Question about Poulan WEED EATER PE550 711431 22CC 2 Cyc Gas Edger
How to thread pull cord to fix a broken cord - Poulan WEED EATER PE550 711431 22CC 2 Cyc Gas Edger
How do I fix my singer.
the problem most likely is thread tension possibly on the upper thread
It is not pulling the thread up from the bottom allowing the bottom thread to become tangled
Apr 30, 2015 | Singer Sewing Machines
Pull starter string is broken
Hi ed this is a time consuming one. Firstly remove the starter head and turn it over. Then by hand turn the cord holder anti clockwise by hand until the spring inside cant turn no more. Get some one to hold the whole lot and then try and thread the new string through until it goes through the hole in the pully. When its in Tie a big knot in the end and then pull the cord down so its tight. Release the cord pully slowly and it should retract back in with the strength of the spring. This should fix it.
Sep 23, 2013 | Briggs & Stratton Garden
Need to replace broken pull rope
you will need to remove the four bolt on the shroud, and the one on the oil stick. Once the bolts are removed tip shroud upside down and wind clockwise/counterclockwise which ever put tension on the pulley, then wind it six or seven times, line the two holes up, the one the cord goes through the outside and the one on the plastic piece inside the shroud, pull the cord through, let go and it will wind, tie a knot on the one on the inside of the shroud and singe the end of the knot. Pull on the cord a few times to make sure it going to hold, put shroud and oil stick back on, thread cord through handle. Hope this helped Tim
May 22, 2011 | Garden
I have a craftsman push weedeater and the pull cord broke and I want to know how to reinstall so the cord so it will work. I have taken the cover off and fixed the cord and put everything back together but...
you will need to pull the shroud back off, turn shroud upside down, wind it up and with a screwdriver or another pair of hands thread the cord back through, tie a knot and burn it, let go of the it, it will wind the cord back in, pull on it a few times and make sure it is working, then reinstall. Hope this helped Tim
Mar 12, 2011 | Garden
I have an old radio with a dial tuner that has stopped working. I've opened it up and found the thread that goes around the spindle is broken. I could replace that but I can't figure out the route the...
The thread is called teh dial-cord and should be replaceable even with a heavy carpet thread. You are correct in that the routing is critical. There should also be a spring on at least one end of the cord. If the cord has just broken, you should be able to see the current route and jsut follow that route with the replacement cord. Get the cord tight with some tension on the spring. The spring should be able to take up any slack that occurs if the thread stretches a bit.
Dan
Oct 05, 2009 | Audio Players & Recorders
Broken recoil start on tecumseh 6.5 hp
broken cord? remove bolts holding recoil housing.lift housing straight up,you may have to wiggle it a bit.turn housing over,remove any cord thats left,note how & where it connects to the spool.wind the spool [and consquently the spring under it]in the direction the cord would turn it as pulled when starting.hold spool tight.thread new cord through hole in housing.let spool turn back just enough to attach new cord.hold cord & housing,let spring "re-coil" cord slowly.check for smooth operation.replace housing.you may need to pull cord slightly to align 'square' shaft w/hole in spool.only after you are satisfied with the operation of it adjust length of cord by pushing excess cord through the handle,tie a new knot,then cut off excess,if any.
Sep 21, 2009 | Garden
How to sort broken pull cord on petrol strimmer
Hi Baz, i will tell you a generic way of doing this as i don't know the model of your strimmer.
on the pull cord housing you will have 3 or 4 screws to secure the housing to the motor body, undo these. the housing will lift away from the main motor body, underneath this cover you will see a spring canister, there may be a screw or clip keeping this in place or some are just secured with the outcover. remove this canister you should see a coil spring in the middle and a groove around the outside where the cord goes. you should see a knot inside the cord grove where the cord is threaded through to secure, remove thisand remove old cord. Now the trickky bit! some times it helps to have a helping had, you will need to turn the coil spring so it tights up to its full tightness, then thread the new cord into the secureing hole where the old cord was located, then when you release the spring this will coil the cord round the cord groove. replace the pull handle on the end of the cord so there is no slack and replace on to motor in reverse order. Hope this helps.
Sep 04, 2009 | Ryobi ZRRY30550 Factory-Reconditioned 30cc...
Replacment of starter pull cord
Remove the recoil cap cut the knot of the old cord off pull out the string. Cut a new cord the same length thread it in and knot it . rewind the spool until the cord in the spool. fish the cord out of the pull hole and tie on the pull handle
Aug 04, 2009 | Ryobi Factory Reconditioned 18" 40cc...
Broken pull cord. how do i get to the inside to fix it?
you need to take off the top cover. there are about 4 to 6 bolts to remove. the pull cord and winder will be under top cover
Jul 25, 2009 | Poulan Garden
Troy Bilt Lawn Mower pull Cord broken
there should be four bolts holding the cover on that houses the pull cord assembly take the bolts out look inside you should see the rest of the broken cord at the other end there is a spool that the cord rolls up in to pull the cord until it stops the other end of the cord is a not in the cord pull on the knot the broken peice should come out turn the spool 2 times in the direction that is against the pressre while holding the spool in place feed the new cord in through the whole that you pulled the broken cord out of then tie the cord in a knot wind the rest of the cord up then feed the other end of the cord through the new pull handle tie the cord in a knot put the housing back on
Mar 21, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Poulan WEED EATER PE550 711431 22CC 2 Cyc Gas Edger Logo
18 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
