Question about Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony Bravia KDL-32S20l1
I see a thin pink vertical line on bright backgrounds, but on dark backgrounds the line is gone and the picure is great. This trouble is on any picture mode. (Digital, Analog,& Video games)
  • Anonymous Mar 16, 2009
    I hava a Sony Bravia 42 Inches and vertical lines has come out in the middle on the screen.
    Any idea how much it will cost me to fix this?
  • Anonymous Mar 28, 2009
    Pink vertical line on the left side of the screen! any help would be appreciated!
2 Suggested Answers
SOURCE:
  • 53 Answers
SOURCE: Vertical line on KDL-32s20l1
You'll get this abnormality some times due to the signal if you're watching regular analog picture and you have your TV set on full screen, the TV will stretch the picture and you will see more defects than if you're watching it on normal picture. But if you are seeing the same problem when watching HD picture it needs to be serviced try this link I found: http://www.moniserv.com/doc/lcdtv.html
Posted on Aug 28, 2007
I have a Bravia KDL 40BX421 that suddenly has green vertical lines on the bottom 1/4 of the screen. These lines are in a background bar that is mostly a reddish shade.
Thin vertical lines cover screen on Samsung LCD - AVS Forum ' Home ...
www.avsforum.com/.../1127410-thin-vertical-lines-cover-screen-samsun...
Mar 7, 2009 - 30 posts - ‎25 authors
Hi guys, Ive had this TV for about a year now - all of a sudden thin vertical lines havecovered my screen (show in link below) No matter what ...Missing: 40bx421
TV Repair Help for Vertical & Horizontal Lines on Your TV ...
? 2:47
https://www.youtube.com/watch?v=b0sI7LB4cZE
Apr 25, 2014 - Uploaded by ShopJimmy.com
TV Repair help with troubleshooting lines on your TV Screen. ... hi i have a sony bravia mdel # KDL46EX523. i have horizontal multi colored lines ... My TV has the following symptoms: - Horizontal lines from top to bottom of .... thick(like 1-1/12 inch) and a couple of green vertical lines next to the black one.Missing: kdl ‎40bx421
Flat Screen TV Has Lines Going Through Screen - Possible ...
Dec 16, 2015 | Televison & Video
What's wrong with my Bravia if at power up screen displays vertical thin lines with dark background. Power LED is green. Thanks Guys!!
This sounds like the power supply in the TV. It may be a bad capacitor or a bridge rectifier causing the problem. Get a volt meter and start making some voltage measurements. This may help find your problem.
May 20, 2014 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Vertical shadows every 3" on sony bravia 32 about 1/4" wide
Image burn from leaving it on.. Its the vertical colors we get when we disconnect everything.. Its stand by screen.. It won't get worse.. But u either have to replace it.. Or live with it..
Feb 06, 2018 | Sony BRAVIA KDL-32S2010 32 in. LCD...
Vertical lines after the tv is been for a minute
If you can open LCD Tv than refit all connector of Mother Board
Jan 21, 2010 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
I have a Sony 26 inch Bravia LCD tv model KDL-V26XBR1.It has thin vertical black and yellow lines about an inch apart across the whole display. Not noticeable from a distance but really see them up...
Well if the panel is bad it would not clear up in any situation, so its not the panel. most likely the t-con board or just poor connections inside. Julio Millenium TV in Las Vegas.
Dec 18, 2009 | Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD...
Sony Bravia KDL-40S2000 thin vertical line
If the line is present in all inputs and modes, there is a problem with the LCD Panel. The only way to fix it is to replace the whole LCD Panel which is very expensive (usually around $1000+ for 40" Sony). Unless the TV in under warranty, it is usually around the same price for a new TV.
Oct 05, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
LCD Displaying Red instead of Black, Vertical Lines in Display
I had a similar problem where the screen went to a pink shade periodically. Sony sent me a memory stick, with download instructions, that fit into one of the back ports. The problem has gone away. It was a software correction.
Mar 15, 2009 | Sony KDL-46XBR4 46 in. LCD Television
Aug 27, 2007 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Sony BRAVIA KDL-40S2000 40 in. LCD HDTV Logo
542 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
