I have an amana ntw4630yq washer and a piece of the lock mechanism came loose. my boyfriend took it apart but I can't find anywhere that shows how to put it back together. the washer won't work without it
Hello I have a AMANA washer top loader model number NTW4700YQ. The washer will do the 5 second fill when you start a wash cycle and then switches over to "lid Lock" now after this it does nothing. you can...
The lid switch is one thing to check, make sure that it is not loose or broken, IT could also be the water level sensor, they become gummed up with softner sometimes.
Dec 09, 2013 | Amana Washing Machines
Amana he washer door won't close
Bad lock mechanism, without proper model number I can't give accurate instructions.
Jun 22, 2012 | Amana Washing Machines
I took apart my Dremel 395 Type 3 and the spring popped out for the shaft lock. Where does the spring attach to?
It doesn't attach anywhere, that's why it popped out. It should just fit in a recess, pushing the lock button outward.
Sep 10, 2011 | Dremel Variable - Speed Multipro Rotary...
Washer agitates but will not spin drain spin or fill
Well I have a Roper Top Load Washer, bought it in 1998 ,no problems til back 6 years ago we had someone come fix it. My problem was the same wouldn't drain or spin. The problem was it was clogged, in the front when you lift off the washer casing theres a white piece connected to to tubes that drain. well there was my daughters pair of underwear in there and a couple small socks. He took them out put it back together and worked ever since. Until earlier tonight we had same problem so we took it apart ourselves and found my boyfriends sock in there took it out and put it back together and works great again. So far so good. Hope this helps Good luck. Tammy
Nov 05, 2010 | Whirlpool LSR8433K Top Load Washer
Amana front load washer door locked with door open
To get the front off. (All screws look to be #2 Phillips Screws)
1. You have to unscrew (2) phillips screws from the back that holds the top on.
2. Slide the top off. (slide towards the back)
3. Then where the control panel is there is about 4-6 screws holding that plastic piece on, take those out this will allow you to pull the control panel up and out of the way.
4. At this point you can unscrew the 4-6 screws in the door area that holds the front of the washer on, once you unscrew those screws there is a tab that you have to lift the front over to pull the front off. This will allow you access to the locking mechanism.
5. There are only 2 screws holding te locking mechanism on.
Feb 25, 2009 | Amana Washing Machines
DE shows-the door will not lock.I even took it apart.
door lock is not designed as a repairable item.just buy a new one.if it still dosent work,give the door an additional push.if it still dosent go ,brobably a fault with the main power board.(rare)
Feb 02, 2009 | LG WM-2277HW Front Load Washer
I need to remove the agitator from my washing machine.
On most Amana washers you pull on the agitator with brute force. It "snaps" on. It helps if you fill the washer with hot water and let it set for a few minutes... drain and then try pulling it out. When i last took apart my Amana it took me and a friend to pull the agitator off.
Nov 22, 2008 | Amana NAV2335A Top Load Washer
Burner knob wont turn
appliance repair and yes you can fix it you likely need an infinite switch
Apr 17, 2008 | Cooktops
VGB3 leg lock broke
On the velbon vgb 3, the leg locks consist of a lever, one or two pieces of metal and a plastic piece. The metal and plastic pieces rest in a depression against the lever. When the lever is pulled out, pressure against the smaller leg section is released. When the lever is pushed in, pressure against the smaller leg section is exerted, locking the legs in place. On the back side of each joint, there is a phillips head screw which acts as a stop to keep the leg section from coming all the way out. When the screw is backed out, the leg section can be removed, exposing the latching mechanism. If the only problem is that the latch mechanism came apart, it can simply be reassembled. If, however, something broke and allowed the latch assemby to come apart, that will have to be dealt with as well. My guess is that the phillips screw may have become loose, and the latch came apart.
Aug 14, 2006 | Velbon Chaser EFL-4 (A) Tripod
Washing Machines Logo
44 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
