Question about Sanyo PLV-Z2000 Projector
Projector lcd alignment - Sanyo PLV-Z2000 Projector
I have christie lx25 Projector .After cleaning lcd chip picture in double
LCD block of the projector are properly aligned at the manufacture with a special machinery and software. If you've removed them individually, then they've gone way out of alignment.
Jun 01, 2015 | Christie Office Equipment & Supplies
Alignment
It seems that the lcd panels are failed
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Jan 26, 2014 | NEC Lamp for VT460K Projector
My sony projector works great but there seems to be some green coming in on the screen..i played with the setting but no results..Are their any trim pots for the red,blue,green lcd panels?
if you reset the settings to factory default and swaped out cables, then the oly thing left to do would be to realign the lcd panels. unfortunately, only sharp service centers can do this easily. they have a tool specifically made for lcd panrl alignments on sharp projectors. you could try av solutions in ny. the'yr pretty good. www.avsolutionsny.com
Dec 04, 2009 | Sony VPL HS10 Multimedia Projector
My Eiki Projector is fading blue. I just bought a replacement lamp and it didn't help at all. Is there anyway to fix this?
The lamp is not the problem. Based on your description, you have a Blue lcd panel going bad.You will have to have the projector repaired--lcd replacement and re-alignment. The projector is out of production so you'll have to find a service center that do the work. If you enter "lcd projector service" in a search engine, there are a lot of reputable centers that can do the work.
Sep 01, 2009 | Eiki LC-SB22 SVGA LCD Projector Multimedia...
Blue on one side
It isn't the LCD panels, it is the Polarizers that degrade with heat. You can replace them yourself.
Mar 09, 2009 | Epson EMP-61 Multimedia Projector
Blurred side of projector
This is caused by misaligned lens and/or display panel (LCD or DLP). Recommend a trained tech to perform alignment.
Mar 08, 2009 | HP Digital Projector Vp6110 Multimedia...
ALIGNMENT Problem - InFocus Proxima DP6155 Multimedia Projector
if the lcd panels have become misaligned, it is time for a new projector, the parts are no longer available for this unit, and it needs the most expensive part, the LCD block
Jul 19, 2008 | InFocus Proxima DP6155 Multimedia...
Color shift
Hi there
There is unfortunatelly no section in the Service Manual to explain this sort of procedure.
You'll have to move the LCD panels one by one - millimeter by millimeter.
Mar 29, 2008 | InFocus LP290 1100 Lumen XGA LCD Projector...
Alignment (convergence) of color panels MT1050
I can assist you with that if you want. It is very tedious, but can be done. You need a cross hatch pattern generator or something with vertical and horizontal lines to lineup the LCD Panels again. Tricky little procedure if your not familiar with it. Let me know if i can assist you and hopefully save you agravation at the same time. Thanks Jay
Jan 12, 2008 | NEC MultiSync MT1050 Multimedia Projector
Proxima projector A10
reset the settings to factory default. if it's still off, you'll need to send it in to an infocus service center. they'll have to realign the lcd panels or replace the optical engine.
Nov 21, 2007 | InFocus Proxima Impression A10 Multimedia...
Sanyo PLV-Z2000 Projector Logo
Top Sanyo Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
