Question about Craftsman 8.50 Torque Rating Rear Tine Tiller
Tiller won't move
Tines will engage and work, shift lever works freely when not running and am able to get it F and R, but will now move. When in neutral I can move it bout 4 rotations of the tire forward and then it locks up-- can then do the same going backwards and same happens. belt is tight just wont move. Any help you could give me would be appreciated.
2 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: Own a "Craftsman Rear Tine
Can you move the tines by hand???
They should turn by hand if you try to move them...if not then they are bound up by something...
either a bearing has gone bad, something has wrapped around them, or there is something stuck in there that will not let them turn...check for a rock stuck between one of the tines and the housing around them...
Get the tines moving freely and you will be okay again...
heatman101
Posted on Mar 31, 2011
Tines wont engage on my troy built pony. How can i fix it?
The lever for the tines moves easily? Is there an adjustment on the linkage that may need tightening?
May 11, 2012 | Troy-Bilt Pony Garden Tiller
I have a 1988 troy bilt horse 8hp the tines rotate when its engaged or in disengaged
check the shift linkage sometimes the pins fall out when you shift it does it move to freely
Apr 19, 2012 | Garden
Ryobi ry64400 tiller tines won't move engine runs fine
then you need to open the gear box and find out why if it has a forward and reverse the the shifting linkage it could be stuck in one gear and adding the other will lock it up as well
Apr 17, 2012 | Ryobi Cultivator
Own an older (1990's) American Yard Products model WER500 Weedeater rear tine rotortiller. The engine runs great but when I engage to til, the tines won't turn. The belt is fine and pulleys turn...
Yes, there are shear pins on the tines and on the wheels. Can you check to see if the belt actually moves when the pulleys turn?
May 13, 2011 | Garden
Mtd rear tines tiller won't engage tines. F and R
I had similar problem recently with 2007 Huskee MTD series 410. The shift assembly bent and couldn't move the clutch collar all the way over on the drive shaft.
Apr 23, 2010 | Mtd Products Yard Machines 158CC Tiller
Tiller goes For./Rev. but wont drive forward with tines engaged
check the sher bolt on the tine to drive shaft. ill need model and ser number off the unit before i can go further with helping you thy changed them around a lot
Oct 09, 2009 | Mtd Garden
How do i put a troy-bilt tiller 3 hp.into free
The way to move without the motor running...
1.on each wheel pull pin in center of hub
2.push wheel closer to motor.
3.put pin back in to axle but not though hub
4.do the same steps to other wheel
now you can push tiller
Apr 07, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Troy bilt horse pto clutch will not disengage
The problem is lack of lubrication in the pto coupling. Losen the two swing bolts carefuly,block the front under the motor. Separate the tine transmision from the housing and grease both sides with as much grease as you can work in. Work the lever as you do this. Should fix the problem.
Jan 17, 2009 | Troy-Bilt Pony Garden Tiller
Yard Machines/Tiller
the tines are usually connected with shear bolts designed to break away when u hit something as a safety precaution so that u dont break anything in the transmission. its common that people dont know this and replace them with normal bolts. if this was done and the tines are not moving now chances are uve got a snapped gear shaft
Sep 28, 2008 | Mtd Super Bronco Rt Tiller
Craftsman 8.50 Torque Rating  Rear Tine Tiller Logo
80 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
