Question about Echo Garden
Will not run
My echo cs-305 just stoped running and will not start again . I have full gas tank-- 50/1 good spark --- carberator is clean and not flodding eng.-- crank seals apear to be good--- I have about 3.5 Hr. of sawing on this saw any ideas
  • Echo Master
  • 2,239 Answers
You need to make sure it is mechanicaly ok ( not scuffed the piston ) remove the muffler and check the condition of the piston skirt through the open exhaust port, any sign of damage and the machine will need to come apart.
Posted on May 09, 2013
3 Suggested Answers
onescewleft
  • 18 Answers
SOURCE: Echo CS-440 Chainsaw.
unleaded fuel is notorious for going stale,and it can leave a resinous coating in the carb-try running the saw on half choke with new gas and less oil eg 50 to 1 for say ten minutes,this should clear the gunk out-if this does not work,you have two choices-strip and clean the carb,or adjust the H (high) scew on the carb anti-clockwise by a quarter turn a time till it revs out full bore-good idea to remove the chain and wear ear defenders when adjusting-and always use a chainsaw at its max rpm,or you run the risk of "kickback"
Posted on Feb 25, 2010
Testimonial: "Very good information. Not sure if the easy cure will work but at least I know where to start. Thanks "
  • 2239 Answers
SOURCE: I have an Echo CS-3450 16" Chain saw that starts
This is classic fuel starvation, it needs to run a little rich when free running, when it goes under load it needs the extra fuel to keep it going, if you have replaced the fuel filter, and the fuel hoses are good ( no leaks, or cracks in the pipe, give the pipe a tug to see if fuel squirts out ) then there is dirt in the main fuel screen under the pump diaphram, remove the carb, remove the alloy pump cover, normally held with a single screw, under here will be a gasket, and a pump diaphram, in that order, pressed into the carb is a very fine screen, this should be replaced, or at least cleaned, check the condition of the diaphram, this should be supple not hardened, rebuild and try again, the H screw on the side of the carb controls fuel to the main jet, if need be increase ( screw out ) 1/4 turn.Somewhere from the tank will be a breather, this allows air into the tank to stop a vacume occuring, to check this slacken the filer cap when the machine starts to die, if it picks up again it is a breather issue.
Posted on Jul 18, 2011
Mx-2721b gas generator carb kit
check for spark if spark squirt some starting fluid in carb dose it try to start or runs chang gas put fresh gas in it and seafoam carberator additve in it restart sameway let it run three tank fulls out then try to start it regular way if still dosnt wont to run rebuild carb this is how a shop would do it
Sep 02, 2014 | Electrical Supplies
Bolens cultivator model BL410 won't keep running
clean the screen inside the muffler
Aug 03, 2012 | Garden
ECHO PB-500T - Stopped running and added gas fuel mix. Quit running again with full tank and now flywheel is stuck and I can't pull to start it. What is the problem?
My $350 Echo PB-500T seized up. I almost cried.
The solution was to drain the fuel tank.
  • Refill fuel tank with an 2-cycle Oli/gas mixture.
  • 40:1 =3.2 oz to one-gallon gas, do not use Alcohol base gas.
  • Remove the spark plug.
  • Pour approximate 1/8 oz 2-cycle Oli into the spark plug hole.
  • Remove the pull cord assembly (4-bolts)
  • This reviled the crank shaft-Pull cord bracket
  • I use a large monkey wrench to turn the shaft (CW) Clock-wise.
  • Complete approximate 20 revolutions.
  • Reassemble, but don't install the spark plug yet.
  • Complete approximate 20 more revolutions
    by pulling the pull cord.
  • Use q-tips to swab the top of the piston, as much as possible.
  • Install the spark-plug and crank, it will smoke for amount 7-10 minutes
Jul 30, 2011 | Echo Gas Blower 162 MPH 450 CFM Blower...
Echo cs-370 chainsaw wont start. running fine the day before. good spark. fuel wet at muffler. plug always wet.
Check air filter- is it clean?
Some plugs are without cilinder ok but if in place dont work. cahange the spark plug.
Mar 17, 2011 | Echo Garden
The other day it is running fine then all of a sudden it dies and won't start. air cleaner is clean. The a couple of days later, I start it and runs fine. I'm blowing off the patio and it dies again after...
If the air filter is clean, then you have either no spark or no gas. Gummed up carberators are well familiar with the leaf blowers. Once a year or every other year you should clean up your carb. During the winter season when your not using the blower, it is a good idea to put a 1/2 bottle of Stabil in the gas tank which will prevent carb gum-up while being stored.
You can remove the spark plug, put it back on the wire, lay the bottom of the plug next to a metal surface. Then pull the motor over while you observe for a good strong spark. If you have a good strong spark, then the problem is with the fuel.
If you have no spark, weak spark, or intermittent spark, then either the coil could be bad, plug could be bad, or you may even have a shorted kill switch.
Either no gas or no spark is your problem. Spark is easiest to check. If spark is good, remove and clean your carberator out thuroughly
Dec 31, 2010 | Garden
Echo CS-440 Chainsaw. Was cutting firewood, saw running fine until I refilled the gas tank. The gas was a few months old but looked clean and smelled OK. But after I filled the tank could not get the...
Feb 25, 2010 | Echo 30.1CC Chainsaw With a 14 In.bar and...
Poulan 446 Pro engine won't run
its probably not getting any gas from the tank try putting your finger on the hole on the carberator and pull your finger should be wet if not take fuel line of the carburator and thenblow then take off the gas cap and blow through the hole on the gas tank it should flow freely throgh teh line to the carburator
Nov 06, 2009 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
Chainsaw starts fine, but dies mid cut?
Immediately after saw quits, while everything is still hot. Sometimes ignition modules quit working when hot.
Ignition Coil Test
SmallEng.com
http://www.youtube.com/watch?v=L7WNBDRG4C4
You may need to use a jumper wire between the threaded part of the plug and the cooling fins. You don’t have to bend up the electrode.
Loosen fuel cap when it starts to die, If that fixes it it has a fuel vent problem.
If you did nothing to the carburetor adjustments, are using a fresh (3 months or less) fuel mix with the same oil/fuel ratio, and are operating at the same elevation there is a reason your saw is acting up.
It sounds as though there may be a fuel delivery problem. Check the fuel filter on the free end of a hose in fuel tank (manufacturer recommends an annual replacement). Check all fuel delivery lines especially at fittings and bends for cracks and holes. If those are good then the likely cause is internal parts of the carburetor. HTH
Lou
Oct 12, 2009 | Echo Garden
Garden Logo
48 people viewed this question
Top Echo Garden Experts
Jim London
Jim London
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you an Echo Garden Expert? Answer questions, earn points and help others
