Question about Acer Aspire 3680 Laptop
Trying to do a repair installation
My acer laptop showed the BSOD screen, I tried all teh options available, last known godd fig, safe mode, start widows as normal etc but they dont work, I still see the Bsod screen. I am now trying to boot my laptop from CD, I put the windows boot CD into the laptop. I am now looking at a screen with a number of options. The screen is titled PhoenixBIOS setup utility. The suboptions include Information, Main, Security, Boot and exit. What do I do to repair my PC and keep all my files intact????? Thanks
  • Anonymous Mar 17, 2014
    TI have tried what is builtin.To no good.So please help me!!
    Scholar:
  • 181 Answers
OK, that screen is the bios for the laptop. Don't do anything in there. (except check under boot and make sure the boot order is cd then hard drive) Once the boot order is correct, just boot from the cd rom, and to do a repair, just keep continuing past where you are asked to enter F-8, the next screen will offer a repair for the windows installation- press R. That keeps your files and programs, but reinstalls windows. Good luck
Posted on Aug 11, 2007
SOURCE:
My Acer aspire turns on shows windows logo then goes to black screen, what can I do?
Depending on your version of windows, I would trying starting in safe mode to see if the computer does boot. If it does, then you want to restart again, go to advanced boot options and select "start windows with last known good configuration." Access advanced boot options following the steps at this link. Need to Start Windows 7 in Safe Mode Here How
Jul 18, 2015 | Acer Computers & Internet
Netbook Acer Oner N270 Atom 1.6GHz doesn't start, I tried to run a chkdsk thru F8, but the sistem prompt never shows up when I ran in safe mode with command prompt. Thru F8 i was able to see a while...
Hi
Did you try to go back to last known configuration in the F8 option
or the repair option
failing that try a system restore in the F8 option back to when it was running ok
failing that also you could try to get back into safe mode
go to start run/search box
type in cmd
this Will bring up a black box
type in CHKDSK
that should check disk and hopefully give option of repair disk as well
but it will take some time but be patient
Or try to get to the acer recovery
i have never tried the recovery in safe mode but it hopefully will except it then restart into the recovery management
this is where you find it ( in or out of safe mode )
start programs
acer
acer empowering technology
acer erecovery management
recovery
follow on screen instructions
good luck
hope you get sorted
Feb 18, 2011 | Acer Aspire One AOA110-1588 Notebook
I have an Acer Aspire One with Windows XP and when I turn it on a black screen comes up saying "We apologize for the inconvenience, but Windows did not start successfull..." Then it gives me a list of...
Try to use the last known good configuration the issue should be fixed.. If afforadable try to get a external DVDdrive.. If not try to get one from friends.. Nothing is working.. call acer they will take your computer and reinstall the OS ....
Sep 20, 2010 | Acer Aspire One PC Notebook
STOP: 0x0000000024 that is the error message I am receiving and can't seem to get past the screen that gives you the option to start in safe mode
if this happens when starting to boot to Windows, try last known-good config. When system is restarting, tap F8 a couple of times to get to the Advanced Options menu where Safe Mode is also listed. Select Last Known-Good Configuration if available and press Enter. If this does not work, try selecting Safe Mode. If you can get to Safe Mode, you can try System Restore to a previous restore point available when your system is working properly. If none of the things work, try Windows repair or reinstall. Make sure to try to backup data if you can before doing any reinstall or repair.
Sep 16, 2010 | Compaq Presario Notebook
When i go to start it up, it shows the Windows XP loading screen, then a black then blue screen flash for less than a 1/2 second.
It's called a BSOD which means blue screen of death. try to boot into safe mode by pressing F8 as soon as the computer starts hit it repeatedly, then try last known configuration that worked. If that doesn't work, reboot and try F8 again and go to safe mode, then do a system restore.
May 22, 2010 | Toshiba Satellite A15-S129 Notebook
The ACER Aspire 5610Z is stuck, upon rebooting, on the large ACER Intel window. I push the start button for a length of time, and it won't restart. What else can I do? The problem arose upon a reboot after...
Try booting into safe mode. When the computer is just starting, tap the F8 key and keep tapping it until the safe mode options come up. Select "Last Known Good Configuration" and let it continue booting from there. Once inside Windows, check Windows Update to see if your computer had tried to install update KB977165. This recent update has been known to cause problems in XP, including the dreaded BSOD (Blue Screen of Death), due to malware infections. You may want to try the ESET online scanner on your machine and possibly Malwarebyte's Antimalware, available at www.download.com. Always keep running the scans until your computer comes up clean.
http://blogs.zdnet.com/hardware/?p=7377&tag=nl.e539
Feb 22, 2010 | Acer Aspire 5610-4648 Notebook
Booting problem
You may have to boot from a CD and make a repair.
Once logged in the CD, choose repair option (Recovery Console), and type these three commands:
1) fixmbr (wait til it finishes)
2) fixboot (wait...)
3) CHKDSK (this will take longer than the previous two.
Your laptop may now boot normally. I think your laptop doesn't have an internal CD-ROM so you may use an external USB CD.
Apr 22, 2009 | Computers & Internet
Display problem
next time there are many option beside strat windos normally, first try last known good configuration that worked, if didn't work try saFE MODE AND MAKE SYSTEM RESTORE. GO START>PROGRAM>ACCECORIES>SYSTEM TOOLS SYSTEM RESTORE. you can read about system restore here.
another option is repair windows(you need someone who know to do this or may be try to google it) or last option format it.
Jan 22, 2009 | Acer Aspire 3680 Laptop
Acer laptop with broken screen recovery
press F8 key if u get try to enter in last known godd... also in safe mode change resolution settings to 800*600 or 1024*768.
Sep 29, 2008 | Acer Aspire 3680 Laptop
Acer Aspire 3680 Laptop Logo
167 people viewed this question
Ekse
Alun Cox
