Sxp2224wm password compex sxp2224wm has no dumping button. I changed the password by default and now I can't come into settings. how to dump the password or how to return factory settings?
  • 2 more comments
  • Alex May 08, 2013
    Compex sxp2224wm has no RESET button!
  • Alex May 08, 2013
  • Alex May 13, 2013
    I don't see a hole of marked RESET. Where it is located?
  • Doctor PC
    Doctor PC Apr 19, 2015
    OK try this: Open the device panel to enter inside the device. Inside locate a hole (like this onehttp://2.bp.blogspot.com/-XRgEwdM36M4/T3... then put a screwdriver on it an power on the device untitl leds or beeps then relase it and try to log in with admin/admin.
There is no reset button on this switch. i have the same problem and i need to reset 4 of them.... any help?
Posted on Apr 17, 2015
  • 7,733 Answers
Read here
Posted on May 12, 2013
Testimonial: "I don't see a hole of marked RESET. Where it is located?"
2 Suggested Answers
maxcarson
  • 7627 Answers
SOURCE: How can I reset Compex SGX 3226 to default (factory) settings?
Your device is a bit light on support, a brief user manual can be found here: http://www.manualslib.com/manual/223934/Compex-Sgx3226.html#manual Usually there is a tiny recessed RESET button on the device, push and hold for 30 seconds or so will return to defaults.
Posted on Apr 02, 2013
HOW DO I RESET Compex SXP2224WM-110 TO DEFAULT CONFIGURATIONS
To restore factory default settings, press and hold the reset button for 8 seconds and release! When you are holding the button, pls pay attention to the LED lights, at the beginning one of the lights will be on stably and then it turns to blink faster and faster. Suddenly,it stops and become slower, at this moment you can release the button and later all the lights will be on, it means the device is rebooting. When the device is completely started,you can check it.
Sep 09, 2014 | Computers & Internet
Apr 02, 2013 | Compex Computers & Internet
Have a 7x14 bray dump trailer dumps 3/4's then runs out of fluid. to fully dump i have to add fluid then as the box lowers down it pushes the extra fluid on to the ground?
When the dumping piston lowers, there should be fluid being taken into the other side of the piston from the return hose. The fluid level in the reservoir should not change. Has the hose routing been changed from original design?
Gary
Jul 26, 2011 | V, Inc. Dump Trailer Pump 12v Dc Double...
Picked up a Compex NetPassage 27G at a yard sale and cant access it. Does it have a default username and password?
Hi
start by trying these:
Default IP for all Compex's Routers/ APs/ Client Adapters: 192.168.168.1 Default IP for all Compex's Modems: 192.168.1.1 Default IP for all Compex's Switches: 192.168.100.128 Default Password for all Compex's products: Password Default User ID for Compex's modem: Admin
alternatively most router will have a reset button that's usually behind a little hole in the back or at the bottom of the unit. inspect the device carefully and introduce something sharp (that won't break) through that hole while the unit is powered and press for 30 to 60 seconds, this is usually how devices are brought back to factory defaults. if this does not work it's like the device is defective and you may want to get your money back!
hope that helps!
Apr 19, 2010 | Compex NetPassage 27G Wireless Router...
How to default the switch
turn off your swith and reset all things
Feb 27, 2010 | Compex (sxp2224wm) Networking Switch
I accidently set my boot menu to zero value on both choices now I cant boot back up
You don't say which setting you have 'assigned a zero value to', but the default settings are as follows:
Default operating system - Fortunately you couldn't have deleted anything here. Just make sure it is set to the OS of your choice (Chances are there will only be the one).
Time to display list... and time to display recovery... - Both should be 30 seconds (for XP and Vista). By default, both are ticked in XP, only time to display list is ticked in Vista.
If you hit the edit button (XP only) your boot file should look something like this (upper/lower case is not important, neither is the exact order):
[boot loader]
timeout=30
default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Home Edition" /noexecute=optin /fastdetect
Under the system failure section, tick everything.
Default for XP is small memory dump (64 KB), for Vista kernal memory dump.
Dump directory -
XP default is: %SystemRoot%\Minidump
Vista default is: %SystemRoot%\MWMORY.DMP
Do you REALLY promise you'll never do it again??? :-)
Matt
Feb 29, 2008 | Computers & Internet
Problem with SXP2224WM compex switch.
If I remember correctly, this device has vlan. Did you check to make sure that the vlan is configured or turned off? And does this have a firewall? Seems like a firewall is blocking ping port but allowing traffic. Also, I thought the 24WM was a 24 port switch, you mentioned a hub, but what kind of hub is it? It really sounds like a port blocking issue.
Jun 17, 2007 | Compex (sxp2224wm) Networking Switch
Computers & Internet Logo
103 people viewed this question
David Payne
David Payne
