might also need to increase or reposition your thrust jets. These are pretty common problems with these automatic pool cleaners.
May 13, 2010 | Polaris 380 In Ground Pool Cleaner
Unit moving very slow
Check your finger screen just inside the wall of the pool. Pull your hose out of the water and be sure you don't have any leaks at hose swivels or in the hose itself. If this isn't it then you should take your head into a store and have them check it out for you.
Mar 03, 2010 | Polaris 380 In Ground Pool Cleaner
Having problem with polaris 380 not moving. just replaced back-up valve and having a different problem. there are three small devise on hose that are spraying water.
If the wheels are spinning independently you have broken drive belts. The hose swivels are leaking also which could lower the pressure to the head.
Jul 08, 2009 | Polaris 380 In Ground Pool Cleaner
Polaris 380 In Ground Pool Cleaner Logo
151 people viewed this question
Top Polaris Pool & Spa Experts
Jay Finke
Jay Finke
David Spradling
David Spradling
Michael Vincent Cruz
Are you a Polaris Pool and Spa Expert? Answer questions, earn points and help others
