Question about Worx (16") 3.5 HP Electric Chain Saw - WG303
How do I tighten chain after removing the cover
    Sergeant:
  • 458 Answers
All the saws I use that do not need the cover removed to tighten the chain. If the tightening parts are in the cover you can't adjust the tension with the cover off Other saws the pin is on the saw side To tighten the chain there is a pin that fits into a hole on the bar. Turn the adjusting device to move the bar forward to tighten the chain. If you get it too tight it will not move.
Posted on Jan 27, 2014
How do you fix the chain
Remove cover on the chain side of the saw. Loosen the two hex nuts that hold the bar onto the saw. You will need to loosen the tightener screw also. Place chain back onto the bar making sure the chain is positioned properly in the sprocket at the rear of the bar and just reverse the directions. Tighten the tightener screw until the chain is tightened leaving a little slack, then tighten the two hex nut. Replace the side cover. When you pull the chain down away from the bar, it should have just a bit of slack not tight. This allows the chain to turn without a lot of friction. I hope this helps.
Jan 26, 2014 | Homelite Garden
Manual ryobi chainsaw
Chain replacement is basically the same on all chainsaws. Loosen the side retaining nuts on the cover over the chain. Now loosen the chain tension screw ( usually a flat headed screw) at least 4 full turns. Put the saw on its side with the blade up. Remove those side cover nuts and the side cover - the blade should sag as you remove the nuts. push the blade towards the engine, paying attention to the direction of the teeth on the chain. remove the chain and clean out the junk from behind the chain around the sprocket and from the inside of the side cover. The emergency brake band is located inside the cover - make sure you clean out the debris from around the band, tensioner screw assembly, and cover. Re-install the new chain, orienting the teeth in the correct direction. Re-install the side cover, making sure the tensioner pin goes into the hole in the bar ( blade). Slightly tighten the side nuts, then re-tension the chain until you can just pull the teeth off the bar. tighten the nuts, being sure you don't over tighten them ( a little past snug is good). Run the saw for a few minutes ( doing 1 cut will speed this step along). Loosen the side cover nuts and re-tension the chain, the re-tighten the nuts.
Hope this helps!!
Nov 26, 2013 | Garden
Cam chain tensioner tighten
Remove the tank to access the top cover of the engine so the chain is accessible, hold the adjuster bolt, loosen the lock nut, then carefully take the slack out but not too tight, then tighten the lock nut to secure the assembly. replace the top cover gasket and the cover, and re-install the tank.
Sep 13, 2013 | 1995 Suzuki RF 600 R
I have a 358351610 chain saw and need to find out how to remove the chain
Set the chain brake to off, then remove the fasteners on the right side cover where the chain drives from. This will release the bar which will slide back toward the engine and allow the chain to be removed. Note the direction of the cutting edge of the teeth. Clean everything including the two small oil passages that run from the large holes in the bar out to the chain groove on each edge of the bar. When refitting a new chain, back off on the chain adjustment screw (CCW) a few turns to allow the cover to fit to the bar properly. Fit the chain over the clutch sprocket, then insert the bar to the engine. Work the chain over the bar, then pull the bar outward to tighten the chain. Install the cover and the fasteners finger tight. Make sure the cover fits the bar properly. Tighten the chain adjuster CW so that the chain pulls up to the lower bar edge, but not so tight that you can't turn the chain by hand. Tighten the cover fasteners, then recheck the chain tension. The lower run of chain should be cutting as the chain moves toward the engine. Check the chain oiling by running the saw at speed with the bar tip near some cardboard--it should throw off a thin line of oil after several moments. Hope this helps!
Dec 19, 2010 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
How do you replace chain on stihl farm boss with 20 inch bar
Take the side cover off.there should be two nuts holding it on.you can lift the bar and remove chain.put new chain on.you might have too take a screwdriver and adjust bar adjuster too put bar and chain back on.replace cover and snug up nuts.adjust the bar to tighten the chain and then tighten nuts on side cover.
Dec 08, 2010 | Garden
How to replace a waterpump on a 2001 olds alero 2.4 cam
Water pump is driven by timing chain idler and is mounted on the rear of the timing chain housing. Disconnect the neg. battery cable. Drain cooling system. Disconnect oxygen sensor connector.
Remove upper exhaust manifould heat sheild. Remove exhaust manifold brace. Remove lower exhaust manifold heat sheild. Loosen manifold to exhaust manifold spring loaded nuts. Remove radiator outlet pipe to water pump coverbolts. Disconnect exhaust pipe from manifold.
Pull down on the exhaust pipe to disconnect it from exhaust manifold bolts. Disconnect outlet pipe from oil pan and transaxle. If equipped with manual tranaxle, remove exhaust maifold brace. Leave lower radiator hose attached and pull down on radiator out look pipe to disengauge from water pump. Leave outlet pipe hanging.
Lower vehicle. Remove exhaustmanifold to cylinder head nuts. Remove exhaust manifold to cylinder head nuts. Remove manifould. Remove timing chain front cover. Remove timing chain tensioner. Remove bolts bolts securing water pump cover to cylinder block. Remove water pump to timing chain housing nuts. Remove water pump attaching nuts. Remove water pump and cover assembly. Separate componets as necessary.
WHEN INSTALLING WATER PUMP MAKE SURE YOU FOLLOW THE TIGHTENING SEQUENCES THAT AFFECT SEALING. My frist one I messed up and broke the pump so becarful.
Installation
If cover was separated from body during removal, join this componets with a new gasket and hand tighten bolts. Apply bearing grease to splines of water pump drive. Set body and assemble into position.
Install and hand tighten bolts securing cover to cylinder block. Install and hand tighten bolts securing cover to cylinder block. Installand hand tighten nuts securing body to timing chain housing. Lubracate outlet pipe "O" ring with antifreeze. (I use RTV) Connect outlet pipe. Install and hand tighten bolts. Tighten bolts and nuts to specification in the following sequence. I'll ad the torque spec. at the end but this is where if you tighten out of order something will break.
pump assembly to timing chain housing nuts.
pump cover to pump body bolts
pump cover to cylinder block bolts (Bottom Bolt First)
outlet pipe to cover bolts
To complete installation reverse removel procedure.
Torque specs are 19 in. or 26mm all except water pump cover bolts which are 124 in or 14Nm
I never torque the bolts just make sure there done in the right order.
Oct 19, 2010 | Oldsmobile Alero Cars & Trucks
What is the right way to time a 4cyl Chevy S-10 timing chain
1998-2003 To Remove:
  1. Remove or disconnect the following:
    • Crankshaft pulley and hub
    • Timing chain cover and gasket
  2. Install a bolt in the end of the crankshaft CAUTION
    Do not install the crankshaft balancer bolt or a bolt longer than 1 inch or damage to the crankshaft threaded hole will result.
  3. Rotate crankshaft until the number 1 piston is at Top Dead Center of compression stroke.
  4. Make sure that the alignment marks are aligned with the tabs on the timing chain tensioner. gm-03-22-611.gif
  5. Measure distance between hole in bracket and unworn surface of timing chain tensioner shoe. NOTE: If distance between the hole and unworn surface of timing chain tensioner is greater than 0.314 in (8 mm), replace tensioner, timing chain and sprockets.
  6. Remove timing chain tensioner bolts.
  7. Remove the timing chain, timing chain tensioner and camshaft sprocket at the same time.
  8. Remove the crankshaft sprocket using special tool J 22888-20A or equivalent.
  9. Remove crankshaft sprocket alignment key.
NOTE: If any camshaft components are being replaced to correct a noise problem, all camshaft drive components must be replaced.
To Install:
  1. Install the crankshaft sprocket alignment key.
  2. Install the crankshaft sprocket using special tool J 5590 or equivalent. gm-03-22-613.gif
  3. Compress the timing chain tensioner spring and insert a pin into the tensioner hole to retain the tensioner shoe.
  4. Install timing chain and timing chain tensioner (do not tighten tension bolts).
  5. Align the crankshaft and camshaft timing marks with the tab on the timing chain tensioner.
  6. Tighten the timing chain tensioner bolts.
    • Torque to: 18 ft lbs (24 Nm)
  7. Tighten the camshaft sprocket bolt.
    • Torque to: 96 ft lbs (130 Nm)
  8. Remove pin from timing chain tensioner hole.
  9. Remove bolt from end of crankshaft. CAUTION
    Inspect the timing chain cover for warping or damage. Replace if needed.
  10. Clean all timing chain cover mating surfaces.
  11. Install or connect the following:
    • Timing chain cover to the engine block
      1. Ensure that the gasket is installed properly in the groove in the timing chain cover
    • Timing chain cover and make sure it fully seated on the alignment dowel pins
    • Timing chain cover bolts
      1. Torque to: 97 inch lbs (11 Nm)
    • Drive belt tensioner
    • Crankshaft damper hub and the crankshaft pulley
Aug 17, 2010 | 2000 Chevrolet S-10
Cannot move the chain by hand after the bar has been tightened.
First be sure the chain is on going in the right direction. When looking at the bottom of the bar the sharp tooth should be going towards the motor. When you put chain back on are the chain teeth properly engaged in the sprocket on the motor. Remove the cover again, check that teeth are in sprocket. Make sure pin from adjuster screw is engaged in the hole in the bar. Before you tighten the cover bolts, make sure chain will turn by hand. If not adjust the adjusting screw. Once adjusted, tighten cover bolts. Check again after tightening bar.
Jul 04, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
How to replace chain on eager ****** chainsaw
Remove the side cover on the saw Should be 2 nuts on studs
Either in the front between the bar and the saw body or in between the nuts on the side is a chain tightener. Use a flat bladed screwdriver to loosen the tightener and remove the chain from the drive and the bar. NOTE the direction of the chain teeth.
Replace with new or sharpened chain Reinstall the side cover Install the nuts DO NOT TIGHTEN just snug to contact Adjust chain to where you can just pull the chain free of the bar at the center of the bar length Tighten the nuts
Happy cutting!
Coyote
Mar 31, 2010 | Garden
Had plug in saw 2 weeks and it dose not work /// it spins but dose not move blade just loud clicking noise
ok i assume it is an electric chain saw? chain usually gets loose and can jump off clutch sprocket . to remedy this there should be atleast one nut or bolt sometimes two nuts or bolts depending on brand and model on the side cover where bar and chain inter the clutch area remove those and cover will lift off second there is a screw that faces front next to bar should be a regular slotted screw head loosenit all the way up till bar gets loose and remove bar by pulling away from saw this will come off veryeasy and chain shoouls fit on teeth of clutch sprocket and fit back onto bar tighten screw till chain tightens up on bar then replace cover and nuts on side cover but do not tighten the with one hand put tension on chain by pulling down on it while tightening screw till chain feels elastic snapping back to bar then toghten up nuts . chain should have no more then 1/4 inch slack around bar this is the correct tension youshould maintain.
Mar 18, 2010 | Poulan Garden
Worx (16") 3.5 HP Electric Chain Saw - WG303 Logo
262 people viewed this question
Top Worx Garden Experts
Tim Whalen
ray gallant
Wayne McNeil
Are you a Worx Garden Expert? Answer questions, earn points and help others
