Question about Vaico 2010 - 2011 Mercedes-Benz Sprinter 3500 Suspension Control Arm Vaico
Sprinter fault code P22A1 P229F
WE CAN'T FIND A SYMPTOM FOR THESE FAULT CODES ON A 2011 MERCEDES SPRINTER P221A AND P229F
Mercedes Benz sprinter 515 CDI,it just cranking and gives stored fault code on the diagonosing mechine. P008700 Low fuel pressure
Fault codes can be misleading and using a code reader is just one step to reaching a diagnosis, using manual checking of components and sensors and studying live data displayed on a good scanner.
Low fuel pressure could be caused by insufficient fuel being delivered due to a restricted fuel line or faulty pump or equally be caused by faulty injectors and other problems.
Aug 18, 2016 | Cars & Trucks
2008 Sprinter van. It is running but why won't it get out of neutral?
run the fault codes and look for torque converter clutch solenoid and TCM problems
Jul 19, 2015 | Mercedes-Benz Cars & Trucks
Two OBDII codes. How to fix?
P0101, mass air flow circuit range, P242F appears to be a non code , may mean don't forget to repair previous code. Check and repair mass air flow problem . then delete code, code will reappear if fault not fixed.
Jul 09, 2015 | 2009 Dodge Sprinter 2500
What oil to use in mercedes sprinter 313CDU
  • Full Synthetic 5W40 is what Mercedes says to use on the new Sprinter's.
Oct 27, 2011 | 2010 Mercedes-Benz Sprinter
Fault code p1955
I used a generic scan tool on a v6 sprinter and it gave me fault code p1955 as a current code. I hooked up the factory scan tool (star diagnosis) and had no fault codes. Looked up the mercedes benz obd codes and this code does not exist. What symptoms do you have with your sprinter?
Aug 11, 2011 | 2010 Mercedes-Benz Sprinter
LIMP MODE
You will have to have the fault codes read and removed. If it is permanently in limp mode it may suggest another problem.
Nov 19, 2008 | 2002 Dodge Sprinter
Vaico 2010 - 2011 Mercedes-Benz Sprinter 3500 Suspension Control Arm Vaico Logo
1,202 people viewed this question
Top Vaico GPS Experts
Will Halftowaite
Are you a Vaico GPS Expert? Answer questions, earn points and help others
