Question about Fujitsu Siemens Computers & Internet
DNS server or whatever...
Hi to everyone. I have problem with my Fujitsu siemens Amilo pro V8210. It cant connect to web anyhow. its showing that is connecting, but nothing happened. I have Adsl line and also tried with my nokia mob. When i ve done diagnostic, it showed me problems with dns server. Everzthing else works, and coy of this, i ve reinstalled sys 2times, but still noithing. Thanx in advance
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 44 Answers
Check your firewall is turned on or not.
Hold down the Windows key and press R. (This will open the Run dialogue.)
  1. Type "cmd" and press Enter. (This will open a command prompt.)
  2. Type "ipconfig /flushdns" and press Enter.
  3. Type "ipconfig /registerdns" and press Enter
  4. Type "ipconfig /release" and press Enter.
  5. Type "ipconfig /renew" and press Enter.
  6. Type "netsh winsock reset" and press Enter.
  7. Reboot the computer.
Posted on May 08, 2013
  • Milijana Del May 09, 2013
    thanx very much. I ve tried that, as regular user and also as admin, but nothing. I still have the same problem. On taskbar Is showing that its connected, when i use any explorer showing "connecting, connecting....."-nothing. Im starting to think that it has something with OS or hardware, coz this is insane.
  • david May 12, 2013
    Not your hardware problem it's your OS. It happen to me with hp dv G70. Have you got factory partition than restart press F11 Use recovery disk or reinstall with new os if you have product key intact in your laptop.
SOURCE: Fujitsu Siemens - Easy Launch Keys - Wireless
I have had exactly the same problem happen a couple of days ago. My wireless network is always switched on and i never have to use the easy lauch keys. However my connection stopped a couple of days ago and my quick lauch keys have stoped working. All of them. I can only assume that the keys are broken/disconnected and because of this wireless will not work. i to have tried suggestions but the network connections box says that is connected and i know it not. Is there any other way round this or does anyone know how to fix the keys?
Posted on Oct 02, 2007
AvioriX
  • 689 Answers
SOURCE: amilo pro v2020 no sound device
Windows doesn't always recognize all devices, thats why laptop manufacturer's provide the driver with CD and also release on their support websites.
Model that you have usually comes with VIA Vinyl AC´97 So you can find it easily also its published support website of Fujitsu-Siemens.
here is the link
http://support.fujitsu-siemens.com/com/support/downloads.html
Please post your question if you need further assistance.
Good Luck
Posted on Jan 30, 2008
  • 101 Answers
SOURCE: fujitsu siemens amilo pro keyboard replacement
Hi is that you want to replace the existing keyboard from your mom's laptop ? if so right above the keyboard you will find a removable plastic panel (it is fragile breaks very easily so be carefull ) which would secured in place with snap on plastic locks or 3 screws would be securing it in place which you can see on the rear of the laptop , if the battery compartment is under the top portion then remove the battery you can see these screws . In any case please take your OWN TIME TO ANALYZE and only then attempt this. If you are succesfull in doing this then remove the other screws visible that holds the KB in place and lift up the KB slowly because the connecting cable is flexible PCB and you could easily TEAR IT OFF if you pull hard . The Connector also needs lot of attention - very thin and small release the side catches by lifting it with a watch screw driver very slowly else you will end up breaking it . If you have come to this stage GREAT replacing KB is reverse of all this procedure.
Posted on May 10, 2008
Exidous
  • 63 Answers
SOURCE: Fujitsu Siemens Amilo Pro V2055 laptop power on problem
Check to see if the ram is securely in place. (that will cause a pc to not boot, usually there is a beep code tho)
Posted on Oct 06, 2008
SOURCE: I have a Fujitsu Siemens Amilo Li 2727. The
Try downloading the automatic driver update tool from the website.
This should normally fix this problem by updating all drivers.
Posted on Aug 23, 2009
I have a fujitsu siemens AMILO Pro v8210 ,hardisk derial nr.871100490181 0807. Every time ill switch it on it ask for SATA HDD PASSWORD.wHAT IS THIS AND WHERE CAN I GET...
Problem 1:
The hard drive has been encrypted and password protected for theft protection. SATA HDD passwords cannot be reset or circumvented, if the person who entered the code does not tell it to you, the hard drive must be replaced for a new one. Again, there is no remedy. Connecting the HDD to a different computer and formatting the drive won't work either.
Problem 2:
Siemens and Fujitsu divorced some time ago, but Fujitsu continues to support the joint venture customers. An authorized Fujitsu service station can remove the BIOS password, but you will need to show proof of ownership.
Find contact information HERE.
Dec 23, 2010 | Fujitsu Siemens Computers & Internet
How do i turn my wirless connection on my fijitsu siemens amilo pro
Fujitsu Siemens Amilo A Series ---- Button above the keyboard on top right
Fujitsu Siemens Amilo D Series ---- Button above the keyboard on top right
Fujitsu Siemens Amilo K Series ---- Not Wireless
Fujitsu Siemens Amilo L/EL Series ---- Fn / F1 to turn on/off
Fujitsu Siemens Amilo La Series ---- Fn / F2 to turn on / off
Fujitsu Siemens Amilo Li Series ---- Easy launch button (one of 3) on top of keyboard
Gateway Laptop ---- Switch on side and then Fn / F2
Apr 02, 2010 | AT&T Siemens S46 GSM Cellular Phone
Does the fujitsu Siemens Amilo pro V2010 have a backlight I cant find it
Backlight is connected to the lcd so that the display become brighter and readable.
why do you want to take it out?
Mar 24, 2010 | Fujitsu Siemens AMILO Pro V2010 Notebook
Amilo xi 2428 built in web cam not working
If all drivers are installed and up to date...try pressing F7 and Fn to activate the cam. If that dosen't work, try connecting through Skype or a similiar server for a better signal.
You can find more support for your product on the companys website. Look in the Fujitsu Technology Solutions Forum
Hope this helps...
May 14, 2009 | Fujitsu Siemens AMILO Pro V2000 Notebook
Connection to wireless
There is any wireless adapter showing in the control panel.
According to the laptop specs, this laptop did not come with wireless capability. You need to purchase a wireless notebook adapter for it or us it with a network cable.
See the specs on this link:
AMILO-D-1840-FUJITSU-SIEMENS-Laptop-220304">http://www.twenga.co.uk/specs-AMILO-D-1840-FUJITSU-SIEMENS-Laptop-220304
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Apr 07, 2009 | Fujitsu Siemens AMILO Pro V1000 Notebook
No drivers
Hello there
I understand you need drivers for Fujitsu Simens Amilo Pro V2000 Notebook. Please click on the below link or copy and paste it in the address bar of a web browser. In that page enter the product name and click ">>" next to the search bar. You will get all the drivers for your Notebook model.
http://www.fujitsu-siemens.co.uk/support/downloads.html
Thank you
Feb 18, 2009 | Fujitsu Siemens AMILO Pro V2000 Notebook
Hpg6000 Vista 32 cannot access via browser
Hi.
This problem usually occurs if DNS addresses are not set-up correctly.
DNS addresses are IP addresses of DNS servers which translates your queries to IP addresses. Like, when you enter www.google.com in your browser, computer sends this to DNS server, then DNS server gives back information of the address of the site you're trying to visit. Since your computer does not know where DNS server is, it cannot display your web page. Some programs like Messenger and Skype work by quering exact addresses (since they are made to connect to single database on Internet), and that's the reason they are connected to Internet.
  1. Ask your Internet provider for DNS addresses.
  2. Open Start menu and then Control Panel.
  3. Open Network Connections.
  4. Right-click the connection you are using to connect to Internet, and click Properties.
  5. From the item list, choose Internet Protocol (TCP/IP).
  6. Click Properties.
  7. Click Use the following DNS server addresses.
  8. Enter given addresses.
  9. Click OK and then Close.
Your responses are intended to improve the level of service provided. Please rate your experience.
Jan 21, 2009 | Fujitsu Siemens AMILO Pro V2010 Notebook
Computers & Internet Logo
326 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Alun Cox
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
