Question about Satechi Soundfly Aux Mp3 Player Car Fm Transmitter For Sd Card, Usb Stick,
WMA not playing
My Satechi Soundfly is not playing WMA files. Can someone help me with this ? Thanks Dan
I'm using a satechi soundfly Bluetooth fm
some send a stereo signal others send a single channel signal which is heard from either side..if the transmitter battery is weak(or cold) it will sound from one side..if not connected properly it will do the same thing..its a matter of process of elimination as to the exact issue or contact the outfit who sold the equipment..
Feb 24, 2013 | Cars & Trucks
Cannot listen WMA songs on memory card on my gravity phone
Your phone is unfortunately not capable of playing WMA file format. Your can convert your music to MP3 file format easily and that will allow you to play it back on your phone.
Apr 14, 2010 | Samsung Gravity SGH-T459 Cell Phone
Plays wma books, will not play mp3 books
convert the mp3 files to wma on a computer and then try
May 31, 2009 | SanDisk Sansa Clip MP3 Player
I have burned a .wma video file on a cd-r, on my computer it runs perfectly... only when i put it in my dvd player it say's stop and won't play. Can someone help me out ? Thanks Jeff
Several causes for non-playback:
1. Your CD player doesn't like CD-R
2. Your CD player doesn't recognize wma
3. The music you converted to wma is copy protected and the CD player wont play due to that.
Solutions:
1. Most likely this isn't the problem as most working CD/DVD players recognize CD-R. Double check with your user manual.
2. Check your DVD player's playback formats. Most will play mp3 and wav. If that's the case, rip your music to mp3.
3. There are many hacks out there to remove copy protection. This you'll have to figure out on your own :)
May 02, 2009 | Philips Televison & Video
Music will not play
I managed to get this sorted by changing the default setting in windows media player from ripping the CDs as a wma protected file to a mp3 file.
Dec 25, 2008 | Mattel Barbie Girls MP3 Player
Wont play wma files
Different players will accomodate different formats. You might have to reformat the WMA files on your PC and then transfer to your unit.
Nov 01, 2008 | Philips GOGEAR SA6045 MP3 Player
Enable wma playback
Hello irie8,
According to PSP system software update 2.60 allow the PSP to be able to play WMA files. So if you have all the latest system file updates on your PSP, you should be able to play WMA files. However here is the link I found to be very helpful.
http://www.us.playstation.com/PSP/About/SystemUpdate/history.html#update260
I hope this information was helpful.
Sincerely,
Agent Xiong
May 19, 2008 | Sony PlayStation Portable (PSP) Console
Tatung M100 Error
I don't think it plays wma files
Nov 29, 2007 | Tatung Elio Photo JukeBox MP3 Player
225 mr will not play burn MP3's
I have the manual and copied it verbatim for you. Please let me know if you need me to scan the manual for you. Acceptable medium formats: The following formats are available for the media used in this unit. The maximum number of characters used for file name including the delimiter (".") and three-character extension are indicated in parentheses. ? ISO 9660 Level 1 (12 characters) ? ISO 9660 Level 2 (31 characters) ? Joliet (64 character; Up to 32 characters are displayed) ? Romeo (128 character; Up to 64 characters are displayed) ? Long file name (200 characters; Up to 64 characters are displayed) ? Maximum number of characters for folder name: 64 (Joliet; Up to 32 characters are displayed) For a list of available characters, see the instruction manual of the writing software and the section Entering file and folder names below. The media reproducible on this unit has the following limitations: ? Maximum number of directory levels: 8 ? Maximum number of files per folder: 255 ? Maximum number of folders: 50 MP3/WMA written in the formats other than the above may not be successfully played and their file names or folder names are not properly displayed. Settings for your MP3/WMA encoder and CD writer Do the following setting when compressing audio data in MP3/WMA data with the MP3/WMA encoder. ? Transfer bit rate MP3: 8 ?320 kbps WMA: 48 ?192 kbps ? Sampling frequency MP3: 8, 11.025, 12, 16, 22.05, 24, 32, 44.1, 48 kHz WMA: 32, 44.1, 48 kHz When you use your CD writer to record MP3/WMA up to the maximum disc capacity, disable additional writing. For recording on an empty disc up to the maximum capacity at once, check Disc at Once. Play mode may not be possible when portions of the functions of Windows Media Player 9 or higher are used. Entering ID3 tag: The Displayable ID3 tag is ID3 version 1.x. For the character code, refer to the List of Codes. Entering file and folder names: The code list characters are the only file names and folder names that can be entered and displayed. If you use any other character for entry, the file and folder names are not displayed correctly. They may neither be displayed correctly depending on the CD writer used. The unit recognizes and plays only those MP3/WMA which have the MP3/WMA extension (.MP3/.WMA). A file with a name entered with characters not on the code list may not play correctly. Writing files into a medium: When a medium containing MP3/WMA data is loaded, the unit checks all the data on the medium. If the medium contains a lot of folders or non-MP3/WMA files, therefore, it takes a long time until the unit starts playing MP3/WMA. In addition, it may take time for the unit to move to the next MP3/WMA file or a File Search or Folder Search may not be performed smoothly. Loading such a medium may produce loud noise to damage the speakers. ? Do no attempt to play a medium containing a non-MP3/WMA file with the MP3/WMA extension. The unit mistakes non-MP3/WMA files for MP3/WMA data as long as they have the MP3/WMA extension. ? Do not attempt to play a medium containing non MP3/WMA.
Jul 31, 2007 | Kenwood KDC-225MR 200W Car/Marine SIRIUS...
Won't paly WMA files that I bought online!
I remember reading somewhere that if you upgrade your firmware of your H340 from US to international to get video you lose the ability to play DRM music. I from this I would that the international version can't play the copy protected files. I am not sure of the legalities in your location, but you may be able to work around the copy protection. Maybe a google search would give you some hints.
Nov 13, 2006 | iRiver H340 MP3 Player
Satechi Soundfly Aux Mp3 Player Car Fm Transmitter For Sd Card, Usb Stick, Logo
42 people viewed this question
Top Satechi Computers & Internet Experts
David Payne
David Payne
Are you a Satechi Computer and Internet Expert? Answer questions, earn points and help others
