Question about 1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch
Chevy 1500 no spark or dash lights
Turn key no dash lights come on and fuel pump doesnt kick on. It cranks over and over doesnt seem to have spark. Almost like no computer activity
    Scholar:
  • 117 Answers
Check the positive battery cables. There are 2 on the pos side. Make sure both have a good connection. If the one going to the ignition side is bad, the vehicle will crank and not start. If there is voltage close to the battery, check for a bad fusible link in the wire
Posted on Nov 01, 2013
2 Suggested Answers
SOURCE: 1995 Chevy 1500 5.7 v8.
the wire going to the starter is shorting out. probably a bare spot on the wire arking against metal somewhere.
Posted on Oct 16, 2010
Where is the fuel relay switch located on a 2002 chevy Cavalier?
its on the drivers side wheel well. when you pull the cover off there is a sticker in the cover with the layout of all the fuses and relays and each one is marked accordingly.
Apr 12, 2017 | Cars & Trucks
I have a 2005 Chevy impala and My car still won't crank I got fuel pump replaced fuel filter replaced and I have gas in it and it still want start
You say it won't crank , what do you mean exactly ? Does the engine turn over when you turn the key to the start position ? You have crank no start condition or you have a no crank no start condition ! If the engine turns over but does not start , is there spark at the spark plugs ? Did you test anything before you replaced parts you didn't need ? Do you have any lights lit on the dash , check engine , security etc.. No Start Diagnostic Basics EricTheCarGuy
Apr 28, 2015 | Cars & Trucks
What runs the daytime lights, dash warning lights, and fuel pump. these seem to be the factors of why my truck only cranks but doesnt start.
Check all fuses and relay fuses. Then "crack" the fuel line to the injectors and crank to see if fuel is present. If fuel pressure is present, check for spark (Ensure no spilt fuel is around) by cranking with plug lead shorted off the spark plug.
May 21, 2014 | 1999 GMC Yukon
Have a 1999 ford explorer sport 4x4, cranks want start. have replaced fuel pump, crank senser and cam senser, checked fuzes, replaced computer. doesnt seem to be firing
When you turn the key on you should beable to hear the fuel pump come on. Other than that you have a fuel pressure test port, looks just like a tire valve stem get a little probe press the valve after cranking fuel should come out strongly and not dribble out. If is doesnt seem to be firing your going to have check the coil pack for spark from the coil pack take one plug wire out and put it in a position that as you crank the vehicle you will be able to see spark jump or even hear give it a 1/4 air gap from its connection. If you dont have spark and your timing chain isnt broken you need to check for power the choice of tool is a test light.or volt meter. If you dont have either test tool we will go by sound when you turn the key on the engine fuse box has relays do you hear them click. That click noise will be fuel pump relay and PCM relay for power inpect those relays for corrode connections you mainly have a power problem and inspect for proper ground a missing ground can also cause the ECM to not fire the coils2_26_2012_7_32_43_am.gif
Feb 26, 2012 | 1999 Ford Explorer
2002 chevy avalanche died at a stop light and now wont start back up. it just cranks.
Those are known for having the fuel pump go out. Take the gas cap off, open the little steel door with a screwdriver and have someone turn the key forward, not cranking it over, just turn it until all the dash lights come on and see if you can hear the fuel pump kick on for about 2 seconds. You definitely need 2 people to do this. If you can hear the fuel pump then its probally not getting spark.
Jul 10, 2011 | 2002 Chevrolet Avalanche
Exprees van just cranks over
I would chech the ingition module inside the distributor. It's a little black box on the bottom(inside). I'm assuming you have the correct fuel presssure coming from the fuel pump.
Jan 17, 2010 | 1996 Chevrolet Express
2000 chevy venture doesnt start
check to make sure the security light is not on if it is the van will have spark but no injecter pulse the best way to solve this issue is to have the original igniton key and put it in the igniton in the run position and leave it on for 10 minutes then the light will flash then try to start the van
Jul 15, 2009 | 2001 Chevrolet Venture
Engine cranks over will not start
check for fuel and spark could be a fuel pump fuse or relay or ignition module
Jun 03, 2009 | 2001 Saturn S-Series
1997 chevy 2500 4x4 stumbles
Fuel pump is most likely the cause. Probably just barely making the required pressure to start. Needs to maintain 60-66 psi while cranking to start.
Dec 21, 2008 | 1999 Chevrolet Silverado 1500
1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch Logo
44 people viewed this question
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Mike
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
