Samsung le46b530p7wxxu manual
No Warning.Sound but no picture.No screen brightness or display.ound OKon Satelit and Freiew
3 Suggested Answers
joeguest2
  • 2080 Answers
SOURCE: Samsung model: LE46B530P7W, Model code:
Do you mean that your television shuts itself off completely after 20 minutes of working normally?
Does the small power indicator light on the front change color when this happens or does it shut off completely as well?
Does the sound stay on when the picture turns off, or does it go off too?
Can you restart the television right away when this happens, or do you have to wait a while or unplug the set before it will power up again?
Most often, this symptom is a result of a failing POWER SUPPLY, but a bad / overheating LCD CONTROLLER BOARD, or a faulty INVERTER BOARD can certainly cause very similar symptoms. Unfortunately, without a donor TV or a dedicated test rig, it can be very difficult to differentiate between these problems.
One way to test this is to remove the rear access panel on the TV and replace the power supply circuit board with a new one, since this is the most often the source of the trouble.
You can usually find a replacement power supply circuit board on Ebay by searching for your TV's model number. Although I do not see one currently available at this time, the online inventory selection does change daily.
The repair / replacement procedure is not extremely difficult if you have some basic electrical safety knowledge and some basic electronics / mechanical repair skills.
You will need to unplug the power cord from the unit, lay the TV screen side down on something soft and flat like a bed, and then remove the rear access panel or the entire rear cover as required in order to access the circuit boards inside.
When you remove the rear cover and access the circuit boards inside, just check the part number that is printed right on your power supply circuit board itself and confirm that it exactly matches the one provided in the Ebay listing.
Then unclip and remove the various electrical wire connectors leading to the power supply circuit board. Then remove the screws securing the circuit board to the TV frame and then remove the power supply circuit board. Be sure to avoid touching any large capacitors on the circuit board which can retain a nasty charge even after the unit is unplugged.
Then just screw in the new circuit board and connect all the wire bundles to their appropriate connectors on the new circuit board and then replace the rear cover. Then plug in the power cord and test.
If you want to replace the LCD Controller board (otherwise known as a TCON board), the process is not much different except for the connectors which are usually the flat ribbon type.
Please comment back here to this page if you have any details to add, have any questions, have difficulty with the links, or just require further general assistance and I will respond as soon as I see it.
I hope that was helpful to you, good luck.
Joe.
Posted on Aug 08, 2011
Micoman
  • 198 Answers
SOURCE: Samsung plasma appears to overheat and displays
may be the fans are blocked or malfunction.
Don`t continue using if is overheat, you can broken others parts.
I recommend clean the TV, put the blower or aspirator near the vents air (slots for ventilation).
If you can dissamble the TV, remove the fan and check it or replace.
You can buy it at your service center
Is important for people who share their knowledge, know your comments.
If the answer is helpful, rate my answers
Posted on Sep 21, 2011
Problem with LED TV screen
Hi Dale, The link below is a YouTube video showing how to fix a Samsung television NO picture GOOD sound, Also there's videos down the right side of the link that may help as well........CHEERS..
https://www.youtube.com/watch?v=cI2L61dzj6k
Samsung UN46D6000 No picture Sound OK problem FIXED BN95 00497B BN41 01662A
May 11, 2016 | Samsung Televison & Video
When i turn on my samsung pl50, a totally white and bright screen appears and its impossible to view anything on that screen. All other functions are working. Its capturing pictures as well. But the...
Sound like a problem with your LCD screen, related with the CCD Image Sensor; since that you can view mode and setting displays, isnt the LCD screenviewer.
The CCD Image Sensor isnt a job that you can do it, I suggest visit your techinician service or apply if has underwarranty.
Good luck.
Oct 16, 2011 | Samsung SL202 / PL50 Digital Camera
Are ther advanced setting for my samsung pn64d8000 tv?
Unfortunately, the answer is no. Samsung pn64d8000 TV does not have any advanced settings.
I hope this is clear. Please let me know if you have any more questions about this TV.
Regards.
Apr 30, 2011 | Televison & Video
My TT was imported new from Japan....Has AMAZING video and sound system unfortunateley its all Japanese to me!! The manual that comes with it is about an inch think...Its got built in Navigation system...
I know you can that you can change this by simply hooking up a scan tool for specific year. There are language options accessible for situations like this. Here is a sample of what can be changed using VAG 5052 or equivalent scanners.
Coding
  • 0?xxxxx: Model
    • 1 = Lamborghini
    • 2 = Audi A3 (8P)
    • 3 = Audi A4 (8E)
    • 4 = Audi A4 Cabriolet (8H)
    • 5 = Audi A6 (4B)
    • 6 = Audi TT (8J)
    • 7 = Audi R8 (42)
  • 0x?xxxx: Treble Speaker Monitoring inactive
    • 0 = Front Treble Speaker Monitoring inactive active (NOT Audi A4 Cabriolet)
    • 1 = Front Treble Speaker Monitoring inactive inactive (ONLY Audi A4 Cabriolet)
  • 0xx?xxx: Sound Characteristic
    • 0 = Sound Characteristic linear
    • 1 = Audi A4 (8E)
    • 2 = Audi A6 (4B)
    • 3 = Audi A4 Cabriolet (8H)
    • 4 = Audi TT (8J)
    • 5 = Audi A3 (8P)
    • 9 = Sound System
  • 0xxx?xx: Telephone/Telematic
    • 1 = Telephone not installed (Remote Feed Voltage for Microphone active)
    • 2 = Base Plate (Temic - Remote Feed Voltage for Microphone inactive)
    • 3 = Base Plate (Cullmann - Remote Feed Voltage for Microphone inactive)
    • 4 = Base Plate (Nokia - Remote Feed Voltage for Microphone inactive)
    • 5 = Telematic Europa (Remote Feed Voltage for Microphone inactive)
    • 6 = Telematic US (Remote Feed Voltage for Microphone inactive)
    • 7 = Base Plate diagnostic capable with Comfort Control
  • 0xxxx?x: Equipment I
    • 1 = Tuner not installed
    • 2 = Digital-Radio installed
    • 3 = Satellite-Radio installed
    • 4 = Satellite and Digital-Radio installed
    • 5 = Analog Input (AUX) installed
    • 7 = Satellite-Radio & Analog Input (AUX) installed
  • 0xxxxx?: Equipment II
    • 1 = TV-Tuner/CD-Changer/Multi-Function Steering Wheel not installed
    • 2 = TV-Tuner installed
    • 3 = CD-Changer installed
    • 4 = TV-Tuner and CD-Changer installed
    • 5 = Multi-Function Steering Wheel installed
    • 6 = TV-Tuner and Multi-Function Steering Wheel installed
    • 7 = CD-Changer and Multi-Function Steering Wheel installed
    • 8 = TV-Tuner and CD-Changer and Multi-Function Steering Wheel installed
Adaptation Channel 001: Tire Circumference The tire circumference is beeing adapted in "mm".
Channel 002: Wheel Pulse The wheel pulse describes the amount of wheel pulses per revolution.
If value 0 is entered the system calibrates automatically itself after several kilometers and inputs a value.
  • 43 = Audi A3 (8P) / Audi TT (8J)
  • 45 = Audi A4 (8E)
Channel 003: Language (Screen)
  • 0 = German
  • 1 = English (UK)
  • 2 = French
  • 3 = Italian
  • 5 = Spanish
  • 6 = Portuguese
  • 7 = English (UK)
Channel 004: Back-Up Camera
  • 0 = Back-Up Camera not installed
  • 2 = Back-Up Camera installed
Channel 005: Speed Threshold (Video Input)
  • 0 = max. 0 kph or 0 mph
  • 1 = max 5 kph (Standard for Europe)
Channel 007: Options Channel 008: Volume Characteristic Channel 010: Region
  • 0 = Europe/North America
  • 1 = Australia/South America
  • 2 = South Africa
Channel 011: Language (Speech Recognition)
  • 0 = German
  • 1 = English
  • 2 = French
  • 3 = Italian
  • 5 = Spanish
Channel 018: Start Screen The start screen setting has to correspond with the control module coding, e.g. a S3 start screen doesn't work with an A4 coding.
  • 0 = Standard Start Screen
  • 1 = Audi S3 Start Screen
  • 2 = Audi S4 Start Screen
  • 3 = Audi RS4 Start Screen
  • 4 = Audi TT Start Screen
  • 5 = Audi R8 Start Screen
Channel 065: Read Test Channel 066: Self Test Channel 067: CD/DVD Drive
  • 000 - Normal/Eject-Button enabled
  • 001 = Eject CD/DVD (will not be saved)
  • 255 = Eject-Button disabled/locked (Anti-Theft-Protection)
Channel 068: Screen Test Values will not be saved, they only act as initiation for each Test Picture.
  • 0 = No Test Picture
  • 1 = Test Picture: Red
  • 2 = Test Picture: Green
  • 3 = Test Picture: Blue
  • 4 = Test Picture: White
  • 5 = Test Picture: Black
  • 6 = Test Picture: Checkerboard
  • 7 = Test Picture: Checkerboard (inverted)
  • 8 = Test Picture: 64 Gray Scales (vertical Bars)
  • 9 = Test Picture: Special
Channel 069: Display Mechanism
  • 000 = Display closed
  • 001 = Display open
  • 200 = Display half open (Obstacle)
  • 255 = Position undefined
Channel 070: Display Brightness
  • 0 = 0% Brightness (Display OFF)
  • 1 = 20% Brightness
  • 2 = 40% Brightness
  • 3 = 60% Brightness
  • 4 = 80% Brightness
  • 5 = 100% Brightness
Channel 099: Transport Mode Only applies to models without Gateway/Diagnostic Interface for Databus.
  • 0 = Transport Mode inactive
  • 1 = Transport Mode active
Channel 111: Reset
  • To perform a system reset/restart save 1 as new value.
Channel 114: FM Frequency
  • Range: 875...1080
Channel 117: Signal Test (Output)
  • 0 = Fader Center & Balance Center
  • 1 = Fader Front & Balance Left
  • 2 = Fader Front & Balance Right
  • 3 = Fader Rear & Balance Left
  • 4 = Fader Rear & Balance Right
Channel 136: Driver Position
  • RNS-E Basic
    • 03226 = Left-Hand-Drive (LHD)
    • 02632 = Right-Hand-Drive (RHD)
  • RNS-E High/US
    • 00005 = Left-Hand-Drive (LHD)
    • 00013 = Right-Hand-Drive (RHD)
Jul 04, 2010 | 2007 Audi TT
Yellow screen, no picture, but sound is complete
i think maybe the video board...
can you take a picture to be more sure..
thanks!!
Feb 10, 2010 | Samsung LN-T4665F 46 in. LCD Television
I have a samsung that the screen was pink now, black with sound??
What you describe is a classic symptom of burned out fluorescent tubes in the display. I'm assuming this tv is a LCD model...Unseen by the user, there are long, thin, extremely bright, fluorescent tubes along the edges(usually top and bottom) which light up a backscreen so you have a vivid image to look at. (sort of like how a doctor views xray pictures) As the tubes age, they change color and eventually burn out. An excellent example of the same technology is a laptop display or desktop lcd display--same exact design. Hopefully your unit is under warranty because this is an involved repair *if* it can be done. Most often, the whole lcd display unit must be replaced. Definitely shop around for repair facilities if non-warranty is a factor.
Sep 09, 2009 | Hitachi UX21511 Projector Lamp for 50V500
Sound yes, but no picture on tv
If you have sound on the stations this is a problem in the display. Take bright flashlight and hold it against the screen. Look for an image around the edge of the flashlight. If you see an image then it's one of three problems;
1) The inverter board is bad.
2) The CCFT (cold cathode fluoresent light) are bad.
3) The power supply to the inverter board is bad.
Someone knowledgeable in electronics can replace the bad part(s).
Dec 21, 2008 | Samsung LN-S2641D 26 in. LCD HDTV
Garmin Nuvi 200W
If you push for 5-8 seconds on satelit indicator and then release it, the satelit meni is showen.
Apr 29, 2008 | Garmin nuvi 200W GPS Receiver
Problems whit Samsung VP-D351 Visor and LCD in mode normal blur but in mode NITE PIX OK...? Some body knows..about this...is CCD Sensor...when repairthis....please
samsung vp-d351. lcd screen was bright white at first then suddenly went off (no picture). sound and everything else ok. can anybody help?
Aug 21, 2006 | Samsung Compact MiniDV Digital Camcorder
Televison & Video Logo
63 people viewed this question
Top Televison & Video Experts
Electro Med Services...
