Can't connect to my home wifi using my new Proscan Tablet
I have a Proscan Tablet #PLT7223G
  • 368 Answers
SOURCE: New Sylvania 7 mini tablet...on
Yes in that case it is your router. You need to adjust your setting, could be a web filtering, client filtering, or even time limit filtering that has been turn on. Check your router settings.
Posted on Jan 27, 2011
damneddle
  • 1607 Answers
SOURCE: Hello, I just purchased an
Turn on both your tablet and cellphone's bluetooth. Then from the bluetooth settings menu, make sure that your device is ready/enabled to be found by other bluetooth devices.
Then from bluetooth options, choose "add device". Once you found the other device, choose to connect with it.
Now your tablet and cellphone are connected to each other. You can now transfer files. BUT you can not connect to the internet using your bluetooth without a wireless router with a modem.
Posted on Jun 14, 2011
SOURCE: my new LG P970 won't
Go to settings, wireless networks, access points and then hit menu button then add access point and enter same address as the one that you are currently connected to then select the access point you just made and problem should be solved, reason why is there was a default proxy, this should fix your problem
Posted on Aug 22, 2011
jomabug76
  • 1148 Answers
SOURCE: toshiba thrive wifi connectivity
u search wifi networks ,,should have in the menu wifi connections or add a new network,,do a search for wifi,,a wifi scan,,when new netwrks or signal s appear on there,,,if it says open u can go online,,if passwrd enabled or wep or psk or whatever u cant ,,has to be a open signal,,like mcdonalds,,hotels,,,stuff like that,,drive an d search,,
Posted on Dec 23, 2011
SOURCE: why won't my kurio 7" tablet connect to wifi
I had this problem with my son's Kurio over Christmas and found that connecting to wireless in Kurio mode was impossible. If you go to the parental mode and click the switch to Android button there are settings for the wifi in the Android platform settings. You can set up there and then go back to the Kurio safe mode for the children to use. Hope this helps...
Posted on Dec 27, 2012
Factory reset
Factory reset Proscan PLT 70330 use power and volume buttons to reset.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Factory Reset on Proscan PLT7223G or Tablet
How to reset proscan tablet model PLT7033D to factory setting its locked
want to reset my PIN on my Proscan PLT7033D
Mar 23, 2016 | Cell Phones
How to reset passeword
you have to go into setting and set to manufactures settings. look for pin hole that states reset
now if you have a password already and you setup the password already that trying to bypass the password setting you will need the password in order to get to those setting i think.
you could go to website for the manufactures look up lost pass word bypass, or FAQ section, or if technical support can help you if you done all this already .
Mar 25, 2015 | Proscan PLT7223G-K 7in Android 4GB Tablet...
How can I get my Proscan PLT7223G to show what it is suppose to when typed ?
Go to Settings.
Go to Language & input
That's where you set up your preferences for your keyboard. Not sure of your particular tablet. However if you can set it to the default keyboard you should be o.k. That's where it gives you your preferences. What you might have is anticipation settings where it guesses what you are attempting to type.
Jul 09, 2014 | Proscan PLT7223G-K 7in Android 4GB Tablet...
WHAT DRIVERS DO I NEED ON MY LAPTOP, SO I CAN CONNECT TO MY LAPTOP AND TRANSFER MUSIC, FILES, ECT...!
Here is link to manufacturer download pages for PLT7223G models.
You may need additional code numbers
http://www.proscanvideo.com/products-search.asp?itemnmbr=PLT7223G&Submit1=search
Drivers are generally USB and would be computer operating system dependent. ( Android devices use "ADB" ).
Hope this helps
May 08, 2014 | Tablets & eReaders
How to unlock tablet proscan PLT7223G
Download the firmware update PRO_PLT7223G_FIRMWARE.ZIP
Download the RockusbDrivers from https://docs.google.com/file/d/0B_keThrKc71iYkZXMHNxZWdVT0U/edit
Save these files to a new folder on your desktop.
Unzip the FIRMWARE file and follow the instructions. When you need the tablet drivers, manually install the drivers from the RockUSBDrivers files in the new folder you created.
Jul 19, 2013 | Tablets & eReaders
Televison & Video Logo
217 people viewed this question
Top Televison & Video Experts
Electro Med Services...
