Question about Vaico 2010 - 2011 Mercedes-Benz Sprinter 3500 Suspension Control Arm Vaico
Sprinter fault code
P229f
Problem with sprinter 2008 dont start
Have you run fault code tests? Does the starter spin and engine turn over but not start? I need more details.
Jun 17, 2016 | 2008 Dodge Sprinter
Two OBDII codes. How to fix?
P0101, mass air flow circuit range, P242F appears to be a non code , may mean don't forget to repair previous code. Check and repair mass air flow problem . then delete code, code will reappear if fault not fixed.
Jul 09, 2015 | 2009 Dodge Sprinter 2500
Fault code p1955
I used a generic scan tool on a v6 sprinter and it gave me fault code p1955 as a current code. I hooked up the factory scan tool (star diagnosis) and had no fault codes. Looked up the mercedes benz obd codes and this code does not exist. What symptoms do you have with your sprinter?
Aug 11, 2011 | 2010 Mercedes-Benz Sprinter
P242F Bank1Sensor3 sprinter fault codes 07 Sprinter 2500
Bank one is the side on a V or H engine where cylinder number one is located. On an in-line engine you only have a bank one, no bank 2. Sensor 3 will be the third sensor from the engine in the exhaust stream.
Oct 25, 2009 | Dodge Sprinter
2007 sprinter trouble code po674?
0675 is a fault in glow plug # 5 .I dont see a 674 in my list , but I got it off the web and my not be complete. and its for 08 dzl
Aug 10, 2009 | 2007 Dodge Sprinter
2006 dodge sprinter esp light on and tire spin light
Go to nearest garage and do diagnosis test and fault erase.
Mar 04, 2009 | 2006 Dodge Sprinter
LIMP MODE
You will have to have the fault codes read and removed. If it is permanently in limp mode it may suggest another problem.
Nov 19, 2008 | 2002 Dodge Sprinter
Vaico 2010 - 2011 Mercedes-Benz Sprinter 3500 Suspension Control Arm Vaico Logo
192 people viewed this question
Top Vaico GPS Experts
Will Halftowaite
Are you a Vaico GPS Expert? Answer questions, earn points and help others
