Question about Simmons Pro Diamond 4X32 Shotgun Matte
Simmons Pro Diamond Shotgun scope Manuals - Simmons Pro Diamond 4X32 Shotgun Matte
My reticle/crosshair has rotated by about 45 degrees anti-clockwise in my Simmons Deerfield 3-9x50 air rifle scope, is there a quick fix? Or is it a gun shop job?
You could do like my wife did on an old scope of mine, run your finger into it, but then all you see is clear. the olny thing you mght ry is to roatate the scope clockwise about 45 degrees or replace the scope. you might contact Simmons, they might replace the scope for you. Good luck.
Mar 20, 2015 | Simmons Optics
Need a manual for a Simmons Model 21012 Rifle Scope, 3X - 9X Variable,where can I get one?
Download the appropriate manual from here: http://simmonsoptics.com/global/manuals.aspx
Mar 11, 2015 | Simmons Optics
Simmons 8x32-44ao rifle scope
Is that the "Prairie Master"? I think Simmons is pretty uniform in that range of scopes--elevation adjustment should be the top dial and windage is on the side. The zoom locking ring should be in front of the eyepiece, with the zoom ring just forward of that.
You can download a generic Simmons scope manual from the Simmons site at this link: http://www.simmonsoptics.com/downloads/manuals/archive/HSI_Simmons%20Generic%20Scope%20Adjusting%20Instructions.pdf
Mar 31, 2010 | Simmons 510513 3-9x40 Blazer Riflescope -...
Simmons Prohunter Model 517710 won't shoot a group
You SHOULD send it back. There is something loose inside the scope. Even the worst Simmons scope will get you to 2"-3" group. Also, when you replace it, you might want to consider their (or Nikons) shotgun scopes. They are built to with stand the power of the higher centerfire calibers and magnum shotgun shells.
Jan 23, 2009 | Master Heaters Simmons Master ProHunter...
Need to reset scope to zero
Turn the ajdustment knob, all the way in one direction. Then, counting the number of clicks as you do it, turn it all the way in the OTHER direction. Do this slowly. Turn it back, HALF that number, and it will be zeroed. Example - If the total number of clicks is 32, turn it back 16 clicks, to zero the crosshairs.
Dec 06, 2008 | Master Heaters Simmons Master Series...
Do you guys make scopes?
A scope on a shotgun are you funny in the head? Its a Cqb weapon not a marksmens rifle. You wont find a scope for a shotgun ever.
Sep 15, 2008 | Crosman (4032)
Simmons Pro Diamond 4X32 Shotgun Matte Logo
44 people viewed this question
Top Simmons Optics Experts
Mark Campeau
Level 1 Expert
John Hong
John Hong
Ted Maxwell
Are you a Simmons Optic Expert? Answer questions, earn points and help others
